Crappy Sound System
We love our new RDX, but the sound system is horrible: tinney and brittle even with the treble turned way down. I understand the advance trim has a better system , but this mess sounds like a freaking transistor radio.! Is it just me?
No, not just you.
I have the 12 speaker system and find the Audio is my greatest disappointment with this car. Tweeters are Harsh and the sound is not immersive. Audio settings need to be adjusted by source. |
What sources are you guys using, and what kind of volumes are we talking about?
I only use AAC files via USB, and I find that fine. XM is crap and you couldn't pay me enough to listen to analog radio ( even if you extracted the constant babble ). But I did bite the bullet ( hard ) and shell out for the Advance. The ceiling speakers seem to contribute much more bass and midrange than I would have expected. But this thing is an SUV ( sorta ), and road noise at high speeds is gonna be worse than an upscale sedan or coupe. If you crank up the audio to get above the background noise, at some point you're going to overdrive it. And if you live for low bass, that will happen a lot sooner. BTW, if this audio is like other similar ones I have done spectrum analysis on, the "tweeters" are really super tweeters. They don't even get in the game until 5 kHz or so. Vocals come from the midrange drivers. |
I was in my friends S550 and his sound system was better than mine.
What gives? |
Originally Posted by Wander
(Post 16434582)
Originally Posted by Madd Dog
(Post 16434593)
What gives? |
I have only driven the RDX Aspec and Advance, and have found the sound system excellent. I would not even entertain the lower end RDX's for this reason as I love a good sound system. You had to know the 12 speaker system was not going to be as good. Should have tried them both out before you decided. You have to have better things in the upper levels, because you pay more.
Originally Posted by BLEXV6
(Post 16434626)
My Bose system in my Rogue was much better than the system in my Advanced RDX. And let's not even start on the navagtion system. My wife just picked up her 2019 Hyundai Tucson top of the line model and the infotainment system is SO much better it's almost laughable. I still love my RDX because of it unsurpassed performance.
Originally Posted by Alias1431
(Post 16434616)
Pick one.
There are exactly two "tweeters", in the A-pillars. All the other drivers are midrange or full-range. What do I need to pick? FWIW, I was referring to the "tweeters are harsh" comment. Most of the time, it's hard to know if the tweeters are even turned on. If the sound is shrill or harsh, there is another cause. For instance, an amplifier that is being "overdriven" will produce distortion that often manifests as harsh high frequencies. |
(Post 16434621)
Ummm, about $100,00.00. :)
(Post 16434593)
What gives?
(Post 16434621)
Originally Posted by likerage
(Post 16434689)
Lol, I see that a lot around here. People keep forgetting they are driving around in 40k vehicles.
Unless I'm mistaken, the furry one was subtly pointing out the futility of comparing audio in a top-of-the-line luxury sedan with that in a near-luxury SUV. And I agree. But maybe I'm barking up the wrong tree. :snicker: |
SMH! Do you guys not test drive these things?
This may sound stupid, but be sure that the volume on your device (phone) is turned all the way up. When I first got my RDX I was perplexed b/c the system didn't sound as amazing as the one I test drove. Then I realized my phone was defaulting to a lower volume level when connecting to the system. Cranked the phone up and the system opened up.
I'm an audio snob, and this system is the best I've heard in a stock car. Hope this helps! |
Perceived quality != actual quality
Before I catch flak for saying that, I agree that perceived quality is ultimately most important to the consumer. However, perceived quality is subjective and can vary dramatically depending on the person, the music genre, the compression of the music files, etc... You can see that by the varying opinions of the sound system. Even the shape of the cabin plays a large role in the sound. Sure, I wish it was improved in some ways. However, biases aside, the system is very well-tuned. You also have to remember this is a sound system in a car. It will never sound as good as a proper home setup. |
Not sure I understand your comment. There is no 'phone volume' control when you plug it in, it is digital. Volume comes into play for a bluetooth connection. I believe everyone on here is playing music from a thumbdrive or an iphone directly connected to the USB port. Not sure how you are testing. Bluetooth transmission will be frequency handicapped.
