Notices
Over The Air (OTA) Software Update D.1.0.7
Old 12-12-2018, 11:21 AM
  #81
Registered Member
There is a PDF on the Acura Owners site that is essentially the same as above. It only has 3 pages. Most worrisome is that really none of the significant issues are called out in the fixes. We were forced to pull a fuse yesterday when the infotainment system emitted a loud chirp, then froze and stopped all audio. Would not shut off even after the ignition was shut off. Of course, this has happened to others, but a first for us. Carplay continues to skip during playback and often the touchpad becomes very slow to respond.
Our first service is coming due and we may have to push the dealership. I hope this update resolves the issues that we and other have seen.
cengel is offline
Old 12-12-2018, 11:37 AM
  #82
Registered Member
No Android Auto,
no fix for the SMS Message Notification "Screech"
no fix for the "Your device is not connected" when AcuraLink is showing as connected on your phone and music is playing via Bluetooth from your phone.
Looks like this was a fix for Apple Carplay issues and not a whole lot for Android users.
*sigh*
Newsy1904 is offline
Old 12-12-2018, 11:38 AM
  #83
Registered Member
Madd Dog's Avatar
Anyone do it yet?
If so, how long did it take, and done by wifi or usb?
Madd Dog is offline
Old 12-12-2018, 11:48 AM
  #84
Registered Member
Can't do it. Tried for the last 30 minutes but all I get is that my software is up to date. Looks like it can only be done using WI-FI connection , and the car sees my home router and says its connected and the allow updates using this connection is set to "allow". So I'm giving up for the time being.
mrblase is offline
  #85
Registered Member
Nothing yet...
jonarogers is offline
Old 12-12-2018, 12:13 PM
  #86
Registered Member
catbert430's Avatar
^^^ I got this as well when trying USB update.
catbert430 is offline
Old 12-12-2018, 12:21 PM
  #87
Registered Member
I still believe you can update either way (WiFi of USB) but the update hasn’t been made available yet via either method.
Midwestuser1 is offline
Old 12-12-2018, 12:23 PM
  #88
Registered Member
The write up I just pulled from the owner's site says that the new software version is D.1.0.7 which I believe is on vehicles manufactured in the early fall time frame and later. So if this fits you, then there would be no new software. I would expect that the earlier built vehicles will soon have the opportunity to move to this level when everything is set up and that is really the only audience for this upgrade. I think the older level is D.1.0.4. Am I missing something on this?
gtssenior is offline
Old 12-12-2018, 12:31 PM
  #89
Registered Member
disappointed
thanks for nothing Acura !!!!
nyr726 is offline
dukeh62 (12-12-2018)
Old 12-12-2018, 12:46 PM
  #90
Registered Member
I know it stinks but I know I don’t want to be the one that has it crash my system. If they are verifying the update works properly via dealer vehicles first then I’m O.K. With that.
  #91
Registered Member
Madd Dog's Avatar
I got the same ‘no update’ as did jonarogers, and my build is 1.0.4
Madd Dog is offline
Old 12-12-2018, 12:47 PM
  #92
Registered Member
false hope as they should be doing proper QA before releasing the update. They shouldn't/can't rely on dealers for testing as it involves actual cars
Coolguy is offline
Old 12-12-2018, 12:59 PM
  #93
Registered Member
i69fstop's Avatar
Hi gtssenior, you are correct, mine was at D.1.0.7 weeks ago!!!!
i69fstop is offline
Old 12-12-2018, 01:07 PM
  #94
Registered Member
catbert430's Avatar
My car is definitely version 1.0.4 built in May.
Old 12-12-2018, 01:16 PM
  #95
Registered Member
Same with me and my car was built before the June introduction.
mrblase is offline
Old 12-12-2018, 01:26 PM
  #96
Registered Member
i69fstop's Avatar
Please use and connect to WIFI at home (RDX wifi support both 2.4 ghz and 5 ghz band) , that was how my system got updated
i69fstop is offline
Old 12-12-2018, 01:46 PM
  #97
Registered Member
My car is showing an update available but I have not tried to update it. I hope someone updates their by the time I get home later today.
Hou-RL is offline
Old 12-12-2018, 01:47 PM
  #98
Registered Member
Hey just a quick question. Since you are on the latest version, have you had any issues with it locking up with Apple Car Play?
HuKaShI is offline
Old 12-12-2018, 01:50 PM
  #99
Registered Member
MI-RDX's Avatar
Here's the PDF on the owners site - pretty much says the same that posted originally with a couple additional comments that the update will take about 30 minutes and the vehicle can be used normally while it's happening (could be a problem if you're updating via your home router and want to go anywhere).
