Go Back  AcuraZine - Acura Enthusiast Community > AcuraZine RDX Community > Third Generation RDX (2019+)
Reload this Page >
massive hesitation on acceleration after braking is driving me NUTS !!
Notices
Old 05-29-2019, 11:59 AM
  #41
Registered Member
Madd Dog's Avatar
Originally Posted by Yotrek View Post
traction control ON or OFF?
Everything set to normal. Comfort mode, trans in D traction on, just like a regular daay out driving.
Madd Dog is offline
Old 05-29-2019, 01:06 PM
  #42
Registered Member
Laggy transmission, stays in a higher gear too long while slowing down. As someone else posted, I manually downshift 2 gears and acceleration isn't laggy. And totally agree, we shouldn't have to adjust for the transmission manually, less than ideal tuning by Acura.
markm929 is offline
Old 05-29-2019, 02:18 PM
  #43
Registered Member
it could also be, specially in low gear..you notice people that like to launch or drag race their car that equipped with traction control, first thing they did is to disable the traction control..just saying..
But that's because the traction control will dial back engine output and/or selectively apply wheel braking when it senses wheel-spin. And then that darn Porsche will get ahead of you.
In the situation we're discussing, engine output is ZERO for an uncomfortably long period of time, so wheel-spin isn't a factor. I'd be happy for some wheel spin, as long as it's in the right direction. Beats getting swung around by a semi.
Wander is offline
Old 05-29-2019, 06:47 PM
  #44
Registered Member
I manually downshifted after slowing down getting ready to accelerate and it showed 4th gear! This seems to be the cause of the laggy throttle response because it's in too high of a gear to accelerate. Mine was trying to accelerate from 4th causing it to bog down, unless I manually dropped it a few gears every time I come to a stop. Just another RDX quirk to deal with...
Njbrandon is offline
Old 05-30-2019, 07:29 PM
  #45
Registered Member
spinedoc777's Avatar
Originally Posted by Wander View Post
A twist of the Big Chrome Knob to "Sport+ Dynamic Mode" will eliminate most of that hesitation. Or a push on the D/S transmission button to put the transmission into "S mode".
Either approach is readily reversible when conditions change, which is good cuz IMO it's way too buzzy to leave it that way for routine driving.
These comments should not be construed as an excuse for inadequate control software. There is room for improvement.
The sport and sport + do absolutely nothing for the hesitation. Those modes actually make it worse because it seems the car lurches forward even more forcefully. I actually haven't tried S mode yet, but I really doubt that will help.
spinedoc777 is offline
Old 05-30-2019, 07:35 PM
  #46
Registered Member
Originally Posted by REALM View Post
You may just need a V6, plain and simple. Not everyone does, but you probably do to enjoy your experience.
I’ve had all kinds of vehicles...
- 4 cylinder NA
- 4 cyliner turbo
- 6 in line
- V6
- V8
- Turbo Diesel
- 2WD: RWD/FWD, AWD, 4WD, 4x4
- Sports cars, SUVs, pickup trucks mid-size, half ton, quarter ton, Sedans
Not every car and combo is right for each person. Even the best 4 cylinder turbos have turbo lag. Most can deal with it, some can’t.
I don’t love it, miss my MDX V6 at times, but I can deal with it and not planning to sell my car or anything. It still drives awesome other than the lag, and gets better mileage than a V6.
You can improve it some by just putting it in Sport+, and getting into it and saying screw gas mileage. The lag probably won’t bug you as much, but the 16mpg and slight lag might.
I believe this is the first 4 cylinder I've ever had in my life. Maybe I had a 4 cylinder beater when I was a kid, my first car was a 74 Celica lol. But I'm used to V8's and my last vehicle was a 3.8 V6 which I was very happy with. But I still suspect it's that the trans isn't shifting down and the vehicle has no power for those 1-2 seconds, it doesn't feel like it's even running on 4 cylinders unless the MO for a 4 cylinder is to just sit there. It's only at low RPM's such as when slowing or stopping, otherwise the trans seems snappy enough although a bit artificial feeling because of the turbo and the sport mode raising the shift points so high. I cannot for the life of me remember a single car in my life that I've ever driven to have this issue, it's a serious safety concern.