On another note, I have tried listening every way possible in all different formats. I do find a 'shrill' when turned up a bit, mainly when flacs are playing. Playing with controls only help so much. The system appears to use the windows to some extent to reflect, which I would think would have limited frequency response.(even though the windshield is acoustic glass, also the side windows on the Advance). I plan on experimenting with sound absorbing material on the dash to see if I can calm it down a bit. The system has some great clear mid and lower base, which I find is superior to like Bose. |
I've learned that the Tech package (or whatever package includes the upgraded stereo system) is a must in Acura vehicles. The base models seem to have pretty sub-par setups. The 4G TL was this way. Base was pretty weak but the upgraded ELS in the Tech is really nice.
Originally Posted by Funz51
(Post 16434902)
On another note, I have tried listening every way possible in all different formats. I do find a 'shrill' when turned up a bit, mainly when flacs are playing. Playing with controls only help so much. The system appears to use the windows to some extent to reflect, which I would think would have limited frequency response.(even though the windshield is acoustic glass, also the side windows on the Advance). I plan on experimenting with sound absorbing material on the dash to see if I can calm it down a bit. The system has some great clear mid and lower base, which I find is superior to like Bose. As for plugging in via USB, I cannot comment b/c last time I did that my car spent 17 days in the shop getting the Infotainment system replaced. I only roll via Bluetooth these days. |
Bluetooth protocols have improved in terms of compression, but AFAIK USB connection is still superior. And anyway, I usually play through Apple CarPlay because the organization is better than generic USB thumb drives.
Just follow Acura's advice and use a new genuine Apple cable ( if it's an iPhone ) and you should be fine. Yeah, it's maybe 10 bucks more than a generic cable, so skip a Starbucks latte and you'll be good. Dunno what will happen if you plug a Samsung into an Apple cable... :pound: |
Originally Posted by Mustachio
(Post 16434781)
Before I catch flak for saying that, I agree that perceived quality is ultimately most important to the consumer. However, perceived quality is subjective and can vary dramatically depending on the person, the music genre, the compression of the music files, etc... You can see that by the varying opinions of the sound system. Even the shape of the cabin plays a large role in the sound. Sure, I wish it was improved in some ways. However, biases aside, the system is very well-tuned. You also have to remember this is a sound system in a car. It will never sound as good as a proper home setup. If you recorded the noise in your car on the highway and played it back at equivalent volume in your living room, you would be shocked. I think this is one of the reasons a "flat" frequency response sounds lifeless in a car. The background noise isn't "flat". And then there are the incredible resonance phenomena in a car interior, which vary depending on where you're sitting. It's really a crappy listening room. But I'm just an audio snob ( albeit a somewhat cheap one ), not a sound engineer. |
Originally Posted by Stew4HD
(Post 16434749)
When I turn and tilt my head, the music comes from all directions. I looooove the audio system.
Originally Posted by robnalex
(Post 16435171)
Most of us test drive the car, not the sound system. This is really not a big deal to me, but I expected the sound system in the 2019 RDX would at least be as good as the system in my 2001 CL. It’s not. By a mile.
I have the Advance model and love the sound system when playing back multi-channel USB sources and much of BT sources. FM and SiriusXM .. not good |
I have the A-Spec. The sound system sound good to me.
No No no... The audio system in the Advanced and Aspec is top notch for it’s price class!
No F’ing way a Rogue stock system is better than these specs; I understand the OP was asking about the base trim. I don’t own an Aspec or Advanced but have enough seat time to know the sound system is 1/2 step below Merc/Volvo Burmeister which are much more premium $$$. It’s above all of the HK, Bose, Mark Levinson crap that is sold in other mainstream lux brands/models. I suggest you take good quality source material (Lossless/FLAC) and test the same material across multiple system options to benchmark. I use a FIIO X7 MkII as my source DAP. |
(Post 16435340)
I cannot compare your 2001 CL to the RDX nor should you.
(Post 16435471)
With all due respect, I can and should compare my RDX sound system to anything I choose, including purple unicorns.