MI-RDX is offline
Old 12-12-2018, 01:57 PM
  #100
Registered Member
i69fstop's Avatar
I am using android, but I connected to my friend's Iphone X a couple of time, I don't experience any issue (know that I didn't really intentionally test it)
I've experience disconnecting phone call on android phone a couple time though, then it takes ,3-5 second, then it reconnected again.
i69fstop is offline
Old 12-12-2018, 02:03 PM
  #101
Registered Member
update complete
just finished updating mine from 1.0.4 to 1.0.7 via Wi-Fi no issues updating. took about 10 minutes to complete haven't seen any changes as of yet. please post if anyone who has updated sees any changes other than iPhone issues thanks.
nyr726 is offline
The following 2 users liked this post by nyr726:
i69fstop (12-12-2018), MI-RDX (12-12-2018)
Old 12-12-2018, 02:08 PM
  #102
Registered Member
I also just got an email stating in the subject “A software update is available for your 2019 RDX”. Going to do it now via WiFi.
Old 12-12-2018, 02:10 PM
  #103
Registered Member
MI-RDX's Avatar
Just this minute got my email as well.
MI-RDX is offline
Old 12-12-2018, 02:11 PM
  #104
Registered Member
MI-RDX's Avatar
Did you have the engine running, ignition on but engine not running, or accessory mode?
MI-RDX is offline
Old 12-12-2018, 02:28 PM
  #105
Registered Member
Stew4HD's Avatar
Received 1,015 Likes on 668 Posts
Still no Android Auto?
Stew4HD is offline
Old 12-12-2018, 02:40 PM
  #106
Registered Member
Still not quite sure how I'm supposed to do that when my home WiFi is several stories above my parking spot in the underground parkade. Guess I'll be parking outside Starbucks or Timmy's if they don't get the USB update sorted soon (assuming they ever release the update for us Canuckistanis; I've seen no reports of such here yet).
HillbillyInBC is offline
Old 12-12-2018, 02:41 PM
  #107
Registered Member
Got an email for software update availability.
Coolguy is offline
Old 12-12-2018, 02:48 PM
  #108
Registered Member
Boltface's Avatar
Got the email saying that a software update is available for my RDX but the RDX says no update available. I was already at 1.0.7.
Of course there's no reason for Acura to know what level of software I have they just built the thing.
Today somehow my wife got into a can't do anything mode trying to listen to FM, no FM no nothing, frozen.
Now FM is gone from the home screen and will not return no matter how many times I try.
Boltface is offline
Old 12-12-2018, 03:03 PM
  #109
Registered Member
tried factory reset ?
Coolguy is offline
  #110
Registered Member
Same here. Came home and system said an update was available. Engine does not need to be running and it took about 10 minutes as well.
mrblase is offline
  #111
Registered Member
Got the email. Downloaded and prepared, just did the "Update while turned off". I am going to the gym and will check it when I am back. I am also filming for a video of the update process on my Youtube channel. will post a link when that is up.
fligster is offline
Old 12-12-2018, 03:05 PM
  #112
Registered Member
TheFidge's Avatar
I just did the update through wi-fi with the car running. Downloading, preparing, and installing took 20-30 minutes. It froze once when it started to install so I had to reboot, then it worked. It installed, but have not had a chance to see if things are fixed or worse..... time will tell.
TheFidge is offline
Old 12-12-2018, 03:16 PM
  #113
Registered Member
I updated 1.04 to 1.07. 10 minutes on wifi, said update failed with an error code but update went through.
I see nothing worth it, no features, and the one bug I tested (that the pdf doc says is fixed) is sending a map to the car (when off)... still does not work. No AA.
I am disappointed.
rdxny is offline
Old 12-12-2018, 03:25 PM
  #114
Registered Member
Boltface's Avatar
If you mean the three button....., yes no luck.
Boltface is offline
Old 12-12-2018, 03:30 PM
  #115
Registered Member
Not saying this is your case, but the same thing happened to me a few weeks ago, and it resulted in the car being at the dealer for the last 16 days getting the Infotainment system replaced. Again, I'm not saying that's what's in store for you...let's hope not.
Did you try disconnecting the battery and/or pulling the fuse?
dukeh62 is offline
Old 12-12-2018, 03:31 PM
  #116
Registered Member
Did the OTA update fix the brake squeal? 🤣
Njbrandon is offline
zroger73 (12-12-2018)
Old 12-12-2018, 03:35 PM
  #117
Registered Member
not only break squeal but the wide body gaps too
Coolguy is offline
Old 12-12-2018, 03:39 PM
  #118
Registered Member
Boltface's Avatar
No, which fuse is that?
Boltface is offline
Old 12-12-2018, 03:46 PM
  #119
Registered Member
HUGE disappointment. This update just brings me up to the current level of frustration with the Infotainment system. The promise of a “couple months” for Android Auto back in May is now looking like a year. Nav system still can’t show me more than a couple blocks around me. Hope this update helps some of those with more serious infotainment problems.
Jeffro941 is offline
Old 12-12-2018, 03:48 PM
  #120
Registered Member
kboo74656's Avatar
Talking
Got the emails saying there was an update for mine. After checking the software version noticed I am already on 1.0.7. No update needed. Oh well now I'm waiting for the next map update from HERE early next year. Time to have some Crown Apple!!!
kboo74656 is online now
Quick Reply: Over The Air (OTA) Software Update D.1.0.7
