Prices Paid and Offers Accepted 2019 RDX
#1562
Skeptic
#1563
- During the first 600 miles (1,000 km) of operation, avoid sudden acceleration or full throttle operation so as to not damage the engine or powertrain.
- Avoid hard braking for the first 200 miles (300 km). You should also follow this when the brake pads are replaced.
- Avoid towing a trailer during your vehicle’s first 600 miles (1,000 km).
There are no other restrictions such having to vary your speed.
#1564
wow that is a really good deal!
could you share your dealer's name and contact info? I am in the same area and I want the same model.
also, any details on what rebate they gave you? did you finance or lease or paid cash?
Thx!
#1565
I paid about $43500 including destination charge and dealer fees for AWD Advanced. This was back in November in VA. It does include 1k loyalty rebate. The price does not include DMV fees and sales tax. The OTD was exactly $45500.
#1566
Regardless, you negotiated well.
#1567
I bought via Pohanka. It took some time but was able to pull it off. Good luck! Ping me if you need more info!
#1570
The Edmunds price promise discount in the DMV area is over $5k right now. Seems like prices are coming down and you might be able to do even better than $5k off if you negotiate more.
https://www.edmunds.com/acura/rdx/
#1571
#1572
#1576
#1577
3rd Gear
Greetings,
My first post and new Member here. I have read and watched numerous reviews on this vehicle, and for the most part, they are very positive! The touchpad/infotainment not withstanding...
Couple of questions:
Will the availability of the Active Damper System on the Advance Package, be available anytime soon or is it an option to build with the A-Spec model? I prefer the appearance of the A-Spec but I have read numerous reviews touting the refinement and almost "need" for the ADS.
Those of you who chose one model over the other and experienced the suspension difference, please chime in? I am curious as to why Acura chose to omit such a great feature from the A-Spec model?
Second: What kind of pricing/discounts are you seeing/getting in the Dallas area market?
Thanks, Marcus
Thanks, Marcus
#1578
The adaptive dampers are available on the Advance trim only.
#1579
Well, actually... The non-Advance trims have "amplitude reactive dampers", which are passive devices.
#1580
3rd Gear
Thank you! That is what I meant to say. So will this be available on the A-Spec? Possibly the 2020?
#1582
Seems even the Acura writers don't know what terminology to use and when:
From the RDX product brochure:
From the RDX Fact Sheet:
And finally from the RDX Press Release:
C H A S S I S
MacPherson Strut Front Suspension • •
Multi-Link Rear Suspension • •
Amplitude Reactive Dampers • •
Adaptive Damper System A A
Dual-Pinion, Variable-Ratio Electric Power Steering (EPS) • •
Integrated Dynamics System (IDS) 4-Mode (Snow,
Comfort, Sport, Sport+)
4-Mode (Snow,
4-Mode (Snow,
Advance Package
Includes Technology Package
19-inch Medium Alloy Silver Interwoven Wheels
Height-Adjustable Power-Operated Tailgate with Hands Free Access
Acoustic Front Side Glass
Two damper types are available – Amplitude Reactive Dampers on the standard RDX, Technology Package and A-Spec, and Acura’s innovative Active Damper System on the Advance Package. All RDX grades include front hydraulic suspension bushings for improved isolation from road noise, vibration and harshness (NVH).
All grades also feature Acura’s 4-mode Integrated Dynamics System, controlled by the prominent drive mode dial on the vehicle’s center console. With Comfort, Sport, Sport+ and Snow modes, the driver can dial in the dynamic performance characteristics of the vehicle according to their desire and prevailing road conditions. The Integrated Dynamics System interacts with multiple dynamic systems in the vehicle, including the Drive-By-Wire™ throttle, Electric Power Steering, torque-vectoring SH-AWD™ (when equipped), Active Sound Control (ASC) and, on the RDX with Advance Package, the Active Damper System.
#1583
The following 2 users liked this post by MI-RDX:
Gator5000e (02-20-2019),
zroger73 (02-21-2019)
#1584
The Amplitude Reactive Dampers have two fluid paths - one more restrictive than the other. Small motions push fluid through the less restrictive path resulting in a smoother ride. Large motions push fluid through the more restrictive path resulting in a firmer ride with less body roll during quick motions. The Amplitude Reactive Dampers only firm up the suspension once sufficient suspension travel occurs - they're "passive".