Interesting topic and I admit I struggled for a while when I first got the RDX Tech model. My test drive was in the Advanced model and it did sound better than my tech the first week. I found I had to really play with the sound setting a lot. I don't claim my ears are what they were back in the 1980's when I was a home stereo nut and spending thousands of dollars on fancy systems at home but I still have a certain taste for sound. These were my thoughts on the system in the car.
1.) Default settings sucked for most of the Applications whether XM, FM or Blue Tooth Audio. I can't speak for USB playback other than using USB Drives since my phone (Galaxy Note 8) is not supported so can't play over USB. 2.) I have played around since I got the car last June (1 year anniversary yesterday) and I still find I have to adjust the settings depending on the source. I do not see one setting works, for my ears anyway, for all sources. 3.) This is my 5th Acura...I had a 2007 MDX, a 2010 MDX, 2013 RDX, 2016 RDX and now this one. The only advanced model I had was the 2016. In my mind anyway, the overall depth of sound seemed better with those older models. I can't say the exact reason but my tastes of sound seemed better served but that doesn't equate necessarily to better sound. I like crisp highs and loud base but tend to tune down the mid-range a bit. The older speaker and sound systems seemed to play better with that type of sound. 4.) Instead of fighting it, I have been messing with the settings and for what it's worth, I have some thoughts. The 2019 Package seems to show much more detail in the music so perhaps my preferred sound muted out a lot of that. It could also explain why suddenly any compressed music playback sounds horrendous to me in the new car. I used to say I could not hear "that much" difference in sound whether a compressed MP3, a lossless MP3 or Apple Lossless. Obviously FLAC sounded much better and you could hear the obvious difference. But at the cost of large amounts of storage. Since I stream alot and activated the AT&T hotspot, I paid for the enhanced Spotify and have to admit the sound quality in the "free" version of Spotify verses the Premium is VERY noticeable so when comparing what some are describing as poor sound can also be affected based on the source being compare. That's my point. IE: Compressed MP3's or decision for streaming source. All in all, now that I have tweaked the settings I know this much. XM sounds like crap IMO. But I thought that even in my older cars. Spotify Streaming or FM HD sounds best in my mind but I get frustrated in my area since most FM stations HD signal drops from time to time. One comment I will say and I am not smart enough to know if it's the radio itself or the antenna system but the reception is far worse across the board for AM and FM. I only use AM for News and Sports Talk but man does it suck!!! And the HD drifting in and out can be irritating. My gut says it's the antenna but I could be wrong. As for using Bluetooth for ANY of the Applications on my phone, I agree with those who posted turning the volume output for media up to 100% on the phone itself. That does impact the sound quality IMO. At first I simply plugged in the phone not realizing the media volume was set to less than 50% because I was using it with plug in earbuds. All in all, I now feel it is a premium sounding system for FM and my streaming apps which all have premium subscriptions to ensure higher quality streams. But I did have to tweak and tweak to get it where I wanted it to sound. Jeff |
I found that, after adjustment, my lowly Tech system was better than virtually all of the music sources that went through it. I received a usb stick with .flac files and it put to shame every other music source.
So, having watched ME TV’s “Have Gun, Will Travel” on my current TV, and found some, shall we say ‘shortcomings’, in the broadcast, should I really blame the TV? |
(Post 16435483)
You state "With all due respect" then stay silly stuff.. SMH.. you just want to whine, obviously.. bye
Ignoring the southern version of "FU" for the moment, in terms of acoustics, comparing an SUV to a coupe is only slightly less valid than comparing it to a purple unicorn. The sound engineers did what they could to compensate with tuning, and the interior shape of RDX isn't worst of breed, but it's still a big echo chamber. It takes lots of amp power to fill it with bass and it's got a whole lot of vertical glass to reflect high frequencies. ( And it's even got a glass roof, if you're silly enough to open the shade! ) So don't expect it to sound like a cozy little coupe or a set of sealed over-the-ear headphones. It can't.
