Before replacing a turbocharger, it is important to conduct a thorough diagnostic check of the engine systems. If the engine does not operate properly,
one should not assume that the turbocharger is the cause of failure. Only after all these points have been checked should one check the turbocharger for faults.
Because it often happens that fully functioning turbochargers are replaced even though the failure does not lie here, but with the engine.
1. Insufficient power/boost pressure too low
Filter, hoses, and pipes are clean and in good condition.
The fuel injection system is in good condition and correctly adjusted.
Excessive flow resistance in exhaust system/ leakage upstream of the turbine.
Boost pressure control swing valve/poppet valve does not close.
Foreign body damage on compressor or turbine.
The insufficient oil supply of turbocharger.
Engine air collector cracked/missing or loose gaskets.
Turbocharger bearing damage.
Turbine housing/flap damaged.
Valve guide, piston rings, engine or cylinder liners worn.
2. Turbocharger generates acoustic noise
The pipework and support brackets are not loose or damaged and that the connections are good.
Check for any leakages or cracks in the inter-cooler.
Dirty compressor or charge air cooler.
Suction and pressure line distorted or leaking.
Exhaust gas leakage between turbine outlet and exhaust pipe.
3. Smoke
Air filters are not restricted or blocked.
Engine oil specifications strictly correspond to car manufacturer’s recommendations.
Oil feed and drain lines clogged, leaking or distorted.
Coke and sludge in turbocharger center housing.
Piston ring sealing defective.
Crankcase ventilation clogged and distorted.
Fuel system/injection feed system defective or incorrectly adjusted.
4. Oil leakage
Oil feed and drain lines clogged, leaking, or distorted.
Piston ring sealing defective. 5. Compressor/turbine wheel defective.
6. Boost pressure too high
Boost pressure control swing valve/poppet valve does not open.
Pipe assy. to swing valve/poppet valve defective.
7. High oil consumption
8. Foreign Objects
Turbo wheel damage, caused by small objects entering the turbine or compressor housing at high speed, leading to imbalance.
9. Lack of lubrication
Turbo fatigue cracking and material transfer created by metal friction and high temperatures as a result of oil inlet supply restrictions,
incorrect gasket placement, and use of liquid gaskets or poor quality lubricants.
10. Over-speed & Excessive Temperature
The turbocharger speed exceeds its operating limits, which causing the compressor and turbine wheel to deform and fail.
In short, most turbochargers of failures are due to the following causes
Inadequate oil supply (oil pressure/filter system)
Dirt in the oil
Penetration of foreign bodies into the turbine or the compressor
High exhaust gas temperatures (ignition system/injection system)
Here we go again...Spam disguised as helpful hints.
nothing about your "10 helpful hints" are helpful.
Please read the room, most people are not having turbo issues..