The dampers used in the Adaptive Damper System have only one fluid path, but the size of the orifice through which the fluid travels is controlled externally by a computer which varies the amount of current applied to a proportional solenoid valve inside each damper. This is an active system because the amount of suspension damping is controlled is controlled not only reactively based on inputs from other sensors, but also proactively based on drive mode. The Adaptive Damper System can firm up the dampers before suspension travel occurs, they're "active".
#1586
Yep, I understand all that. What I was commenting on was the inconsistent use of descriptive terminology in the various documents published by Acura/Honda - like being at the 'sea shore' or 'ocean side' - same place, different terms. In this case one system being active/adaptive while the other is described as being reactive can muddy the waters for someone not familiar with the underlying technology.
#1587
3rd Gear
SO onto the second part of my question... "Pricing in the DFW area?" Specifically a dealer referral in Plano, Frisco area...
Feel free to send me a PM.
#1588
Ready to upgrade from my 2008 RDX. Dealer in upstate NY is quoting me $40,000 for the 2019 AWD with Tech (MSRP $43,595). Her quote includes the $1000 conquest cash I'm eligible for (we have a Honda too). Was hoping to get AAT0995's deal of $38,445, so a little disappointed. Might try a few more local dealers.
#1590
Also, for those that purchased Advance, do you think the adaptive dampers improve ride and handling significantly?
#1591
The problem with trying to match a deal posted here, if we assume that the poster is being honest with the price paid...there are SOOO many other variables...location, time of month, how much local competition that local dealer has...financing, trade ins, etc, etc, etc.
Compare a small town with one Acura dealer within a 200 mile range, with a metro area with several dealers. On the other hand, cost of doing business may be higher in a large dealer in a metro area....
There is nothing wrong with using numbers posted to get a good idea of a decent range to shoot for, but trying to match or beat a posted dollar amount may lead to disappointment.
#1592
From personal experience I can say there is a noticeable difference between Comfort, Sport and Sport+ in my Advance, and it's very noticeable on rough, choppy roads.
Speculatively you can expect the A-Spec to have a less comfortable ride and possibly better handling because of the wider, lower profile 20" wheels that carry 36psi versus 33psi for all other trims.
#1593
You're likely to get more speculation than answers to that question because, other than test drives, not many people have experience with the Advance vs. non-Advance trims. The best you can do is test drive yourself and see what you think - but if you do that make sure the tire pressures are set properly which is something many dealers overlook. Tires set at 40psi or higher (as they seem to be from the factory) significantly alter ride and handling and not for the better.
#1594
Ironically, my dealer is one that wants to sell you the nitrogen in the tires as an $ add-on.....and claimed my vehicle had it, along with the green valve stem caps (I am skeptical of the beneficial claims, and didn't agree to pay for it) but...my tires were all at 40 lbs. Hard to confirm, but I doubt the tech pumped in 40 lbs of Nitrogen in the tires, when it has been widely reported that many have found their tires to be over-inflated when they bought them.
JB in AZ (02-23-2019)
#1595
#1596
Yes. If I wanted the Nitrogen. My main point was how the dealer tried to scam me by saying the tires had nitrogen... and that costs extra. I doubt they even did anything other than change the valve stem caps to green.
securityguy (03-01-2019)
#1597
I hope you replaced the green caps. Whenever I see them on someones vehicle, I always think, "there's an easy mark!"
zroger73 (02-23-2019)
#1598
As another follow up, i visited my local Acura dealership today and my salesman said he had 3 Advances in stock Tuesday. All 3 sold by yesterday. And then he had just unloaded another one today that was going to be sold this afternoon. He can’t keep the RDX in stock. So they aren’t moving on price. I told him about some of the deals you folks are getting. Bcuz i could fly to virginia, buy from that dealer there, and then drive back and still come in cheaper than any deal he could swing.
#1599
#1600
Yep! Already replaced the caps.
