RDX Hood play movement
Old 01-18-2019, 10:46 AM
David Ram's Avatar
Took my RDX in for the rough shifting issue, break squeal,and hood movement.
Service tech mentioned that my shifting issue was resolved after applying an update, break squeal was mentioned to be a normal thing seen with this vehicle no fix was applied.
One thing he did mention was that there was documentation about the hood having some movement at speeds above 60mph and that it is a documented issue that acura may fix at sometime.
Not sure if anyone else has these problems but want to make sure you guys bring these up so it gets fixed sooner if you are experiencing any of these issues.
Old 01-18-2019, 11:13 AM
Received 8,582 Likes on 6,629 Posts
A few threads on it:
https://www.google.com/search?q=site...hrome&ie=UTF-8
Old 01-18-2019, 12:29 PM
JB in AZ's Avatar
Unless I'm wrong, these seem to be regarding the previous generation RDX. Doesn't mean this gen isn't experiencing the issue as well, however.
Old 01-18-2019, 07:21 PM
Dereileak's Avatar
so they updated your transmission control unit? Do you have the invoice of what it says?
Old 01-19-2019, 02:39 AM
Master47's Avatar
It the tranny noticeably smoother? I’d be willing to do a software update to ours, but not much interested in the clutch break-in procedure where they mechanically wear the parts to be smoother shifting...
Old 01-19-2019, 03:18 AM
Null and proud of it
Midnight Mystery's Avatar
What What and What???
Thread title identifies nothing in thread.
Softwear update mechanically wears the clutch packs in transmission???
That is a horrible idea!
Old 01-19-2019, 06:32 AM
Master47's Avatar
You’re right, way off track from the thread title. Hood movement....meh.....You got a software update to fix a tranny problem from another thread that has multiple pages?!?! Say whaaat? Tell me more!
Let me clarify...the rough 1-2-3 shifting problem has seen multiple fixes mentioned on another thread.. One of those is the clutch break-in procedure, which sounds like mechanical wearing in of parts to get them to mesh well. I don’t like that idea. OP here mentions a simple software fix available (presumably changes sequence timing of movements inside the transmission, but who knows). I’m interested in how that worked out...
Old 01-19-2019, 04:19 PM
David Ram's Avatar
Invoice says “found there is a pgm-fi software update. Performed update and idle relearned”
shifting issues are now fixed smooth going between 2nd and 3rd gear now where before there was a shudder
Old 01-19-2019, 04:37 PM
Dereileak's Avatar
well that’s good news, what was your build date on your?
azn5ucka86
14
04-05-2004 01:17 AM
Quick Reply: RDX Hood play movement