Having said that, concentrate on what you can change: quality of source material, and equalization or "tone adjustments". Sadly, the adjustments for the latter are pretty limited. But things like "DTS Neural" can be downright neurotic with some sources, IMO. Turn it off! And experiment with speed volume compensation (SVC). Noise increases with speed. I'm not sure if SVC in RDX alters the equalization as well as overall volume, and Acura isn't saying, but I wouldn't be surprised. If the CL had the Bose system, that was very mid-bass-heavy by design, so maybe that's what you are missing. In that case, you might benefit from adding a powered subwoofer. But it's worth noting that the Bose system isn't known for accuracy or detail. You might find that you're hearing things the CL was masking. That's not necessarily a bad thing. ( Oh, that's what that lyric is... ). Full disclosure: I had a 2003 MDX with the Bose system. RDX is better. Unless you really enjoy boomy mid-bass at the expense of everything else in the music. |
(Post 16435846)
Having said that, concentrate on what you can change: quality of source material, and equalization or "tone adjustments". Sadly, the adjustments for the latter are pretty limited. But things like "DTS Neural" can be downright neurotic with some sources, IMO. Turn it off! And experiment with speed volume compensation (SVC). Noise increases with speed. I'm not sure if SVC in RDX alters the equalization as well as overall volume, and Acura isn't saying, but I wouldn't be surprised. If the CL had the Bose system, that was very mid-bass-heavy by design, so maybe that's what you are missing. In that case, you might benefit from adding a powered subwoofer. But it's worth noting that the Bose system isn't known for accuracy or detail. You might find that you're hearing things the CL was masking. That's not necessarily a bad thing. ( Oh, that's what that lyric is... ). Full disclosure: I had a 2003 MDX with the Bose system. RDX is better. Unless you really enjoy boomy mid-bass at the expense of everything else in the music. As per Bose vs ELS, I totally agree. In my experience Bose systems do tend to be quite bass heavy but horribly imprecise and if you enjoy bass heavy music, it will definitely sound better to you. I used to prefer bass over clarity when I was younger and now I think I like a 50:50 balance. I noticed that many modern systems focus WAY more on clarity vs bass and even with the bass levels turned all the way up they don't satisfy me during times where I want to feel a little punch. I noticed this trend starting to happen around 2012 with many modern vehicles I've driven compared to the mid 2000's and under vehicles. |
(Post 16435846)
(Post 16435846)
(Post 16435899)
Thank you, I see you understood my response to him regarding the comparison of different types of vehicles with very different sound stages. Nuff said.
Originally Posted by dukeh62
(Post 16434922)
To clarify my statement: The physical volume controls on your phone (at least on an iPhone) effect overall input level when connected via Bluetooth. If your phone's volume is not all the way up, the sound system will sound noticeably thinner. Sounds like you're not using Bluetooth, though.
The issue with the RDX system, IMO, is that it is balanced, just like a good reference monitor. Like what you would find in a studio- guess who designed it? The speakers are very clear and balanced, good quality. Problem is, the music sounds flat to most people because they are used to all kind of treble and bass and juiced up equalizer settings. Playing with the EQ can help a lot.
(Post 16436383)
I find the system in my Advance to be, by far, the best stock audio system I've ever heard. The interior of any vehicle, because of its overall size, shape, dimensions and materials is just an acoustical abomination. Every car audio system is a compromise. That has always been the case and until they start lining car interiors with some sort of anachoic material, that will never change. I've always felt that most car audio snobs are mostly full of shit and people who spend a lot of money on customizing their systems just have more money that knowledge or sense. But, it's their money and that's just my opinion.
I think initially, I paired my phone just to try it but mostly I have my music dumped onto a USB stick I keep plugged into the port in the console. For now, it's all MP3s and I don't have it organized into albums or play lists but it all sounds pretty good. It would be nice to be able jump to the middle of a recording like most audio players but there doesn't seem to be any way to do that. If I have a 22 minute album side that's one continuous recording, I'd like to be able to jump ahead sometimes. |
I have an Advance with the 16 speaker system and as long as I am using at the very least bluetooth from my iphone or digital FM the sound is great it even gets better with carplay hooked directly into phone. I can't even imagine what using the 5.1 uncompressed audio from a usb must sound like. XM siruis radio is today's equivalent of AM radio from the 1980's sad that they have not upgraded to an uncompressed format and are stuck in inferior sound.
