Hytech Exhaust and Engine Products for TSX available from Heeltoe!
Ok, at long last! Here is the parts list, Price, and lead time of
Hytech's offerings! Engine parts and exhaust will work on AT or MT cars. Reflash available for all except 05 5AT. Reflash needed for optimal or safe performance. Exhaust Manifold (Specify NA or SC), $1,300.00 4 weeks Catalytic Converter (Specify NA or SC), $395.00 4 weeks Exhaust System (Specify NA or SC), $899.00 4 weeks Cylinder Head Modification Standard Port/Full Weld, 1200/2000 4/6 weeks Camshaft pair, Stage 1 or 2 (For NA), $899.00 Stock VTC Acutator, $125 Stock Valve Spring set, $149.00 Stock Retainer set, $149.00 Stock Valve set, $225.00 Stock Intake Manifold, $500.00 Stock ITB Kit, Complete, $2,899.00 2 weeks Intake Gasket - Hondata, $55.00 Stock Oil Sump Baffle kit, $289.00 Stock Piston set w/ ring - Hytech/Wiseco Custom, $600.00 6 weeks Connecting Rod set - Carillo, $1,195.00 4 weeks Ecu reflash - Hondata Reflash, $595.00 2 weeks K-Pro Conversion Harness, Not Including K20 ECU , $850.00 2 weeks This is a custom dual ECU setup. Not endorsed by Hondata, but we assure you it works. This is a racecar deal. That means thinks like traction control and vehicle stability control are not going to function properly, or at all probably. So for performance and whatnot it will work fine. But we are not recommending for a street application! I have outlined a few packages for you so you can save your adding skill for later if you want. None of the packages include reflash or Kpro, which will be needed! In addition to labor. Now, we have all seen this Dyno: http://www.heeltoeauto.com/files/mar...vsstocktsx.jpg This car was running the Grand Am Stage 1 Kit: Entire cam package (cams, retainers, springs, valves), Header, Oil pan baffle. We also know that the header is designed specifically for use with the Hytech Cat and exhaust, those packages are: Grand Am 1 Kit: $3011 Grand Am 1 Kit with Cat and Exhaust: $4305 With the Grand Am 2 Kit, Intake Manifold, IM gasket, pistons and rods, we are bumping power to about 290 for WHP and 260 for torque: $6655 For the most extreme package, we have the ITB/Full Weld kit. 315 WHP, 250 ft-lbs. $11,054 Eye Candy: Grand Am Motor and header: http://www.heeltoeauto.com/files/mar...h/IMG_0699.jpg http://www.heeltoeauto.com/files/mar...h/IMG_0704.jpg http://www.heeltoeauto.com/files/mar...h/IMG_0706.jpg http://www.heeltoeauto.com/files/mar...h/IMG_0764.jpg Cat: http://www.heeltoeauto.com/files/mar...h/IMG_0765.jpg Exhaust Details: http://www.heeltoeauto.com/files/mar...h/IMG_0767.jpg http://www.heeltoeauto.com/files/mar...h/IMG_0768.jpg http://www.heeltoeauto.com/files/mar...h/IMG_0769.jpg http://www.heeltoeauto.com/files/mar...h/IMG_0774.jpg Header details: http://www.heeltoeauto.com/files/mar...h/IMG_0775.jpg http://www.heeltoeauto.com/files/mar...h/IMG_0776.jpg Baffles: http://www.heeltoeauto.com/files/mar...h/IMG_0802.jpg Cams: http://www.heeltoeauto.com/files/mar...h/IMG_1362.jpg http://www.heeltoeauto.com/files/mar...h/IMG_1363.jpg http://www.heeltoeauto.com/files/mar...h/IMG_1366.jpg Springs/Retainers: http://www.heeltoeauto.com/files/mar...h/IMG_1371.jpg Valves: http://www.heeltoeauto.com/files/mar...h/IMG_1372.jpg http://www.heeltoeauto.com/files/mar...h/IMG_1375.jpg Pistons: http://www.heeltoeauto.com/files/mar...h/IMG_1383.jpg http://www.heeltoeauto.com/files/mar...h/IMG_1382.jpg http://www.heeltoeauto.com/files/mar...h/IMG_1386.jpg Porting: http://www.heeltoeauto.com/files/mar.../RSXHead-3.jpg http://www.heeltoeauto.com/files/mar.../RSXHead-4.jpg http://www.heeltoeauto.com/files/mar...IRSXHead-4.jpg |
Dayam...I wish I had $15k to spend on my car right now...
Finaly! Serious parts, all motor ftw :)
do you need payment in full at time of purchase or can we put like half down and then pay the other half when the parts are ready? that Grand Am 1 Kit with Cat and Exhaust is looking really tasty :yum: :yum: and this is a complete bolt on kit right? no modifications needed?
JEEBUS 315hp?!?!? :drool:
price!?! :bawling: |
:bigeek:
so for the grand am 1 kit do we need BOTH the reflash AND the K-Pro? or just the reflash would work?
now does the extreme kit really mean itbs and how well will this work for a street given car.
Looks like an awesome setup!
What is needed for K-Pro in addition to the K-Pro Harness that Hytech is selling? Do I just need an K-Pro ECU from an RSX? Will this harness work for a TSX with an Auto Transmission? |
Can we expect an extra 3-5 lbs of tq and maybe 10-15 hp with the 06/07 TSX?
What is everyone thoughts on stage 1 on a 06/07 5AT and possible long term problems with 50 lbs of extra tq? Any suggestions/plans to beef up the 5AT? |
Wow...Unreal...
