Question about the RDX battery?
What is the capacity of the battery? With all the electronics in this vehicle i fear the battery dying on me. In my 05 TL it happened a few times, so this is something that worries me.
I figured out how to turn the screen off and i shut off the lights as soon as I turn the car. |
Unless your battery is dying, this is not something to worry about.
It is an H6 AGM.
It is big. Powerful. And will be expensive to replace. oK? |
Thanks Madd Dog, and I think I read somewhere that it is a pretty Heavy Duty Battery due to the Auto Stop feature as it is constantly starting the car. I do not think you can replace it with just any old battery.
^well, AGM's are getting common place...
Be sure to replace it with an AGM and not a flooded battery. |
Originally Posted by lil12002
(Post 16430242)
I never had an AGM battery before. Anybody know the warning signs, or are they pretty much the same as any other battery? I learned a long time ago it's better to replace a battery a few months too early than a day too late.
Modern batteries tend to fail with little or no warning. For years, Honda's FLA batteries have been known to die as early as 2-3 years. Honda began using AGM batteries in the Pilot in 2015. There have been a few reports on a Pilot forum of them suddenly dying after 1-2 years.
This sized AGM costs more than 200 bucks.
If anyone intends to put it on a battery tender, make absolutely sure the tender says, right on it, that it is for an AGM. |
Originally Posted by zroger73
(Post 16434314)
But unless the battery is "deep cycled" by running the audio for hours with the engine off, the greatest risk to the battery may be frequent activation of the idle-stop system in stop-and-go traffic. Starting the engine draws much more current than running the electronics. |
Originally Posted by Madd Dog
(Post 16434496)
If anyone intends to put it on a battery tender, make absolutely sure the tender says, right on it, that it is for an AGM. Product details have been supplied by the Manufacturer, and are hosted by a third party. Always Ready To Gowith Battery Tender 3 Amp SuperSmart Battery Charger® & Maintainer. https://a.sellpoint.net/a/2kbdXPvY.jpg The Battery Tender® Power Plus is a 3 Amp battery charger that will fully recharge and then maintain a battery at its proper storage voltage without the damaging effects caused by trickle chargers. A higher output (3 amps) than the original Battery Tender Plus for a quicker recharge on Automotive, Marine, and Power Sport batteries combined with the automatic switch to maintenance mode makes this unit very versatile. It is an ideal charger for everyday charging use or long-term storage and maintenance. Ideal for AGM, Flooded, and Gel batteries. |
Originally Posted by Wander
(Post 16434731)
AFAIK Honda started using AGM batteries in the 2016 Pilot ( production started May/June 2015 ), and only in the upper trims that were equipped with the 9-speed ZF transmission and auto idle stop. ( I had one ). It's the frequent start/stop cycles of the idle stop system that require the AGM battery. Same deal with our RDXs. There is also an actively ventilated ( ducted and fan-cooled ) enclosure for the battery...
Also, all current-generation Pilots, Ridgelines, Odysseys, and Passports have a ducted battery box with a cooling fan like the RDX - even those without auto stop and AGM batteries. The Accord with the similar 2.0T/10AT as the RDX does not. Curiously, the battery cooling fan in these applications is not monitored, so a fan failure will not result in any lights, messages, or DTC's - decreased battery life would likely be the only symptom if the fan stopped working. |
It would like to see lithium ion car batteries come on line at a reasonable price.
Wanted to buy battery charger/starter. Looks like owner manual says to contact the dealer about instructions how to charge the battery. Do you need to disconnect the battery before charging it, or just clamp cables on top of it to charge?
Would not want to mess up electronics |
(Post 16569527)
Originally Posted by DJA123
(Post 16569537)
I have the same question/concern. I have an AGM compatible maintainer that I'd like to use. I assume it's not harmful to stay connected, but not 100% certain. There would probably be a warning if charging in place was damaging to electronics, but again, not worth the chance without certainly.
without any information, Its probably safer bet to remove negative terminal from the battery before charging it. This way if anything gets messed up, it would be just a bad battery and not car electronics. you also would hope that cheap chinese car charger will not start fire, lol |
(Post 16569551)
you also would hope that cheap chinese car charger will not start fire, lol What impact does battery disconnect have on settings, infotainment, etc.? |
I was looking at this one. Maybe battery does not need to be disconnected, after all they let you jump start your car from booster battery, so it should not harm anything (assuming its not a low quality device)
https://www.northstarbattery.com/product/nsb-agm48-l3
northstar makes some nice stuff, these batteries hold a lot of juice |
(Post 16569569)
But if for some reason you WANT to kill your vehicle electronics, just hook up an unbuffered power supply to the vehicle's battery terminals without the battery connected. That should do it. |
(Post 16569593)
https://www.amazon.com/Schumacher-SC...7945555&sr=8-8 I don't really think the battery has to be disconnected; I tend to be overly cautious with new things until I'm more familiar with how they work. |
Never had to disconnect anything to charge or maint a battery, that's what fuses are for.
