FWD RDX - any regrets not getting SH-AWD?
#41
Are you guys that got the SH-AWD noticing a difference in terms of handling? I got the SH-AWD in the hopes that it would offset the move from a sedan to a crossover, but it still handles like a crossover (yes I know, obviously). I'm wondering if there is a trick to it, my sales guy said you just need to go into the turns a bit faster (but safely) and let the SH-AWD do its thing.
#42
The advantages of AWD become apparent as you approach the tires' limits of traction.
Even on some dry roads, a FWD RDX will spin one or both front tires in 1st and 2nd gears with moderate acceleration as weight is transferred from the front wheels to the rear wheels. An AWD RDX sends power to the rear wheels on take-up virtually eliminating any loss of traction even at full throttle. Floor a FWD RDX from a stop on dry roads and you'll just grind bits of rubber off the tires as you're greeted by a flashing VSA indicator.
Even with more gentle acceleration in a sharp turn, a FWD RDX will spin the inside front tire. an AWD RDX will just pull right through.
When coasting or braking through a sharp curve or corner at higher-than-prudent speeds, a FWD RDX will tend to plow as the front outside wheel is overwhelmed. An AWD RDX will apply the brakes to the inside front and rear wheels to help bring the vehicle through the corner taking some of the load off of the front outside tire.
When accelerating through a sharp curve or corner at higher-than-prudent speeds, an AWD RDX will send more power to the outside wheel to help bring the vehicle through the corner with less plow.
Tire squeal can be fun in a juvenile sort of way, but it also attracts unwanted attention, wears down the tires more quickly, and puts a strain on the front differential pinion gears.
There's significantly more advantage to AWD on wet or snowy roads. Floor a FWD RDX on a wet road and you won't be going anywhere very fast.
#43
Registered Member
some of the advantage is subtle, some more obvious.
I suggest you put the AWD info on your info display screen, and drive, you will see what each wheel is doing. As you glance at it, realize that fwd only moves the front wheels.
#44
Admittedly, there's little to no difference in handling between FWD and AWD in dry conditions with "normal" driving.
#45
#46
Registered Member
Guys,
For those who have had it done, how much is it to purchase a spare tire from Acura and have them install it on the RDX?
Also, is it the same spare tire that would have come with an AWD RDX?
Thanks!
Thanks!
#47
Registered Member
I can't tell you how much a spare tire from the dealer costs, but I paid $212.87 + $19.10 shipping for the kit (06421-TJB-A50 ) from Acura Parts Warehouse. BTW that is the A-spec part # and it worked fine in my advanced. I ordered the tire from tire rack for $97.71.T155/90D-17 KUMHO SPARE TIRE T131 SL
#48
Registered Member
#50
Registered Member
for 2k more having AWD is a steal, in Minnesota it is a no brainer, and half the fun of this car is having the back end pushing you around a corner
#51
Registered Member
At your age, I would tend to agree. Come talk to me in 40 years.... scratch that! ...come talk to my grandson in 40 years and see if you still feel the same way.
#52
Registered Member
I will say the best part in Minnesota where we just got dumped 9 inches is watching all these people spinning their wheels and I just take off like nothing, I can’t even imagine what it would be like with snow tires, love the AWD in this car
#53
Registered Member
I'm sure glad I don't live where it gets snow and ice! Other than if I wanted to race around corners, I have no need for SH-AWD or otherwise. Now, if I lived in snow country I would have it without question.
#54
Registered Member
I'm totally with you here. If I lived in Minnesota I would absolutely get SH-AWD.
Cant say that I'm with you here, though. Different strokes I suppose.
#55
Registered Member
@tsxowner1 , If it's your wife's car and she won't ever appreciate the difference, then save yourself a couple grand. But If you want to convince her because you'll be driving it too, tell her ... "If you do, you'll be glad you did. If you don't, you'll wish you had." That might work.
#56
Registered Member
#58
Registered Member
https://m.tirerack.com/tires/tires.j...R7KH&tab=Specs
got my kit from Acura parts warehouse, the top 3 parts are the aspec spare tire kit, then you still need a tire, bottom 2 are the a-spec hitch items
the top two items you technically don’t need, they replace the covers with a picture of a spare instead of the sealant, really not necessary but they are cheap
robster80
Fourth Generation TL (2009-2014)
33
08-11-2016 01:09 AM
denm316a
Second Generation RDX (2013-2018)
03-29-2014 07:30 PM
kevTL888
51
03-20-2009 10:01 AM
justaques
First Generation RDX (2007-2012)
31
12-08-2008 07:01 PM
