Computer Building Thread
Old Aug 26, 2011 | 12:12 AM
  #121
DaChef320's Avatar
Registered Member
Anyone know how good is the gigabyte mobocracy GA 990fxa compairing to the Asus formula 890 mobo?
Old Aug 26, 2011 | 12:13 AM
  #122
DaChef320's Avatar
Registered Member
Azuser, tell me whats fair for it. I have no idea.
Dizaz, boot time is of zero conzequence to me. A sata6.0 internal hdd will be just fine for me.
But they been having good deals on SSD lately on newegg
Old Aug 26, 2011 | 12:16 AM
  #123
stogie1020's Avatar
Needs more Lemon Pledge
$39 for a 500gb seagate internal.
Old Aug 26, 2011 | 12:30 AM
  #124
MonopolyMan's Avatar
Here's a build that my co-worker just put together for one of our clients. We call it our Carbon Series.
The pictures don't do it justice. It's super clean.
Old Aug 26, 2011 | 12:33 AM
  #125
litesout's Avatar
Oliver!!!
That's not a bad list Stogie. Your old case and 550 PSU should be sufficient. Depending on how old it is you may want to look into replacing it down the road. I've lost a lot of components to aged PSUs over the years. That things got more power than my gaming machine, enjoy it!
Old Aug 26, 2011 | 12:38 AM
  #126
stogie1020's Avatar
Originally Posted by svtmike
Try out a Corsair H50 cooler for better cooling and quieter operation. I put one on my son's i5 and it keeps the core temps way down. I've got one to put on my i7 rig, just need to make the time to transplant it to a new case with clearance for it.
Thanks Mike, I am definitely going to check that out. I have Fry's Electronics in town so I plan to put my hands on one to check it out sometime after I get the machine up and running.
Old Aug 26, 2011 | 12:42 AM
  #127
#1 STUNNA's Avatar
Sanest Florida Man
fuck fuck fuck...
6 Years and my desktop just shit the bed. Pretty sure the processor took a dump. All fans spin, all drive spin, no power or drive light, all cards seated ok, motherboard light comes on...
Nothing. No beeps, no warnings, no display at all.
NOT what I needed right now...
I smell bad power supply. I'd check that, you can pick one up for $30ish to test.
I've got one of these, very handy for my job.
http://www.newegg.com/Product/Produc...82E16899705003
If not PS then yeah prolly mobo, see any swollen capacitors?
Old Aug 26, 2011 | 12:43 AM
  #128
#1 STUNNA's Avatar
Sanest Florida Man
I've got one on my desktop and one on my Server, works great.
Old Aug 26, 2011 | 12:46 AM
  #129
Mizouse's Avatar
You know what, you may be right, I think my computer did the same when the PSU went out.
I bought one of those testers too.
Old Aug 26, 2011 | 12:57 AM
  #130
#1 STUNNA's Avatar
Sanest Florida Man
Also FYI it's extremely rare for a CPU to die, in fact I've never seen it happen IRL.
Old Aug 26, 2011 | 12:59 AM
  #131
Mizouse's Avatar
yea i remember when i suspected my psu to go out.
i bought a cheapo one from worst buy, test it, determined it was the PSU and then returned it and ordered this from newegg.
http://www.newegg.com/Product/Produc...82E16817139010
  #132
stogie1020's Avatar
Stunna, the drives spin, all the fans spin, and the green LED on the MOBO lights up...
I tried swapping a new Vid card in and no joy, so I suppose I could try a new PS, too, but I think that after 6 years, the processor and the thermal compound on it may have just called it quits...
I am not admitting defeat, but the computer ran, no joke, 24/7 for 6 years. I only shut it down when I went out of town.
Old Aug 26, 2011 | 01:00 AM
  #133
Mizouse's Avatar
damn auto correct?
  #134
Mizouse's Avatar
mine did the same.
are the fans spinning at 100%?
Old Aug 26, 2011 | 01:02 AM
  #135
Mizouse's Avatar
im still on my stock thermal compound and fan. although my computer is 5 years old and its a core 2 duo
  #136
stogie1020's Avatar
Originally Posted by Mizouse
mine did the same.
they spin normally.
I will "borrow" a PS from Best Buy tomorrow when I return the Vid card and see.
Old Aug 26, 2011 | 01:04 AM
  #137
stogie1020's Avatar
Don't get me wrong, I would be MUCH happier spending $80 on a new PS than $800 on all new gear right now.
I am a little hopefull that it may just be the PS.
I am also a little less stressed/pressured to buy new stuff, as my Netbook seems to run the remote app I need to use.
Old Aug 26, 2011 | 01:09 AM
  #138
Mizouse's Avatar
actually you know its probably my POS ATI (i mean AMD, well it was ATI when i bought it) video card that does it.
when i boot it spins up to 100% for a second and then spins down.
