Notices
Over The Air (OTA) Software Update D.1.0.7
Old 12-24-2018, 06:02 PM
  #361
Registered Member
OK...so I just went out into the driveway to play with the Acuralink function after Madd Dog post. I unpaired my phone and then repaired it. Then reconnected to Acuralink and all is updating just fine now. Why can't Acura just tell you to do that???
securityguy is offline
Old 12-24-2018, 06:51 PM
  #362
Registered Member
I have done that twice and mine is still not working. I guess I must be sitting in the car wrong, maybe I will try the back seat.
Billy
billyt1963 is offline
The Following 2 Users Say Thank You to billyt1963 For This Useful Post:
securityguy (12-24-2018), zroger73 (12-25-2018)
Old 12-24-2018, 07:09 PM
  #363
Registered Member
I think we owe Madd Dog a bone.
Wander is offline
The Following User Says Thank You to Wander For This Useful Post:
Madd Dog (12-24-2018)
Old 12-24-2018, 07:41 PM
  #364
Registered Member
Madd Dog's Avatar
When you say you reauthorized it on the app and in the car, what exactly did you to? Thanks
on the app, Support, Vehicle Data Collection: Allow.
in the car, Acuralink Icon: Allow. data collection.
Next time I ran the car, it showed on the app.
Madd Dog is online now
The Following 3 Users Say Thank You to Madd Dog For This Useful Post:
97ws6 (12-24-2018), billyt1963 (12-26-2018), securityguy (12-24-2018)
Old 12-24-2018, 07:44 PM
  #365
Registered Member
Madd Dog's Avatar
Billy
Did you run the car?
Someone pointed out that the link updates when the car is turned off.
The Following User Says Thank You to Madd Dog For This Useful Post:
97ws6 (12-24-2018)
Old 12-25-2018, 06:49 AM
  #366
Registered Member
So it turns out the part I was missing was allowing the car to share data. When I did that last night, the numbers started updating.
Thanks MADD Dog for the tip on that part. I knew I was misssing/forgetting something.
I hope everyone has a Merry Christmas.
Billy
The Following User Says Thank You to billyt1963 For This Useful Post:
Madd Dog (12-25-2018)
Old 12-26-2018, 10:43 AM
  #367
Registered Member
So it seems the update may not worth the actuall effort to update unless you are having issues. I will update later after all others have worked through the issues.I tend to delay on updates and I want to see what issues occur.
Hou-RL is offline
Old 12-26-2018, 03:27 PM
  #368
Registered Member
Meto's Avatar
The current update is the only release that will happen until after the holidays are over as Acura completely shuts down during this time. I would recommend not installing 1.07 if you use USB at all.
Meto is offline
Old 12-26-2018, 03:52 PM
  #369
Registered Member
Still issues after update
Im still having problems with CarPlay after the recent update. Songs will stutter occasionally, iPhone will disconnect and reconnect occasionally. Also my right screen always defaults to the Acura map on start up no matter what I left it on when I shut the car down. Just curious if anyone else is experiencing these same issues?
Catman70 is offline
Old 12-26-2018, 05:04 PM
  #370
Registered Member
MI-RDX's Avatar
Originally Posted by Meto View Post
...I would recommend not installing 1.07 if you use USB at all.
What USB issues are you having? I use it more than any other audio source and haven't experienced any issues at all - with 1.0.7 or 1.0.4 before it.
MI-RDX is offline
Old 12-26-2018, 05:17 PM
  #371
Registered Member
kboo74656's Avatar
For the Car Play issue try letting the infotainment system boot up completely and have your phone unlocked before plugging it in. I find that I don’t have any issues with car play when I do this. As for the small screen always booting up to the nav it’s not a problem, it’s just the way it was programmed to work. Mine does it also.
kboo74656 is offline
The Following User Says Thank You to kboo74656 For This Useful Post:
securityguy (12-28-2018)
Old 12-28-2018, 08:57 AM
  #372
Registered Member
I really have no issue with the 1.0.4 and the RDX wifi was setup since day 1, so by the time that I decided to update to 1.0.7, at around 12/15, it was already updated at step 5 of 6 and finished the update with no issue.
Issues:
1. When changing channels using the thumb wheel one day, I've got the "car change mode not available" and the screen started dimming and brighten up randomly with navigation working off and on and XM radio slow responding to change channel and adjust volume using the steering wheel controls. Later on, the touch pad was on/off randomly and finally got the Android keyboard failed message. Quick turning off engine, opened the door and restart the engine did not fix this issue, but touring off the card, exited , wait for 20 minutes. and restart solved the issue.
2. When changing XM favorites using the thumb wheel, the dash showed "system unavailable" message and did not change channel. this happened twice already and if I get out of XM and go back to it, it would be working fine.
