Finished the SSD installation tonight along with removing the optical drive and replacing it with a secondary bay where I installed the HDD to serve as a data drive. So far everything is working well and is running much faster than before.
The SSD makes the computer feel like it's not running a Core 2 Duo 2.4Ghz processor from 7 years ago.
Nope, currently running Mavericks and the beta for Yosemite is supported as well. And from what I have heard the release version of Yosemite will be supported so I am keeping my fingers crossed.
Computer mfg going to be in trouble once the mass market figures out that they can make a computer last 10 years by installing SSD.
I truly don't think SSD's are going to be the reason how people can extend the life of their machines. An SSD's lifespan is shorter than an HDD, so if anything, it may make people more inclined to buy new when it gives out on them.
The fact of the matter is, most hardware that is produced can easily last a long time, my 2007 MBP is a testiment to that. However, because people 1) want the latest and greatest, and 2) lose patience when their older devices take a few extra seconds to perform a task, they ditch it and move on to something better. Sure an SSD helps improve the latter issue; however, most would be inclined to replace due to the perception that others may have as to why you are still lugging around that old device when you can have a new one. And the marketers do a great job of convincing the majority that they "need" the next best thing. Except most that upgrade don't need to have the fastest device to check email, browse the web and play games. In addition, I can easily have my MBP last another 5 years without the SSD, I could have just put a newer, standard HDD and it would have been just fine and definitely outlive the SSD; however, once OS X isn't supported on it, I'll probably ditch it within a year or two after that, but we'll see what happens when that time comes. If the Logic board or some other major component fails on it before then, I'll probably ditch it sooner as replacing those items doesn't make it cost effective to keep it.
The write limits on even the new cheaper TLC based SSDs are 10+ years. No one buys any HDD and expects to get 10 years out of it. So that reason isn't as big as it once may have been.
I tell anyone, especially with laptops, that if they have an Intel based Mac that is still supported a SSD will give them 3 additional years of satisfactory performance. "Non-power" users though. Obviously if you are crunching numbers or in Adobe all the time HDD speed isn't going to make enough difference.
There's a "prevents sleep" column in the energy tab in Activity Monitor. I never got the battery draining sleep issue fixed so I just switched to Windows full time since it runs better on my Mac and OS X does
You can turn off transparency in Accessibility settings. I find transparency annoying and distracting in Safari. I don't mind it elsewhere but it seems that if you want to turn it off in Safari you have to turn it off everywhere.
Mine still works. But then I didn't I erased the entire drive installed Windows 8 first in EFI mode and then reinstalled mavericks, it doesn't use EFI legacy mode.
Can someone confirm or deny that Google Chrome is a huge energy hog on OS X? I wonder if it's the browser itself or an extension I have installed.
It is compared to Safari. My understanding is Safari saves power by using the Sandy Bridge+ graphics, while Firefox uses your computer's graphics card. That may be made up, but it sounds reasonable. I started using Safari due to Chrome battery drain and it is certainly a real thing.
It's more than that since my rMBP doesn't have discrete graphics. I've pretty much switched over to Safari because of this, safari's ability to import my bookmarks from chrome sealed the deal.
Yosemite beta 2 is like a really nice. Everything that wasn't working in 10.9 is working great in 10.10. My horrible sleep battery drain issue is fixed! I can actually use OS X now!
So far so good for Yosemite here, as well. Beta 1 had some bugs in Safari, but since then Beta 2 is a huge improvement.
