Notice a difference between comfort and sports mode?
Does anyone notice any difference? I can’t seem to tell? I can tell the difference between comfort and sports + the acceleration and dampers setting but nothing on sports mode? The acura website doesn’t say much either.
It's in the owner's manual
Sport+: Adds to Sport to allow for increased performance by enhancing throttle response and changing the shift map.
Sport: Enhances vehicle response feel through decreased steering assist, heightened throttle response, increased SH-AWD* torque bias, and modified active sound control.
Comfort: Maximizes driver comfort through increased steering assist.
Snow: Use when driving on snowy road surfaces.
anoop (05-18-2019)
If you can't tell, you are babying your RDX too much
The difference between comfort and sport is much more subtle the the difference between sport and sport+, I wish they would of made sport just a tab more aggressive
And I wish that I can default the system to Sport + mode since that is the mode I ALWAYS drive in.
^As Duke mentioned above, for me the key differences between Comfort vs. Sport are steering feel and cabin noise. Comfort has a looser steering which means you have some more play, but makes it easier to make U-turns. In Sport it's a bit 'heavier' so you have to do a little more work to make u-turns but the plus is you don't need to make as many fine tuning steering adjustments as you drive. Noise wise, it is noticeably quieter for me in Comfort. No added engine noise as you would hear in Sport.
D/S Shift
So pushing the D/S Shift Button a second time puts the tranmission into "Sequential Mode" and allows you change gears manually by using the Paddle Shifters. That is not the same as putting your vehicle into Sport Mode using the Dial. The Sport Mode on the Dial makes adjustments to the Gear Ratio, the Steering (tighter), and Engine Performance/Turbo and also the tightens the Suspension up.
Skeptic
The manual is really not clear on how D/S relates to each driving mode. There really should be a more comprehensive description of each mode and how the Drive and Sequential operation is different in each of them. To be honest, I still haven't figured it all out.
I'd also like the current gear to be displayed ALL THE TIME, in all modes, not just when I use the paddles.
alpine909 (05-17-2019)
Something like that. You can use the paddle shifters any time but it will revert to automatic operation within a certain time depending on the driving mode. In Sport + / Sequential, it appears to me that once you use a paddle shifter, it will remain in manual (i.e., you must uses the shfters) indefinitely unless you switch the tranny back to D.
Alias1431 (05-17-2019)
I find comfort too lethargic in terms of throttle response. The steering also feels a little loose. So, yes, I can tell the difference and I'm glad that is remains in sport mode once set to that, and I don't have to do it each time the car is started.
I haven't noticed that much difference in the transmission between Comfort and Sport but switching to Sport+ at 130kph increases the RPM by 2-300 suggesting the 10th gear isn't in use in Sport+.
Expanse me
look here and search for 'automatic modes'
https://acuranews.com/acura-automobi...-rdx-press-kit
you are right. S+ stops at 8th gear.
So, "D" gives you 10 gears and "S" gives you 8.
I did search repeatedly through that document and did find what Comfort/Sport/Sport+ affect except number of gears. Perhaps I missed it.
But I do agree that Sport+ does use less than 10 gears.
If I could create my own custom Mode it would be: Sport+ mode for the first 3 gears. Then switch to Sport mode.
babyduke
3G MDX (2014-2020)
04-10-2017 01:19 AM
robocam
06-12-2009 05:55 AM
VanyDotK
09-30-2003 09:42 PM
ferrari527
08-05-2003 04:00 PM