When these happened, the system had a USB drive connected and the phone is not paired nor connected to the system.
subin is offline
Old 12-28-2018, 10:13 AM
  #373
Registered Member
beancount1's Avatar
Issues:
I'm having a similar issue with the apps wheel where it doesn't work much of the time and get the "system unavailable" error. I spoke with Acura yesterday and they recommended doing a hard reset of the system. I haven't taken the time to try that yet. Unfortunately it means losing all settings and having to reset phone, radio/sirius stations etc. I'll let you know if that works.
beancount1 is offline
Old 12-28-2018, 11:30 AM
  #374
Registered Member
TheLevelOne's Avatar
Happens when I'm using XM. I switch XM to the main screen and choose one of my favs on the bottom area. Wheel works as expected after that.
Regards --------------------
TheLevelOne is offline
The Following User Says Thank You to TheLevelOne For This Useful Post:
beancount1 (12-28-2018)
Old 12-28-2018, 06:11 PM
  #375
Registered Member
Havasubum's Avatar
Since updating with the OTA version 1.0.7, I cannot use SIRI on my iPhone. I tried using SIRI via my handheld device. It starts to answer my question and then immediately stops. I have also tried via the "long press" on the steering wheel button. I receive the tone, but immediately shuts down. I also noted that my iPhone had loaded my calendar, showing all months of 2018 after driving for a while with the phone paired. I never view my calendar in this mode. I am beginning to seriously regret buying this car. I have never owned a car with so many problems.
Havasubum is offline
Old 12-28-2018, 08:46 PM
  #376
DWG
Registered Member
We have had this happen a few times. Powering the stereo off and on with the power button on the left side of the steering wheel has resolved the issue.
DWG is online now
The Following User Says Thank You to DWG For This Useful Post:
subin (12-31-2018)
Old 12-29-2018, 08:29 AM
  #377
Registered Member
factory default reset
Should have tried this first, but was lazy...
Anyway, I just reset to factory default and I also will report back if this makes a difference.
subin is offline
Old 12-30-2018, 08:16 AM
  #378
Registered Member
So, it happened again after the factory reset. This time, it was about three minutes after I started the engine and driving, the steering wheel's volume adjuster (up/down), with navigation on the big screen and XM on the right, the volume adjuster stopped responding, but I was able to change favorites with the thumb wheel. I was also able to adjust the volume using the knob on the dash. When this happened, I noticed the arrow, which indicates the current location, on navigation was flashing and rotating, but it was not on the street that I was driving (it was about half inch to the right). I then tried to turn off the audio from the steering wheel's on/off button, the screen showed option to turn off and I tried to use the up/down button on steering to select it, but that did not work. Then, I pressed the audio on/off button again on the steering wheel and everything was working again.
Keep in mind that I had no issue like this with 1.0.4. The strange issues that I am experiencing seem to be related to navigation not getting the signal or acting strange.
subin is offline
Old 12-30-2018, 06:33 PM
  #379
Registered Member
Still...knock on wood, we have yet to experience any failures with our head unit as several of you have posted above. What we do experience is that loading time for the updated version does take longer than the previous version and the spinning loading wheel appears for a far greater time than in the past.
The Following User Says Thank You to securityguy For This Useful Post:
markm929 (12-30-2018)
Old 12-31-2018, 07:56 AM
  #380
Registered Member
So, this happened twice yesterday when starting the car with the navigation at the big screen and XM on the right and powering off/on from the steering wheel does fix the issue. I am not setting the XM to the big screen and navigation to the right and see if that could avoid this issue.
subin is offline
Old 12-31-2018, 06:38 PM
  #381
Registered Member
The problem with XM is widespread.
my dealer advised there are at least two if not three more updates do out to continue fixing these problems.
Lets hope so.
Bartrdx is offline
Old 12-31-2018, 06:44 PM
  #382
2019 Ridgeline RTL-E
zroger73's Avatar
Lets hope so.
Oh good gravy - they're just making that up.
I finally had enough of my RDX and went back to a simpler Ridgeline. I never had any problems like this with my last Ridgeline. Shame on me for trading it in! That was an expensive mistake. What was I thinking to believe that Acura would be better assembled and have fewer software issues?
zroger73 is offline
Old 01-01-2019, 01:10 AM
  #383
Registered Member
Yep. Just making it up.
But holy crap. Did you trade in the RDX for another Ridgeline? You change cars more often than I change my underwear!
Having said that, good luck with your new ride.
Wander is offline
zroger73 (01-01-2019)
Old 01-01-2019, 09:02 AM
  #384
Registered Member
So, this happened twice yesterday when starting the car with the navigation at the big screen and XM on the right and powering off/on from the steering wheel does fix the issue. I am now setting the XM to the big screen and navigation to the right and see if that could avoid this issue.
I know it only has been a day, but it appears that the issue only happens when setting the Navigation on the big screen and XM on the right. Again, powering off/on the radio fixes the issue.
