2019 RDX Advance
2019 RDX Advance
I have a few questions hoping someone can help....by the way the vehicle is amazing!
1) Can you turn on the fog lights without headlights on? Is there a way to do this?
2) Can you zoom in on navigation screen? Noticed it is always zoomed out.
3) Can you turn bass on further for subwoofer alone or is it just bass in general that can be increased?
Thank you so much.
Thank you so much.
Registered Member
Thank you so much.
Thank you so much.
1. No, fog lights come on only with the headlights. And this is pretty much "normal" with most all vehicles I've owned...and that has been many.
2. There is only 1 adjustment for the "Bass".....none separate for the sub. I wondered about his too, since previous versions of the ELS system allowed for both.
Registered Member
Regarding the bass - it’s all about how you EQ the mix of treble, mids, and bass. Don’t just turn the bass all the way up (to a whopping 6). It will just make everything muddy. Depending on your source and style of music you may need to tinker but once you do, and get it right, it’ll be more impactful than trying to shake the mirror off.
Registered Member
It also doesnt have a separate subwoofer anymore either.
Registered Member
It takes some research, BUT, you are incorrect. There is a 20cm sub woofer mounted in an enclosure in the right sidewall of the cargo area.
Why it does not have a separate control...not positive, but, after doing some studying of this system....and I'm by no means a designer or true audiophile, what I get from the design of the system, it is integrated in such a way that
they only needed to have 1 Bass adjustment.
If you read DEEP about this design collaboration...with Panasonic and their chief speaker designer for 37 yrs, along with Elliot Schieners' guidance, this was quite the project....esp. designing speakers that spread music although
being so thin....and that is the ones in the headliner. Many of their new designs are proprietary.
The Following User Says Thank You to Colorado Guy AF Ret. For This Useful Post:
MTD (07-12-2018)
Registered Member
But according to the other thread, that's kind of useless because most people want to be zoomed in more than the default while the Nav is actively tracking ie, car position is centered--it snaps back to the default when out of explore mode. I haven't used the 2018 RDX nav to any great extent, but all other cars and the standalone Garmin I have can set the zoom level so you can see more detail and it stays while using the nav whether currently navigating to a destination or not.
Registered Member
Thanked 0 Times
in
Registered Member
Registered Member
Agree, but OMG I hope we don't have to wait for next fall to get the "push". Nothing was promised about zoom on the Nav display, but it looks like the map update mechanism isn't working as promised, so maybe a Nav software update will be forthcoming.
Registered Member
So would you say that aspec is overall more sportier ride than advanced?
Registered Member
The Advance has the dampers that adjust based on what you set the Dynamic Drive Mode to. So, the word is it can ride pretty damn good.
Registered Member
Yea, I would be interested in stiffer/harder suspension. If both are in the same mode: sport or normal, which one has more stiffness in suspension? When I test drove they only had tech package, would ASPEC be any stiffer? I know it has 20” tires which can make it appear stiffer, other than tire size, do they use different suspension in tech vs aspec?
Registered Member
The A-Spec dampers are kinda "harsh" in my opinion. Lot rougher than Gen 2 RDX's for sure.
Registered Member
According to Acura, the A-Spec has a re-tuned suspension...stiffer yes. But, those dampers "self adjust" unlike the Advance, where you can "make them" change their ride quality.
Registered Member
I test drove it, but, I know we didn't really get on the type of roads I have encountered here in my city. I'm frustrated with it. Love the A-Spec, but, can't figure out why so 'harsh" over that stuff. The Mich. Premiere LTX are
supposed to be a "softer riding tire." Talked to Tire Rack about it...and maybe swapping out, but, they told me the Premiere A/S 3+'s I wanted would not ride better.
Registered Member
A-spec doesn't have the capacity to electronically "self-adjust", but I believe it has multi-stage shock absorbers that automatically "soften up" in response to big hits, so you can keep your dentition intact. This is pretty common in modern cars.
