Make your Acura visible with Lumen LED Headlight Kit at CARiD!
HID conversion kits have gained a lot of popularity over the years for being the easiest way to improve your nighttime driving experience, and give your vehicle an upgraded custom look. If your Acura is in need of this upgrade, Lumen LED Headlight Conversion Kit would be perfect to cover all your needs. Built for impressive lighting performance, this kit has reliable shock, vibrant and heat resistant construction.
Lumen LED headlight bulbs will allow you to see further ahead so you can easily spot vehicles, pedestrians, or obstacles in the distance - you’ll have plenty of time to steer or brake appropriately, and drive with confidence and a greater sense of security. It install directly into your headlight housing sockets and attach to the factory headlight wiring connectors with no modification required. Once you install them, you'll be impressed with that cool blue-white 6500K light they provide. It not only ensures better visibility, but also gives your ride a head-turning look. Capable of running constantly without any issues for up to 50,000 hours, this is the most efficient lighting solution you were looking for.
Watch this video with details review on Lumen Headlight and Tail Light Bulbs:
https://www.youtube.com/watch?v=2QzAOylsV38
Lumen® - LED Headlight Conversion Kit
Get years of life and much better coverage on the road with Lumen LED Headlight Conversion Kit at CARiD!
While I represent the shop, I will still agree with the comment above. Stock HID headlights in your Acura are still better than anything aftermarket.
The fog lights on the other hand still can be upgraded to LED with a help of our conversion kits: https://www.carid.com/2005-acura-tl-...nversion-kits/
For the fog lights I recommend Lumen G7 or G8 LED lights. The provide a very well good beam of diamond white light and have a good energy efficiency.
Actually all our LED lights come in 5000-6000k diamond white color. If your HID lights are diamond white, our LEDs would be a good match.
You can check more about LED fog lights and view products here: https://www.carid.com/articles/led-f...gy-drives.html
