Dynamic mode does not change in the infotainment sytem
Has anyone experienced this glitch where the dynamic mode did not change in the infotainment while driving? When changed it says ‘drive mode is unavailable’. if so what did you do about it and what did the dealer tell you? Any advice? I have a 2019 Tech with 1200km. |
Yes. I've also experienced this on my '17 Civic Si and '18 Accord.
The RDX's Owner's Manual says: "Dynamic Mode Change Unavailable Appears if the dynamic mode cannot be changed due to certain situations, such as a system error or adverse driving conditions." Generally, you'll see this message appear under certain driving conditions where a sudden change in the vehicle's dynamics (steering, braking, acceleration, suspension) could upset the chassis leading to a loss of control. |
any updates on this? I just had this pop up today... couldn't change the dynamic mode.. and also the Nav screen changing from day to night, and back, every 30 seconds for a brief moment. Full daylight out. Sometimes with a message saying dynamic mode change not available.
weather cold, clear, but not unusual... maybe 18 degrees f? |
drive mode change not available
Just had drive mode change not available pop up several times also experienced the Nav screen bouncing back and forth between day and night several times. Less than 500 miles. Temperature about 36 at sunset.
Originally Posted by carson2246
(Post 16380205)
For me,. stopping the car, get out, lock the car, and came back to start it after about 20 minutes fixes it. |
Originally Posted by subin
(Post 16380387)
Yes, a few of us have seen the same thing. This only happened to me once in late December 2018 after the software update to 1.0.7. It happened while driving and does not appear to relate to temperature and time of the day.
Originally Posted by zroger73
(Post 16380417)
It's pretty sad when people have to reboot their cars to get them to work again. I feel like we've regressed to Windows 3.1.
Or run chkdsk to find lost clusters, then defrag. Do it from the command line. |
Check your config.sys and autoexec.bat...
Drive mode actually still changes, but no picture
This happened to me about a month ago. It was just a normal clear day and there were no other warning lights--go figure. What was interesting that the drive mode actually DOES change, but you don't get the fancy picture in the infotainment display. You'll see the new drive mode reflected at the bottom of the instrument panel. The next time I started the engine, the problem went away. There are some other threads here on this.
(Post 16380417)
This happened to me a couple times. Pressing the D/S button while already in Drive resolved it. Something in the manual about it but I forget what the logic is.
That would switch the transmission controller into "Sport" mode ( Or S mode if you prefer... ). Dunno why that would get the "Dynamic mode" stuff out of its snit.
But if you want your mild-mannered RDX to get some serious attitude, set the dynamic mode to Sport+ and the transmission to Sport. Yee Haw! |
Originally Posted by Wander
(Post 16394771)
But if you want your mild-mannered RDX to get some serious attitude, set the dynamic mode to Sport+ and the transmission to Sport. Yee Haw! What (I think) I've experienced so far: Snow: I haven't used it or needed it yet. Comfort: Normal automatic transmission operation. Using a paddle shifter will upshift or downshift and display the actual gear on the dash. But it will resume normal automatic operation within a few seconds. Sport: More aggressive shift map. Once you use a paddle, you need to shift manually thereafter. Maybe it returns to auto at some point, I don't recall. Sport +: You must use the paddles and shift manually. Not sure exactly how D/S affects the modes and I need to experiment more. |
Originally Posted by rdxny
(Post 16369626)
