Any way to turn headlights off at night?
Not planning to drive on the roads at night without lights....
I do astrophotograhy as a hobby and visit "dark sites" frequently. Dark Sites are located far away from light pollution sources to better see and photograph the night skies. Courtesy requires turning off your headlights when entering and leaving these sites. Of course the headlights on my 2019 RDX come on as soon as the car is put into Drive. Has anyone found a way to temporarily turn the headlights of while moving at night? I've read several threads related but found no solutions. I wondered about putting a light over the sensor that tells the RDX it's dark, but not sure where it's located. I tried one on the windshield over the rear view mirror but it didn't work. Any suggestions? Thx in advance. |
Originally Posted by TripleBlack
(Post 16421191)
I am interested in the answer to this as well. I couldn't find a way to do it. Had I known before buying the car, it might have deterred me from buying it because I prefer to have manual control/override of everything.
Well see, The way our laws are written.....they mandate that every car have DRL's, or Daytime running lights. Anytime the car is put into Drive, the lights come on. For Safety
Now, older cars used side markers or other type of extruding lights....and you could disable them by pulling the parking brake, before you started up the car. or by pulling a fuse. newer cars on the other hand, have everything integrated into the headlight. meaning, no separate controls or hardware to control. Perhaps you could try the parking brake trick.. with the car off, engage parking brake. turn car on. lights should be off. |
(Post 16421236)
Now, older cars used side markers or other type of extruding lights....and you could disable them by pulling the parking brake, before you started up the car. or by pulling a fuse. newer cars on the other hand, have everything integrated into the headlight. meaning, no separate controls or hardware to control. |
Well OP is asking about "while driving" so i think all of this won't work for him unfortunately. Unless you want to apply your parking brake and creep along somehow :shrug:
...Well if we all take a moment and read our manual page 186, one will see they can turn the parking lights on only (HEADLIGHTS off) manually by rotating the light knob to the first position below AUTO. If the OP wants to go completely dark then they are out of luck, but this solution turns OFF the headlights, which is, based on how the question was worded, what was requested.
Have a good weekend :thumbsup: |
Originally Posted by markm929
(Post 16421260)
Have a good weekend :thumbsup: Have a good weekend :thumbsup: |
(Post 16421236)
In the United States, the FMVSS 108 standard for Lamps, Reflective Devices, and Associated Equipment permits, but does not require daytime running lamps. Studies performed by the NHTSA as recently as 2009 were inconclusive as to the effectiveness of DRL's. General Motors was an early adopter of DRL's in the US and has strongly petitioned for decades without success for them to become required by law. https://www.federalregister.gov/docu...ated-equipment |
Originally Posted by zroger73
(Post 16421285)
DRL's are required by law in Canada, but are voluntary in the United States.
In the United States, the FMVSS 108 standard for Lamps, Reflective Devices, and Associated Equipment permits, but does not require daytime running lamps. Studies performed by the NHTSA as recently as 2009 were inconclusive as to the effectiveness of DRL's. General Motors was an early adopter of DRL's in the US and has strongly petitioned for decades without success for them to become required by law. https://www.federalregister.gov/docu...ated-equipment I wonder how Canadians get around the problem that the OP has with trying to be courteous in dark sites. |
Originally Posted by anoop
(Post 16421244)
That's how it works in auto mode, but it doesn't have to be that way in manual mode. I had manual control over these in my 2015 BMW and I don't think anything has changed on that front.
Originally Posted by kurtatx
(Post 16421301)
On my Audi you can put the lights to manual/off, but if you do, the DRLs are on and the car gets pretty mad. It beeps incessantly and gives a warning
(Post 16421274)
Well if we all take a moment to read ALL of our manual page 186 we will learn that as soon as the transmission is taken out of park and the parking brake released and the car moves, the lights come on.
Have a good weekend :thumbsup: I read the OP as DRL's on wasn't even an option but maybe you can clarify OP? |
(Partial) Solution...
I put a very bright LED lamp I use to photograph landscapes at night over the light sensor with some gaffers tape and set the Auto Light Sensitivity to Max.
