JAVOedge Portable Battery Pack
We have a pretty good product that you guys might be interested in. If you own a PSP, iPod, Treo, anything that charges via mini-USB then this is the perfect mobile charging solution.
I use this with my iPod Nano on a daily basis. With a full portable battery, I can charge my Nano from zero power to full about 30 times before having to recharge the portable battery again. When I go on road trips with my girl, she uses it to charge her PSP while I charge my iPod. Saves a lot of space only carrying one charger/battery.
Don't forget to use the coupon code, it will work on this product (as well as any other JAVOedge.com products)!!!
Coupon Code: ACURAZINE611
*case sensitive*
20% off
Key Features
High Capacity (3400mAH) Portable Battery Charger - $39.99
Portable Battery Bundles
High Capacity (3400mAH) Portable Battery Charger ESSENTIAL Kit - $49.99
High Capacity (3400mAH) Portable Battery Charger COMPLETE - $67.05
If you have any questions please feel free to post here and I'll reply back. :ben:
*case sensitive*
20% off
Key Features
- Battery Pack is rechargeable, once you empty it to your other devices recharge it via a USB port (by computer or by usb wall charger).
- Light-weight, easy to carry.
- Compatible with any USB-powered device.
- Holds enough power to charge a USB device up to eight times without needing to be recharged itself.
- 5V, 3400mAh Lithium-ion
n (Li-ion) battery will provide the power your USB-powered devices need. - Dimensions: 100 x 62 x 15mm or 3.9 x 2.4 x .6 inches
- Weight: 120g or 4.2 oz
- White mini USB cable included
MetalGearTypeS
08-29-2016 08:28 PM
Sarlacc
Console & Computer Gaming
09-30-2015 02:15 PM
Hines57
09-24-2015 01:58 PM