The sport+ mode does nothing for it but make it worse. Gas mileage isn't very good anyway so I just roll with it, I don't care much though how much I spend on gas. But my prior V6 vehicle got much better gas mileage and I rode that one hard in sport mode as well.
Old 05-30-2019, 07:42 PM
  #47
Registered Member
Again any update from OP (spinedoc777) ??
No solution yet, I doubt there is one. I previously complained to the service manager but he said it was the way the transmission functioned. Of course he also didn't inspire confidence telling me it might be because of my gas. When it goes in for its first service I am going to ride him hard about it, make him come with me for a test drive and also ask if I can drive another one to see if it does the same. But I think it's all for nothing, I think Acura/Honda just made a shitty transmission when it comes to shifting down. Heck if they can't fix their massive infotainment issues how the heck can they be expected to fix a transmission issue, which reminds me I have to get on them for the absolutely shitty issues I'm also having with the infotainment system. Without a doubt this is the last Acura I will buy, but I'm stuck with this one for 2 1/2 more years.
Old 05-30-2019, 11:14 PM
  #48
Registered Member
If you are unhappy with it you really should try to get rid of it and get something else that makes you happy, especially if you think its a safety hazard. However, if you are really stuck with it, you can try driving in "S" shift mode and use the paddles to engage manual shifting. If you down shift often and early, keep the rpm at least 2k+, especially if you know you need to merge or get on a ramp, it should eliminate a lot the lags. Also, for me, my RDX, if I come to a FULL stop before accelerate again, I usually do not experience lag.
omygod711 is offline
Old 05-30-2019, 11:34 PM
  #49
Registered Member
Well, I drove a bunch of little NA 1.5L-1.8L 4-bangers attached to 5-speed manual transmissions back in the day. So the transmission usually did what I expected, but the high-revving engines that made a whopping 115hp or so at 6000 rpm barely made 25 hp at 1500 rpm. So it paid off to get the revs up and slip the clutch when you launched. If you got caught flat in a tall gear at low rpm, it was gonna be a long slow slog to get up to speed.
In contrast, the 2.0L turbo 4-banger in 2019 RDX is a very torquey little beast that pulls strong from 1500 rpm. That's why I think this is a transmission and engine controller programming issue.
The engine would do its part if the darn transmission wasn't clogging up the works. But I think the controllers won't even let the engine get going until the transmission has finished getting its act together. "Torque management" is the phrase that gets tossed around for this. Some of this is done for the sake of smoothness, or avoiding "shift shock". The engine controller automatically reduces engine output while the transmission shifts to reduce the "rubber band effect". But also, the controllers are protecting the drivetrain, especially the clutches of the transmission.
Wander is offline
acuraada (06-01-2019)
Old 05-31-2019, 05:56 AM
  #50
Registered Member
I've thought about trying to sell the lease, it's a pretty good deal. Using the paddles is a good idea in theory, but in practice I almost never have enough time to think to downshift with them. Coming to a full stop there is no hesitation, only when rapidly slowing then accelerating before a full stop.
Old 05-31-2019, 09:03 AM
  #51
Registered Member
Drove to work in S mode today, didn't notice much difference but didn't have many opportunities to test it out. S mode isn't great though, it holds the RPM's much too high, I found myself on a regular road doing 40mph at 4k RPM for example. S mode also forces you into manual shifting mode if you use the paddles, since S mode revs so high I like to be able to downshift at higher speeds but can't do this without being forced into manual mode. In manual mode it stays in that gear forever instead of automatically changing gears. S mode and sport/sport+ mode also seems to be cumulatively raising RPM, but I prefer sport mode because of the stiffer handling and don't want to give that up. I will test S mode a bit more this weekend but it seems it actually makes things worse for my situation at least.
Old 05-31-2019, 09:06 AM
  #52
Registered Member
Madd Dog's Avatar
It is definitely the transmission logic.