In my dark garage, the headlights now stay off when I take the transmission out of park. DRLs stay on, which is acceptable. I'd tried this before with a dimmer light and the Auto Light Sensitivity set to Medium and it didn't work. Combination of much a much brighter light and the Max setting did the trick. Thanks for the input. Now carry on with your DRL conversations. :D |
(Post 16421309)
:ohsnap: :pofl:
I read the OP as DRL's on wasn't even an option but maybe you can clarify OP? Just posted my solution, which I hope will work fine and maybe help someone else out. Outside of pulling fuses or fooling the sensor, I don't think there's anyway to keep the headlights from coming on while moving at night. Thanks for the help! |
You can turn off the headlights while driving at night. I’ve done this before sneaking home late one night. If they are set to auto, just rotate the headlight stock counter-clockwise (twist it away from you) one click and they will turn off.
Originally Posted by Dcshoesboy
(Post 16421404)
(Post 16421252)
(Post 16421260)
(Post 16421285)
(Post 16421297)
I think they are useful when people forget to turn their lights on at or after dusk or in the rain. The dusk issue is largely solved by automatic headlights, the rain issue still remains, in that headlights don't turn on automatically when it's raining if it's not dark enough.
Originally Posted by cm2021
(Post 16421622)
I noticed the headlights do turn on in the rain. If I have my wipers on in the day for about fifteen seconds or longer the headlights automatically come one.
Many states have a law where headlights must be on when the windshield wipers are in use. Drivers often forget to turn on the headlights in the rain and are risking a citation without even realizing it.
I grew up in Louisiana, and they will write you for this in no time. |
(Post 16421666)
(Post 16421668)
We need the tail lights too in bad rain. DRLs unfortunately don't fix that.
Headlights/Parking lights. |
(Post 16421307)
Is there not an option in the MMI to disable DRL? In the BMW, there was an option in iDrive to disable DRL.
(Post 16421669)
I'm under the impression that the full lighting comes on.
(Post 16421404)
(Post 16421410)
Yeah, I've done that too. In a '69 Chevelle. That does not work on a 2019 RDX. If it does on yours, you should see a dealer.
(Post 16421285)
Originally Posted by PAPI007
(Post 16426658)
Before GMC/Chevy try to petition anything, they should figure out a way to make the daytime running lamps work. Every time I see a GMC/Chevy truck or SUV, only one daytime running lamp is working and the other is always blown out. Has anyone else noticed this before?
(Post 16421285)
@hockeyaddict ...That pub date is 2009...I do not believe that holds true any longer or has for several years. My understanding is that all new manufactured vehicles must have DRLs and not sure what year that started but I think is was several years ago. The DRL is only on when the headlight switch is in the off or AUTO position and ambient light keeps the headlights from turning on.
Originally Posted by securityguy
(Post 16426864)
From FMVSS 108: Daytime Running Lamps Permitted But Not Required on Passenger Cars, Multipurpose Passenger Vehicles (MPV), Trucks, and Buses 2 identically colored either white, white to yellow, white to selective yellow, selective yellow, On the front, symmetrically disposed about the vertical centerline if not a pair of lamps required by this standard or if not optically combined with a pair of lamps required by this standard Not more than 1.067 meters above the road surface if not a pair of lamps required by this standard or if not optically combined with a pair of lamps required by this standard See S7.10.13(b) for additional height limitation. Steady burning.Automatically activated as determined by the vehicle manufacturer and automatically deactivated when the headlamp control is in any “on” position. Each DRL optically combined with a turn signal lamp must be automatically deactivated as a DRL when the turn signal lamp or hazard warning lamp is activated, and automatically reactivated as a DRL when the turn signal lamp or hazard warning lamp is deactivated. See S7.10.10.1(c) for additional activation requirements when mounted close to, or combined with, a turn signal lamp. |
(Post 16426658)
I know on the 2000-2006 GM truck design, water would leak into the light and melt the DRL. Happened twice on a 2003 Yukon I used to work on a lot. |