To me, this is a small bug and will report to the dealer at the first service.
subin is offline
Old 01-01-2019, 09:09 AM
  #385
Registered Member
subin ...don't report it to your dealer as nothing will ever happen. Call Acura and create a case so that it, hopefully, gets to the right place where they will take it seriously and look into it.
subin (01-02-2019)
Old 01-02-2019, 11:53 AM
  #386
Registered Member
Yotrek's Avatar
Any Canadian here know if we are getting this update or not?
Yotrek is offline
Old 01-02-2019, 12:53 PM
  #387
Registered Member
Yotrek, I am on 1.0.4 and have not seen anything on the screen asking me to update.
Lets hope soon.
DavidH
DHood is offline
Old 01-03-2019, 09:57 AM
  #388
Registered Member
Yotrek's Avatar
Lets hope soon.
DavidH
Sucks not knowing whether we are getting the update or not, David..
Yotrek is offline
Old 01-03-2019, 01:38 PM
  #389
Registered Member
You mean it sucks that you don't get to trade one set of bugs for a slightly different set of bugs? I'm hoping for an update to the update.
But in the meantime, I'm just driving the thing.
Wander is offline
Old 01-03-2019, 03:42 PM
  #390
Registered Member
Angry
Agreed! I like the way the RDX handles, looks & many of its features but Honda/Acura really missed the mark for its new info system. The bugs, glitches & quirks has left me with a bad taste in my mouth to buy another Acura. This is my 3rd Acura & 2nd RDX. If they don't make the thing work correctly by early 2019 they've lost me. If they don't add in the features that inexpensive off the shelf GPS's have I'm sure they will loose many others as well. GREAT CAR BUT HORRIBLE INFO SYSTEM !!
Mark S Long Island is offline
The Following 2 Users Say Thank You to Mark S Long Island For This Useful Post:
Havasubum (01-03-2019), zroger73 (01-05-2019)
Old 01-03-2019, 04:26 PM
  #391
Registered Member
beancount1's Avatar
All very true. I've already written Acura to complain about the poor Nav system, but are there any rumors that they actually plan on modifying the nav to include features and user friendliness normally found on an inexpensive portable gps? Not that I've heard.
Old 01-03-2019, 04:35 PM
  #392
Registered Member
And still no Android Auto (which some of us care about).
Sounds is offline
The Following User Says Thank You to Sounds For This Useful Post:
pilozm (01-10-2019)
Old 01-04-2019, 11:28 AM
  #393
Registered Member
Any way to roll back the update?
acelow is offline
Old 01-04-2019, 11:35 AM
  #394
Registered Member
No. Once itís done itís done!
Old 01-04-2019, 12:39 PM
  #395
Gen3 RDX Owner
Angry Still nothing for Canadian Owners
I'm at 1.0.4 and have been trying to check for update for like a week. RDX always tells me there's no update available
BILFFF is offline
Old 01-04-2019, 12:42 PM
  #396
Gen3 RDX Owner
Angry
Lets hope soon.
DavidH
Nothing for me yet, 1.0.4 in Canada
BILFFF is offline
Old 01-05-2019, 07:30 AM
  #397
Registered Member
For those waiting on 1.0.7 I wouldnít really recommend you install it. I didnít have any noteworthy issues with 1.0.4, but since updating it has broken Siri, my iPhone app is pretty unreliable, and I had my first system freeze (where it refused to shut off). I spoke with Acura support yesterday and they acknowledged they have heard a number of Siri complaints and were looking into app issues for me. Hold tight - they seem to be trying to fix things, they are just slow.
Colin Whooten is offline
The Following User Says Thank You to Colin Whooten For This Useful Post:
BILFFF (01-09-2019)
Old 01-05-2019, 07:36 AM
  #398
Registered Member
Several weeks ago I updated from 1.04 to 1.07 as many other did. Now I have a message in my Acuralink App. It is dated 1/1/2019 and it says System Update 18503.1 (A1806432). New Version D.1.0.7. When I first saw this I was hoping it was a further update to at least fix the broken steering wheel Siri connection. But nobody else has mentioned it so I have a feeling it is just old news about the update I installed in early December. Did anyone else get this notice on there Acuralink App? Is is new or just a repeat?
RDXguy is offline
Old 01-05-2019, 07:42 AM
  #399
Registered Member
I have gotten the same message in the app, just had not said anything.
Tried to run system update and it says nothing is available.
Billy
Old 01-05-2019, 08:44 AM
  #400
Registered Member
update message from AcuraLink
Yes, I have got the same message, but I already have 107.
I have setup the RDX wifi to connect to my home internet, so by the time I went to the system update on the infotainment, it was already in the process of update at step-5 out of 6.
subin is offline
Quick Reply: Over The Air (OTA) Software Update D.1.0.7