Old Aug 26, 2011 | 01:10 AM
  #139
#1 STUNNA's Avatar
Sanest Florida Man
It's very common for everything to spin up and have the mobo light up yet still have a bad PS
Old Aug 26, 2011 | 01:22 AM
  #140
Mizouse's Avatar
did you have any power outtages or spikes recently?
thats what killed my PSU even thou its plugged into a surge protector
Old Aug 26, 2011 | 01:34 AM
  #141
Moose Muscles's Avatar
Bad motherboard or overheating.
Try new thermal paste, its the cheapest fix/test you can do.
Other than that, test motherboard by pulling ram and booting with no ram in.
You could try a new power supply, but I doubt that has anything to do with it.
Good luck
Old Aug 26, 2011 | 01:40 AM
  #142
litesout's Avatar
Oliver!!!
Funny you should mention that. I just replaced a bad CPU in my mom's machine. It wouldn't power up at all, no response from the button. Tried disconnecting all the drives, swapped out the ram with known good ram, tried an external video card (vs the onboard) all to no avail. Was getting ready to swap in a new mobo when I figured I'd try a replacement CPU. Had one laying around from a system I scrapped out with a bad mobo. It posted, but the voltage regulator was going bad so under load voltage dipped and it blue screened. It ran great with the other CPU.
Old Aug 26, 2011 | 01:52 AM
  #143
Ken1997TL's Avatar
I've built probably over 200 machines since the early 90's. Only one ever had a bad CPU. Original Athlon 64 and I'm quite sure it was my fault...
Old Aug 26, 2011 | 02:48 AM
  #144
Stapler's Avatar
Well. I may be driving up there this weekend. I can bring you my mystery psu crate.
Old Aug 26, 2011 | 06:41 AM
  #145
Costco's Avatar
Speaking of surge protectors, which ones would you get?
Not looking for anything fancy, just want something to plug in and let it do its job. I completely forget how much a typical good one costs.
Old Aug 26, 2011 | 09:15 AM
  #146
#1 STUNNA's Avatar
Sanest Florida Man
Get an APC battery backup for $40
Old Aug 26, 2011 | 10:27 AM
  #147
Mizouse's Avatar
Old Aug 26, 2011 | 10:36 AM
  #148
Ken1997TL's Avatar
Bought a few of those, been quite happy with them.
Old Aug 26, 2011 | 10:53 AM
  #149
litesout's Avatar
Oliver!!!
Can't beat them, and you get the added benefit of not losing your work when the power flickers which is pretty frequent here in the summer. I've got a 550 on my network equipment, a 1500 on my PC (which will run it for about 45 minutes while gaming) and had a 350 on my entertainment center until the battery crapped out. Just haven't gotten around to buying a new one yet but I will.
Old Aug 26, 2011 | 11:04 AM
  #150
CocheseUGA's Avatar
I need to buy one, but I've been waffling on which one to get.
Old Aug 26, 2011 | 01:24 PM
  #151
#1 STUNNA's Avatar
Sanest Florida Man
I got the 900 for my server and recently upgraded my 900 on my desktop to the 1300. It's got the new feature that cuts power to my accessories like my speakers, monitor and hard drive dock when I put my pc to sleep. Pretty suite, will save a few bucks in the long run and have less annoying lights in my room when I try to sleep, plus I like it's led display
Old Aug 26, 2011 | 01:31 PM
  #152
Costco's Avatar
^hmm.... on second thought, maybe I DO want a fancy one.
Old Aug 26, 2011 | 02:29 PM
  #153
#1 STUNNA's Avatar
Sanest Florida Man
this one should be more than enough
http://www.buy.com/prod/216010981.html
Old Aug 26, 2011 | 02:39 PM
  #154
#1 STUNNA's Avatar
Sanest Florida Man
You guys don't have battery backups already on your machines? SMH
You guys need to get on that, I probably have a very brief outtage for lightning or whatever about once a week so I got the router, modem and computers all on backup so if we get a brief power outtage I don't lose interwebs.
Old Aug 26, 2011 | 03:05 PM
  #155
AZuser's Avatar
_
I have 3 older versions of those. Definitely worth the investment.
  #156
doopstr's Avatar
Agree, they are too cheap not to have.
Old Aug 26, 2011 | 03:06 PM
  #157
doopstr's Avatar
I made the smoke come out of a 486DX4 once.
Old Aug 26, 2011 | 03:17 PM
  #158
AZuser's Avatar
_
I've often found battery is almost as much as new unit so I just buy a new one when they're on sale or closeout
Old Aug 26, 2011 | 03:54 PM
  #159
stogie1020's Avatar
Ha, awesome. I just grabbed a PS from BB and am trying to put it in . Connectors have changed a bit for fan power on the MB... Oh well, here goes!
Old Aug 26, 2011 | 04:11 PM
  #160
Mizouse's Avatar
