Notices
Missing door hinges lubricant ?
Old 05-09-2019, 10:01 AM
Registered Member
Not sure if its only my ride but I am not seeing any door hinges lubricated. Is it by design or they simply missed it?
Coolguy is offline
Old 05-09-2019, 10:41 AM
Received 5,846 Likes on 4,687 Posts
is it making noise?
thoiboi is offline
Old 05-09-2019, 10:48 AM
Registered Member
aIRpeACE's Avatar
Wd40
aIRpeACE is offline
Old 05-09-2019, 11:42 AM
ceb
Registered Member
Received 1,172 Likes on 871 Posts
Originally Posted by aIRpeACE View Post
Wd40
Bad idea. Use a proper lubricant
ceb is offline
NooYawkuh (05-09-2019)
Old 05-09-2019, 11:43 AM
totally agreed.
White lithium grease is my go to for door hinges.
thoiboi is offline
The following 2 users liked this post by thoiboi:
Coolguy (05-09-2019), NooYawkuh (05-09-2019)
Old 05-09-2019, 12:01 PM
Registered Member
NooYawkuh's Avatar
WD-40 is not good for anything except removing water and moisture, short term. Left alone over time, it coagulates into a sticky, gummy coating that attracts dust, grit and does not lubricate or repel moisture. For example, if you drop your gun in the water or you get caught out in the rain while hunting, spray it down with WD-40. But, ASAP, do a thorough clean and lube with [your solvent and lube of choice].
NooYawkuh is offline
Old 05-09-2019, 12:05 PM
Registered Member
Originally Posted by thoiboi View Post
is it making noise?
I hear slight grinding noise
Coolguy is offline
Old 05-09-2019, 12:09 PM
Registered Member
thanks all for suggestions ..
But the main question is, do you guys see grease or lubricant on your RDX hinges ?
Coolguy is offline
Old 05-09-2019, 12:27 PM
Registered Member
Mine didnít have any and I had some reddish rust look starting to form over the winter, but i put some of this grease on them now and they seem fine, my only worry with this type of grease is sand and debris getting stuck in it and wearing into the metal
Itís a
  • NLGI #2 GC-LB lithium complex EP grease
https://shop.advanceautoparts.com/p/...rchTerm=Grease
Dereileak is offline
Old 05-10-2019, 11:11 PM
Registered Member
I noticed this a while back and lubricated them this evening before seeing this thread. The doors didn’t open smoothly and made a slight scraping noise. Much better now
FrankZZR is offline
Old 05-10-2019, 11:29 PM
Registered Member
Mine also did not have any and I greased them up myself, although there was no noticeable noise.
subin is offline
Savio
1G TSX Problems & Fixes
05-09-2019 01:31 PM
wolftag
Third Generation TL (2004-2008)
08-13-2005 12:55 PM
Elephantman_nosefacehead
First Generation TSX Discussion (2004-2008)
07-12-2005 01:53 PM
Eskimo
Second Generation TL (1999-2003)
05-17-2004 02:53 PM
JasonT
Second Generation CL Discussion (2000-2003)
12-10-2001 01:39 PM
Quick Reply: Missing door hinges lubricant ?