There are different flavors of electrically active shock absorbers and associated control systems. Some automatically respond to varying road and driving dynamics conditions in real time, at the millisecond time scale. Some allow the driver to adjust the overall "sportiness" of the ride. And some do both. I believe the system in the 2019 RDX Advance does both.
Registered Member
Advance gets noticeably stiffer in Sport+ mode compared to Comfort mode, but I can't compare directly to A-spec.
Registered Member
There are strictly mechanical systems that open additional valves in the shock absorber in response to high-amplitude impacts, so called amplitude reactive shock absorbers. These are much more common, and much less expensive than shocks with electrically controlled external valving. I remember from a posted interview with an Acura engineer that magnetorheological (MR) shocks are NOT used, as are used in some flavors of MDX. Those are quite expensive.
https://www.acura.com/performance/mo...active-dampers
From the press release:
Registered Member
Ok, what about tech vs aspec suspension, is aspec suspension stiffer?
Registered Member
my understanding is the suspension is the same across all trims but the exception is in advance you get active dampers that adjust depending on the driving mode. In the tech and aspec there is no active dampening - controlled by driver or otherwise. People will wonder then why it has comfort mode, the answer to that is that the drive modes adjust other parameters As wel such as throttle response and steering weight to give you a sportier feel with more “go” and tighter steering so you feel as though you’re in more control. The thing that really makes the aspec feel stiffer are the 20” wheels. They aren’t as soft and don’t “roll” as much obviously as 19” wheels. I think the tech will feel more like the aspec than the advanced because of the active dampening, but the tech is also softer than the aspec because of the wheel package. To me, the advanced felt too spongy but that’s all a matter of preference. I’ve driven sporty sedans my whole life so I want that feel. Not the feel of driving boat. Drive each and make your own conclusions though. It’s a personal preference thing honestly.
The Following User Says Thank You to Dizzyg12 For This Useful Post:
russianDude (07-16-2018)
Registered Member
Lower profile tires will make some difference in both ride "stiffness" and sharpness of handling, but I do remember a posted comment from an Acura engineer that the suspension was "tuned" differently in A-spec relative to other trims. To me, that means different springs and/or shock absorbers. When parts lists are posted, we will know.
It's been a few decades since I stuffed Koni adjustable racing struts into a first-gen Toyota MR-2, so I may have forgotten what a stiff suspension feels like. But the 2019 RDX Advance corners pretty darn flat for a 4000 pound SUV, especially in "Sport+ mode". Comfort mode is a little bit soft and floaty, IMO, but on pothole infested roads that's not always a bad thing. And the "dynamic modes" do make a difference in that trim, both in suspension feel and the other parameters cited ( steering assist, throttle response ). Transmission shift points are altered as well. And "S" transmission mode takes that up another level.
RDX isn't an exotic car. But RDX can go places an exotic car dare not tread ( and with far more occupants and cargo ).
Registered Member
Thanks. Yes, the handling is great, but, I've now come across "raised ridges" on some roads, and just overall "rough places" and the ride gets really harsh. Don't like it at all. And I've got my TP down to 32 lbs. So, it's not that.
Thamks for sharing this. Backs up our experience. My husband says although the Comfort mode is soft, he feels our new 2019 Advance (in “Comfort” mode) is still stiffer than our 2002 TL rides.
Registered Member
I cant speak for the A-Spec as I only test drove it for 10 minutes after I drove the Advance. The A-Spec was not as comfortable as the Advance in comfort mode. I wish Acura shared more information on the suspension so that we knew exactly what the differences are to make an informed decision. I have some information on the Active dampers and have that in other vehicles I own so I know how it works. It helped me to make my decision on the Advance over the A-Spec model. It is much nicer ride than my 2014 RDX was IMHO.
brucechang
36
01-20-2019 06:04 PM
gtssenior
Third Generation RDX (2019+)
19
06-03-2018 05:36 AM
deanoatkinson
25
05-26-2018 06:45 PM
lexus9810
Second Generation RDX (2013-2018)
26
08-31-2017 07:38 PM