Madd Dog is offline
The following 2 users liked this post by Madd Dog:
acuraada (06-01-2019), Alias1431 (05-31-2019)
Old 05-31-2019, 10:32 AM
  #53
Registered Member
Once u go into manual mode u have to committed to down shift AND upshift. Like a manual transmission car. Since you don't like the automatic logic , going full manual control seems like a good choice but you gonna have to do the extra work. However, You can also hold the upshift paddle for 4 seconds to cancel the manual shift mode.
Old 05-31-2019, 03:53 PM
  #54
Registered Member
That's not true. Even when you press the S button the transmission still upshifts and downshifts. It just holds gears longer. It's not full manual mode at all.
Old 05-31-2019, 03:55 PM
  #55
Registered Member
I think you misunderstood. Once you are in S mode AFTER you upshift or downshift with the paddle shifters you get forced into manual mode.
Old 05-31-2019, 09:51 PM
  #56
Registered Member
I have had a "hesitation problem" but not quite like the OP has. Mine is on acceleration from a stop, where there is a noticeable lag in movement before it goes normally. This is NOT turbo lag. These are easy accelerations away from stop signs in residential areas and it is like the engine management computer is taking its time in deciding to deliver fuel to the engine. I also notice something like this when I start the car and back out of the garage. I put the car in reverse gear and nothing happens for a second or two before it "decides" to go. Agree with the OP that this condition is dangerous. If the dealer cannot/will not solve it, then I will start looking for another car.
Pearl77 is offline
Alias1431 (06-01-2019)
Old 06-01-2019, 08:48 AM
  #57
Registered Member
FWIW, from the 2019 RDX Press Kit:
Paddle Shifter Operation in Sequential Mode (Sequential SportShift)
By selecting the "S" position with the transmission D/S selector button, Sequential mode is engaged. This mode offers automatic operation with more aggressive shift mapping and locks out operation of 9th and 10th gears. A pull on either of the paddle shifters places the transmission in fully manual mode until another mode of operation is selected. A digital display in the instrument cluster indicates which gear the transmission is in. The Drive-by-Wire™ throttle system creates a "blip" of the throttle to help match gear speeds while downshifting.
To prevent harm to the powertrain when the transmission is paddle shifted by the driver, the system will inhibit potentially damaging shifts. As an added safety measure, the Electronic Control Unit (ECU) can also cut off fuel to the engine to prevent over-revving. If fuel cutoff is insufficient to prevent engine over-revving, as might be possible when the vehicle is on a steep downhill, the transmission will automatically upshift to prevent damage. On downshifts, the transmission will not execute a driver command that will over-rev the engine.
For improved stop-and-go performance and to help prevent "lugging" the engine, the transmission will automatically downshift even though the transmission has been left in a higher gear as the vehicle comes to a stop.
robnalex is offline
Wander (06-01-2019)
Old 06-01-2019, 06:57 PM
  #58
Registered Member
That's a good summary, but to be clear, if the smart transmission downshifts when you stop, while in manual sequential mode, it won't prevent you from looking like an idiot when you accelerate from the stop and red-line the engine in about 0.3 seconds.
Wander is offline
Old 06-02-2019, 06:27 AM
  #59
Registered Member
Yep- same as with a fully manual tranny when you depress the clutch when coming to a stop but forget to downshift.
robnalex is offline
Old 06-10-2019, 08:10 AM
  #60
Registered Member
jperdoch's Avatar
Also find this to be true, especially if you are slowing to s stop sign but do NOT 100 percent stop...then you encounter massive lag
jperdoch is offline
Alias1431 (06-10-2019)
Old 06-10-2019, 02:32 PM
  #61
Registered Member
Yep, the approx 1 sec lag is there since first generation of RDX. I experience it with '11 RDX. Just stupid programming IMO.
Very dangerous, especially when you slowdown in slow lane, and try to change to a lane with faster moving traffic.
kosulin is offline
cthan3o3
11-09-2018 03:43 PM
Acura604
01-11-2011 07:08 PM
dqualley
09-28-2009 03:17 PM
camman565
01-14-2008 05:17 PM
Quick Reply: massive hesitation on acceleration after braking is driving me NUTS !!
