10 Speed transmission recalled in Honda Vehicles
So I see there is an issue with the 10 speed transmission in the Honda odyssey where the TCU could reboot and the default behavior is to go into Park, which could happen while driving. This can severely damage the parking pawl. Is this a thing we have to worry about with the RDX since it uses the same transmission?
https://www.consumerreports.org/car-...rollaway-risk/
Here's Honda's official statement regarding the 10AT recall in the Odyssey.
https://hondanews.com/honda-corporat...-touring-elite
Here are more details from the NHTSA.
https://static.nhtsa.gov/odi/rcl/201...9V299-2515.pdf
This issue does not appear to affect other models that use the 10AT including the Accord and RDX at this time.
The following 2 users liked this post by DrWoo:
Curious3GTL (04-26-2019),
justnspace (04-27-2019)
Since the TCU and its programming may be very similar in 2019 RDX, I didn't find this reassuring until I read the following section of the NHTSA release:
There is overlap with 2019 RDX production, but the software fix shouldn't be difficult to apply if applicable. Better than a wrecked transmission.
I am curious with this fix, what happens if the car battery goes dead or is disconnected when it’s just sitting their parked, does it change to neutral? That would be just as bad
Good question. One would hope there is some logic, such as if in park, then stay in park, else shift into neutral.
Clearly, Honda was researching this issue for some time before they introduced revised software into Odyssey production in Jan 2019.
I would hope they would apply this to other potentially affected vehicles in a timely manner.
if it breaks, and the parking brake is NOT set...the car will roll away...
redundancy redundancy redundancy.
if you are so worried, always use the parking brake...as that's another form of a physical stop..
then you dont have to worry about software failing. or code that wasnt tested for certain conditions
the parking prawl is a physical object.
If the transmission tries to ram the parking pawl into the torque converter outer gear ring while the car is in motion, it will make a horrible noise.
If you have any awareness of what your car is doing, you will know something bad happened.
Honda is worried about the segment of the motoring public that doesn't have a clue.
It is for reasons like this that I now subconsciously always always put the parking break when parking. Regardless of if I'm on flat ground or incline...etc.
