Connection issue between Nexus 7 and Windows 7
Old Apr 18, 2014 | 12:27 PM
JS + XES's Avatar
I drive a Subata.
So, I'm trying to connect my Nexus 7 (2012) to my computer for the first time.
When I plug in the USB cord, nothing appears to happen for both devices.
What am I doing wrong? Embarrass me.
Android version is 4.4.2 on this tablet. Just did the update couple days ago.
Old Apr 18, 2014 | 12:32 PM
TeknoKing's Avatar
http://www.asus.com/support/Knowledg...-7F168085F0D7/
or just use a sledge hammer
PS you can also try on your phone Settings > Storage > 3 dots > USB connection. Check if MTP is ticked. If it is try to tick PTP to see if your device will then be recognized. (Reboot)
Old Apr 18, 2014 | 12:43 PM
ChodTheWacko's Avatar
Moderator Alumnus
I don't think windows 7 comes by default with MTP drivers.
Install this:
http://developer.android.com/sdk/win-usb.html
and I happened to find this thread just in case:
http://forum.xda-developers.com/show....php?t=2390296
Old Apr 18, 2014 | 02:03 PM
JS + XES's Avatar
I drive a Subata.
There's no ASUS Android to select on Device Manager.
MTP is checked.
Downloaded that USB driver.
Still nothing. WTF!
Old Apr 18, 2014 | 02:13 PM
Anachostic's Avatar
Does it charge when the USB is plugged in? Bad port or cable?
Old Apr 18, 2014 | 02:20 PM
JS + XES's Avatar
I drive a Subata.
Yes! It does say it's charging.
Old Apr 18, 2014 | 04:04 PM
slvrdrgn123's Avatar
Maybe you're using a charge cable and not a data cable?
Old Apr 18, 2014 | 04:56 PM
JS + XES's Avatar
I drive a Subata.
Oh there's a different cable for it?? I thought it's the same.
Old Apr 18, 2014 | 04:59 PM
JS + XES's Avatar
I drive a Subata.
Yesssssss
It was the cable. I used another cable and did this:
Worked!
Thank you guys!
Old Jun 18, 2014 | 09:33 AM
Anachostic's Avatar
This thread came to mind when I read about this:
http://krebsonsecurity.com/2014/06/g...n-your-mobile/
Juice-jacking as a threat probably first crept into the collective paranoia of gadget geeks in the summer of 2011, after I wrote a story about two researchers at the DefCon hacker convention in Vegas who’d set up a mobile charging station designed to educate the unwary to the fact that many mobile devices (particularly Apple devices) are set up to connect to a computer and immediately sync data.
Didn't even consider that attack vector.
cycdaniel
Dec 17, 2019 10:58 AM
snorf
Sep 17, 2015 10:04 PM
ahsm
Sep 9, 2015 08:35 AM
Stu2414
4G TL Problems & Fixes
Aug 30, 2015 07:30 PM
