There is a PDF on the Acura Owners site that is essentially the same as above. It only has 3 pages. Most worrisome is that really none of the significant issues are called out in the fixes. We were forced to pull a fuse yesterday when the infotainment system emitted a loud chirp, then froze and stopped all audio. Would not shut off even after the ignition was shut off. Of course, this has happened to others, but a first for us. Carplay continues to skip during playback and often the touchpad becomes very slow to respond.
Our first service is coming due and we may have to push the dealership. I hope this update resolves the issues that we and other have seen. |
No Android Auto,
no fix for the SMS Message Notification "Screech" no fix for the "Your device is not connected" when AcuraLink is showing as connected on your phone and music is playing via Bluetooth from your phone. Looks like this was a fix for Apple Carplay issues and not a whole lot for Android users. *sigh* |
Anyone do it yet? If so, how long did it take, and done by wifi or usb? |
Can't do it. Tried for the last 30 minutes but all I get is that my software is up to date. Looks like it can only be done using WI-FI connection , and the car sees my home router and says its connected and the allow updates using this connection is set to "allow". So I'm giving up for the time being.
Nothing yet...
https://cimg0.ibsrv.net/gimg/acurazi...75782b9f0a.jpg |
^^^ I got this as well when trying USB update.
Originally Posted by mrblase
(Post 16348683)
Originally Posted by catbert430
(Post 16348705)
disappointed
thanks for nothing Acura !!!!
Originally Posted by nyr726
(Post 16348724)
I got the same ‘no update’ as did jonarogers, and my build is 1.0.4 |
false hope as they should be doing proper QA before releasing the update. They shouldn't/can't rely on dealers for testing as it involves actual cars
Originally Posted by gtssenior
(Post 16348717)
The write up I just pulled from the owner's site says that the new software version is D.1.0.7 which I believe is on vehicles manufactured in the early fall time frame and later. So if this fits you, then there would be no new software. I would expect that the earlier built vehicles will soon have the opportunity to move to this level when everything is set up and that is really the only audience for this upgrade. I think the older level is D.1.0.4. Am I missing something on this?
https://cimg5.ibsrv.net/gimg/acurazi...4be22259ea.png |
(Post 16348717)
Originally Posted by Madd Dog
(Post 16348751)
(Post 16348777)
Same with me and my car was built before the June introduction.
My car is showing an update available but I have not tried to update it. I hope someone updates their by the time I get home later today.
Originally Posted by i69fstop
(Post 16348792)
Please use and connect to WIFI at home (RDX wifi support both 2.4 ghz and 5 ghz band) , that was how my system got updated
1 Attachment(s)
Here's the PDF on the owners site - pretty much says the same that posted originally with a couple additional comments that the update will take about 30 minutes and the vehicle can be used normally while it's happening (could be a problem if you're updating via your home router and want to go anywhere).
Originally Posted by HuKaShI
(Post 16348828)
Hey just a quick question. Since you are on the latest version, have you had any issues with it locking up with Apple Car Play?
I've experience disconnecting phone call on android phone a couple time though, then it takes ,3-5 second, then it reconnected again. |
update complete
just finished updating mine from 1.0.4 to 1.0.7 via Wi-Fi no issues updating. took about 10 minutes to complete haven't seen any changes as of yet. please post if anyone who has updated sees any changes other than iPhone issues thanks.
(Post 16348842)
Originally Posted by Midwestuser1
(Post 16348848)
I also just got an email stating in the subject “A software update is available for your 2019 RDX”. Going to do it now via WiFi. |
(Post 16348842)
Still no Android Auto?
(Post 16348792)
Got an email for software update availability.
Got the email saying that a software update is available for my RDX but the RDX says no update available. I was already at 1.0.7.
Of course there's no reason for Acura to know what level of software I have they just built the thing. Today somehow my wife got into a can't do anything mode trying to listen to FM, no FM no nothing, frozen. Now FM is gone from the home screen and will not return no matter how many times I try. |
Originally Posted by Boltface
(Post 16348878)
(Post 16348842)
Got the email. Downloaded and prepared, just did the "Update while turned off". I am going to the gym and will check it when I am back. I am also filming for a video of the update process on my Youtube channel. will post a link when that is up.
I just did the update through wi-fi with the car running. Downloading, preparing, and installing took 20-30 minutes. It froze once when it started to install so I had to reboot, then it worked. It installed, but have not had a chance to see if things are fixed or worse..... time will tell.
I updated 1.04 to 1.07. 10 minutes on wifi, said update failed with an error code but update went through.
I see nothing worth it, no features, and the one bug I tested (that the pdf doc says is fixed) is sending a map to the car (when off)... still does not work. No AA. I am disappointed. |
Originally Posted by Coolguy
(Post 16348885)
tried factory reset ?
(Post 16348878)
Of course there's no reason for Acura to know what level of software I have they just built the thing. Today somehow my wife got into a can't do anything mode trying to listen to FM, no FM no nothing, frozen. Now FM is gone from the home screen and will not return no matter how many times I try. Did you try disconnecting the battery and/or pulling the fuse? |
Did the OTA update fix the brake squeal? 🤣
not only break squeal but the wide body gaps too
Originally Posted by dukeh62
(Post 16348906)
Not saying this is your case, but the same thing happened to me a few weeks ago, and it resulted in the car being at the dealer for the last 16 days getting the Infotainment system replaced. Again, I'm not saying that's what's in store for you...let's hope not.
HUGE disappointment. This update just brings me up to the current level of frustration with the Infotainment system. The promise of a “couple months” for Android Auto back in May is now looking like a year. Nav system still can’t show me more than a couple blocks around me. Hope this update helps some of those with more serious infotainment problems. |
Got the emails saying there was an update for mine. After checking the software version noticed I am already on 1.0.7. No update needed. Oh well now I'm waiting for the next map update from HERE early next year. Time to have some Crown Apple!!!
