Gasoline in Oil (Oil Dilution/Engine Oil Level Increase)-Honda 1.5L Turbo
#42
RDX is the 2.0 liter turbo engine
I believe the CRV engine in question is the 1.5 liter turbo engine
has this issue been reported in Civics with the 1.5 liter turbo engine?
#47
I’ve seen quite a few UOAs of Honda 1.5L turbos with very significant fuel dilution but what I haven’t seen are UOAs with fuel dilution and excessive wear numbers. The presence of fuel dilution may not be ideal but I have not seen any evidence that it’s detrimental to engine longevity. As long as the oil still keeps moving engine parts separated this may be of no significant consequence to the engine.
hockeyaddict (05-26-2019)
#50
Car Crazy for Sure!
Honda's current "cure"
My good friend is the top service tech at a Honda dealer I get service work done. I asked him about the latest on the 1.5T engine issue. Honda Motor Corp has sent a re-programming to all dealers to put in to the eng. control computer.
It will adjust timing, fuel flow, etc, to coincide with engine temps. Too soon to know IF this is going to fix the problem.
I asked him have any 2.0T engines been in for this same issue.....and he said "no...none." And I've asked my Acura dealer about my '19 RDX engine having these kind of issues. Zero.....none. No complaints on the 2.0T engine.
So, that's what I just found out a few days ago.
The following 3 users liked this post by Colorado Guy AF Ret.:
#51
CRV owner youtube video about fuel in oil
#52
A friend of mine, who is an engineer with Honda/Acura and involved with the 2019 RDX, assured me that the RDX won't have the issues that the CR-V is experiencing. He seemed very confident in the overall mechanical build (including the 10-speed tranny) of the new RDX. Take that as you will but I trust his word to the best of his knowledge. Only time will tell if any issues will arise. This is a new design and there's always potential for unforeseeable problems.
#53
-Yes , this winter has been cooler .yes, it sometimes get driven on short trips. however this should not happen!
#54
AFAIK turbocharging increases the risk of oil dilution, as well as direct injection. So these things are certainly engineering and quality control challenges. Sucks if you're the guy who gets stuck with a "QC issue".
But the 2.0T DI Honda engine has been out in Accord for a while, it's not new to RDX. Are there wide-spread problems in that application? Or in the more high-strung 2.0T Civic Type R? I don't know, just asking.
I bought my daughter a CR-V with the 1.5T and we just had it in for their mitigation campaign. I also bought her a LOOONG HondaCare warranty ( from Saccucci Honda ) to CMA. I really don't need to hear about that for the rest of my life!
#55
Latent car nut
Received 2,005 Likes
#56
Honda is still downplaying the issue, but it appears they're going to be extending the warranty on the 1.5T by an additional year. Not much peace of mind if you ask me. Consumer Reports doesn't seem too impressed, either.
https://www.consumerreports.org/car-...turbo-engines/
#57
Nuke
I don’t trust turbos for longevity..damn, still driving my 2004 tsx, put 13000 trouble free km on it last fall driving out to western canada and northern BC. Also don’t like CVT’s. Thinking I will need to consider the Mazda CX5 non turbo. RDX drives nicely but really do you need that much HP? And.. who wants to pay the premium for higher fuel usage with the turbo and the expense of premium. Thinking CX5 and a tesla in a few years for shorter trips.
#58
Oil dilution is an unfortunate side effect of high pressure direct fuel injection and closed loop EGR / PCV systems, along with dirty intake valves and increased ingestion of oil droplets (mixed with fuel and soot) into the combustion chamber. With the RDX, we can also add turbocharging to the list of "features" that were designed to increase torque, power, and efficiency, but result in potential issues down the road.
Have you guys heard of a related issue called Low Speed Pre-Ignition (LSPI)? It's a phenomenon that is seen more with turbocharged direct injection engines that causes knocking during low rpm high load situations (i.e., when you floor it at low rpm), and it can be damaging to your engine.
Recent research has pointed to engine oil as being one of the important factors in preventing LSPI. One theory is that the detergents in the oil interacts with the gas and creates a low octane byproduct that can trigger pre-ignition. Therefore, one should always use an engine oil that is rated API SN PLUS / ILSAC GF-6 / GM dexos 1, which has been tested to prevent LSPI. I would also argue that only using fully synthetic oil is important to reduce the deposits on the intake valves (with direct injection, the intake valves don't get cleaned by the incoming fuel anymore like they did with port fuel injection).
Some advocate using oil catch cans as well, but I worry about issues with warranty coverage if they see mods installed in the engine bay, and you need to empty the thing on a regular basis.
Some links for further reading:
https://www.motor.com/magazine-summa...-pre-ignition/
https://www.turnology.com/tech-stori...oboost-engine/
https://www.theturboforums.com/threa...issues.384229/
#59
An OCC is a mod that, if anything, enhances and further protects the engine. I have never heard of anyones warranty claim being denied due to the installation of an OCC which can only help the situation.
#60
Posted the above post without the conclusion...
Given how important engine oil is to not only providing lubrication and assisting with the cooling of the engine and the turbo, its role in preventing LSPI, and how it gets diluted with fuel from today's high pressure direct injection systems, it is essential to check your engine oil levels regularly and to get your oil changed frequently (using oil rated API SN PLUS, of course).
#61
We enthusiasts understand and appreciate the benefits of oil catch cans, but dealers and manufacturers can point to user modifications as grounds for not covering your engine repairs. When I used to have a VW Jetta, that crowd was into modding as well, and a couple guys on the forum that used K&N air filters were not covered when their Mass Airflow Sensors (MAF) died, on the grounds that the oil from the K&N filters contaminated the MAF.
Alias1431 (05-27-2019)
#62
But this is an RDX forum, so on to the 2.0T. Having just replaced an Accord, I spent a bit of time on the Accord forums. Oil dilution doesn't appear to be a much of a problem on the 2.0T. Some owners are reporting a gasoline smell on their oil dipstick, but used oil analyses are showing limited and not serious amounts of fuel. Will the engine go for hundreds of thousands of miles like the V6 it replaced? Time will tell, and it probably doesn't matter to most potential buyers anyhow.
"I may be going to hell in a bucket, babe
But at least I'm enjoying the ride"
#63
#64
Definitely Honda is downplaying the issue, and that's a big concern that kept me away from the 1.5T CRV and steered me into a G2 RDX. At least Honda is finally admitting there's a problem with the 1.5T Civic in the US (but still not the Accord 1.5T). The extended warranty is something, but I wouldn't expect any of these engines to last nearly as long as the 2.4 normally aspirated engines they replaced.
#65
#66
Received 1,024 Likes
robnalex (06-02-2019)
Havasubum
49
02-05-2019 03:34 PM
iforyou
10-25-2016 11:50 AM
