Best way to connect your Non-HDMI PC to your HDMI port TV
I don't have a HDMI port on my laptop (its 2 years old) and I want to connect it to my TV, what would be the best way? My TV has USB and HDMI ports. My laptop has the VGA (I think thats what you call it) and the USB ports.
Thanks.
Thanks.
Needs more Lemon Pledge
The problem here is that the VGA port only carries video, not audio.
You can use this:
http://www.monoprice.com/products/pr...seq=1&format=2
You will need to find a 3.5mm male to 3.5mm male cord to run from the headphone out on the laptop to the 3.5mm in on the converter. Radio shack should have this, although Monoprice may as well.
You can use this:
Go Giants
Depending on the size of the TV, it will probably look like crap.
Go Giants
Somethings fishy.
Sanest Florida Man
Just use the VGA port, going from VGA to HDMI will only make the image worse. Also you should have a PC audio port that goes along with the VGA port. It's usually just a 3.5mm minijack port. You can pick one of those up for 60 cents at monoprice.
Received 2,329 Likes
If your laptop is two years old, don't you have a DVI port?
If you do, you can get an adapter for DVI to HDMI allowing you to broadcast in high definition and then you'll only need to connect the audio.
Buy an Apple TV or something similar and just stream it.
To be fair, VGA will do what you want, it just won't look as sharp as DVI or HDMI.
Sanest Florida Man
Buy a new laptop that supports Widi
http://www.pcmag.com/article2/0,2817,2357919,00.asp
<object width="1280" height="745"><param name="movie" value="http://www.youtube.com/v/eZylICfc4uI?fs=1&hl=en_US&hd=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/eZylICfc4uI?fs=1&hl=en_US&hd=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="1280" height="745"></embed></object>
navtool.com
31
11-16-2015 08:30 PM
navtool.com
09-25-2015 05:15 PM