There is really no need for a tender unless you intend to store the car for months without driving. I only put a tender on my motorcycle during winter months. If you are fearing battery drainage or dying, get a portable battery charger. I always have one in my car now after an incident left me waiting hours for roadside maintenance to show up (then he swipes out a battery jumper) My time is more valuable than waiting for "free" service to show up so I invested in one. Since then I've used it more than once and helped out others. Returned in investment already. |
Originally Posted by acuraada
(Post 16569745)
I too have an older power pack that we take when we go to the Outer Banks. It's great as a power supply and backup for dead battery in the middle of nowhere. |
(Post 16569745)
There is really no need for a tender unless you intend to store the car for months without driving. I only put a tender on my motorcycle during winter months. If you are fearing battery drainage or dying, get a portable battery charger. I always have one in my car now after an incident left me waiting hours for roadside maintenance to show up (then he swipes out a battery jumper) My time is more valuable than waiting for "free" service to show up so I invested in one. Since then I've used it more than once and helped out others. Returned in investment already. https://www.amazon.com/dp/B0748D8KT6..._EjUPEbVS195Y9 Also, AGM lead-acid batteries don't like old-school analog chargers designed for conventional flooded lead-acid batteries. Even if they are a respected brand like Schumacher. Get one of their modern microprocessor controlled chargers if you want one. But yeah, I mostly use mine on boats or lawn equipment. Or my old cars that are trying to become lawn decorations. But they are helpful if you manage to drain your car battery somehow, like trying to install a software update for hours without the engine running. ( Make sure the headlights aren't on! :facepalm: ). |
We winter in Florida, so I put a charger on the car that stays home. Have done that for many years and have never had a problem.
The problem is not just about starting your car. Battery that is under charged wears out a lot faster even though it can start your car. Its a good idea to have portable jump start, but you dont want your battery get to that point, it really shortens its life and these AGM batteries are not cheap.
I am going to charge my cars, with being at home and not driving or very little the battery definitely getting low on my cars |
Since the pandemic, we have been driving as well. We mostly go on short trips with our RDX, while my other just sat in the garage. I'm worried about the battery like this other people on this thread. I measured the voltage across the battery terminal while the car is off but still connected. Its 11.78 volt.
According to this, https://images.app.goo.gl/PEHE7N4SdfAFcHeFA , that's 30% charge. However, it can still start the car no problem. Can anyone check their resting voltage and reply here? |
Originally Posted by pcmcia
(Post 16573919)
(Post 16573939)
I put mine on battery tender since I drive it only once a week for 10min. Works well if you have a garage
Can you measure the voltage across the terminals with a multimeter (while the tender is not connected.)? Thanks! |
My 2019 Advance shows 12.2 VDC on the battery terminals, and the Auto Idle Stop function works as the manual describes. Keep in mind however, that the typical handyman grade voltmeter is not a lab grade device, and measurements may vary widely just because of the meters being used. My meter for instance, uses a 0-200 VDC scale, and meters of this grade typically will quote accuracy as +/- 1% of full scale, thus +/- 2 volts. That makes any comparison pretty useless without some common calibration standard for the meters. The acid test is that the AIS works or not; mine is working for now. I have driven about 200 miles in the last 45 days, all just around town, and in many intervals the car sat in the garage for several days at a time. I rarely enable the AIS, so I can't say that it worked all the time, but now that this discussion has brought up the issue, I have been leaving it enabled and it works as expected. If you use a battery tender, be certain the manufacturer specifies that it is suitable for AGM batteries.
Originally Posted by MT-RDX
(Post 16573961)
My auto start/stop hasn't work since the pandemic started. Last week, I drove about an hour, about 45 miles, mix city/highway. The auto start stop never kicked in. :( I'm thinking of getting a battery tender ( my other car needs it anyways. I had to jump it last night.). Which one is better, Noco Genius 2 ( 2 amp ) or Deltran battery tender 4amp. Both of them at $50 on Amazon now. Which is better? I read somewhere that low ampere is better for batteries. But I also read that you should use (battery capacity amp Hour )/ 10 to charge. For example, RDX battery is 70aH, so you should use 7amp to charge. Not sure which one is correct. |
I bought this one, amazon. Or you can get through costco
https://www.costco.com/battery-tende...100519712.html |
(Post 16573966)
I'm using a home depot multimeter too, but I put mine in 0-20v mode, so its a little bit better.
russianDude,
Thanks for info! I ordered the Deltran battery tender 4amp from amazon. If you don't mind, can you tell me your charging routine? I know you said you only drive 10 min per week. Do you plug it in after you drive and leave it all week until your next drive? |
While we’re on the topic, can someone point out the booster terminal to me in this pic? I haven’t had to jump my car yet, but I’m a little worried that my booster pack won’t reach between battery and the booster terminal. How do people with tenders manage? I haven’t used a tender since I had a motorcycle many years ago but I remember them having pretty short cords too.
https://cimg5.ibsrv.net/gimg/acurazi...d4e279ebb.jpeg |
(Post 16573994)
See this thread. Someone posted a page of the user manual of where the terminals are. https://acurazine.com/forums/third-g...y-dead-987196/
I was using my RDX as a donor vehicle, not the receiving vehicle, so I didn't have to connect to ground. But looking at the picture my jumper cables won't reach the ground terminal in the picture. So far away. |
Ok now I think I see it. In the diagram, it's on the other side of that hose. This pic is one I just grabbed from the internet so I don't know if it's accurate to my car or other RDXs.
https://cimg7.ibsrv.net/gimg/acurazi...3646e0d0dd.png Since it's so far away, is there another ground point that people use instead? Or is there any reason that shouldn't be done? |
(Post 16574056)
I personally would prefer a charger with a separate charge mode specific to AGM batteries only. AGM batteries are more sensitive to overcharging than flooded or gel batteries and a one size fits all setting is not ideal, for me. (Not an electronics engineer) I remember seeing something from one of the major battery makers warning against this type of "generic" charge mode. I'll post if I find it.
Originally Posted by Waetherman
(Post 16574074)
Since it's so far away, is there another ground point that people use instead? Or is there any reason that shouldn't be done? You want a good grounding point capable of safely accepting starting current and not so close to the battery that a spark when connecting could potentially ignite battery gases. Maybe someone else has found a good alternative location.. |