What kind of gains could you see with just the intake manifold? |
I can see a few banks getting knocked over this weekend.....:chuckle:
Right, now all I need is ask Pepsi if they fancy sponsoring me - just for the hell of it! I get fast car, they get.....erm.....come on guys help me out here.....erm......something in return. I'd be more than happy with Stage 1, but Stage 2 would be nice. Stage 2 is already asking a lot from the front end as far as putting that power down, so God knows what Stage 3 requires, if not a complete race car strip out and requisite suspension/sway bars, and race rubber! Exhaust cheaper than Comptech, not much more than Skunk2 - looks like there's a new default in town now. |
Nono, only a reflash. Kpro is for extra credit ;) |
Marcus,
Any eta on my Stage 1 kit w/exhaust and cat? When do I send in my ECU? So, we can add the pistons, etc later and then get another reflash or k-pro? I'm sooooo excited. :excited: |
Yeah, I said ITB Full Weld...and I imagine with the tuning capability on the Kpro street drivability would be quite good. I know a number of people with this type of setup on lesser Hondas. Of course, premium fuel, and maybe octane booster for full potential might be needed. We would be talking about 12.5:1 compression. |
What is needed for K-Pro in addition to the K-Pro Harness that Hytech is selling? Do I just need an K-Pro ECU from an RSX? Will this harness work for a TSX with an Auto Transmission? For the Kpro, you need an RSX ECU, conventional Kpro system, and the harness. Unsure of compatibility with AT. I will ask! |
What is everyone thoughts on stage 1 on a 06/07 5AT and possible long term problems with 50 lbs of extra tq? Any suggestions/plans to beef up the 5AT? I'd say no. The 06 extra power probably has more to do with the revised DOT testing than any significant change in engine performance. The 06-07 is a little better, but we are changing most of those differences to new stuff anyway. Problems? I doubt it. The 4 cyl transmissions are generally very strong. I highly doubt you'd have any issues at that level. Remember, we are not launching or anything, right ;) ? |
Originally Posted by joerockt
Wow...Unreal...
What kind of gains could you see with just the intake manifold? Asking now. Good question. |
We do a 50/50 deal. Pretty much bolt on yeah. Hardest part is putting the cams in. |
I always thought putting in the new springs and retainers was a little harder than just swapping out the cams :toocool: Those damn little retainer keepers! :ugh: |
what parts require the reflash? ie can we install the intake manifold and still get some gains?
what if i go with kit #1 or #2 and decide to throw a supercharger, is it posssible? and what are the cons/pros of the possiblity of throwing force induction after gettting one of these kits.. also it would be nice if there was list of how much gain each part puts out so people can buy just the parts which provide the most gains.. |
so for the Grand Am 1 Kit with Cat and Exhaust, i'll also need to purchase the reflash & Kpro right? what if i currently have the regular reflash? is it just gonna be upgraded to the hytech specs? |
would it be difficult you think to do it in two stages of doing the grand am 2 kit first and the ITB's later on. |
ohhh i like that!!
Originally Posted by vilmar5
Pardon my noob question, but what does ITB stands for?
http://img.photobucket.com/albums/v6...9e1b40e9_b.jpg |
Originally Posted by jiggaman
http://img.photobucket.com/albums/v6...4fd4df6d_b.jpg
http://img.photobucket.com/albums/v6...9e1b40e9_b.jpg this is the second hottest set of ITBs in my opinion only behind the gold ones. http://img353.imageshack.us/img353/505/dsc0360xe2.jpg http://img265.imageshack.us/img265/6913/dsc0361nh3.jpg My hope is if I do ITBs I could get them with the top with the bolt pattern for those CF hats. |
power trade off for non jdm parts. hmmmm. damn I wanted the j's single exhaust but ITBs are so sexy.
ohhh i like that!!
so for the Grand Am 1 Kit with Cat and Exhaust, i'll also need to purchase the reflash & Kpro right? what if i currently have the regular reflash? is it just gonna be upgraded to the hytech specs? No the reflash and kpro are two different versions of the same thing. Reflash is when they take your computer and reprogram it. Kpro is when you program your own computer. Either eay, you want to optimize the computer for your mods. The reflash is good for a car modded with bolt ons, but crazy NA or boost will require the Kpro. The reflash we are talking about is the Hytech specific one, yes. Different than the regular Hondata one. Marcus |
what if i go with kit #1 or #2 and decide to throw a supercharger, is it posssible? and what are the cons/pros of the possiblity of throwing force induction after gettting one of these kits.. also it would be nice if there was list of how much gain each part puts out so people can buy just the parts which provide the most gains.. The Grand am reflash is designed for use with the cam package, hytech exhaust system, and either intake mani (stock or hytech). I am unsure of the effect of adding boost. For sure you'll want the kpro over the reflash if you think you will boost it. |
Marcus will i need to buy both the reflash and the kpro or either or for the Grand Am 1 Kit with Cat and Exhaust? thanks! |
yes i'm aware of the differences between the different reflashes and kpro but my question is:
will i need to buy both the reflash and the kpro or either or for the Grand Am 1 Kit with Cat and Exhaust? thanks! Marcus, this hasn't been discussed yet, but, isn't the VTC (RSX type S) part of the Grand Am kit? |
Since K-pro is now a solution (anyone using it yet btw?) are low compression pistons available as well as the 12.5:1 you have offered?
Originally Posted by TodaSi
No, either re-flash OR k-pro. I'm getting the full Grand Am kit and will be getting the re-flash only. :thumbsup:
I too would like to know if this header/cat/exhaust combo would work well with a Comptech Supercharged car? Since the Comptech S/C requires it's own reflash and all.
i've sent an email to Marcus in regards to this as well... i'm also interested in the k-pro solution... |
What the intake manifold looks like?
Damn, our cars can actually go pass 300hp?? oh my god, is this ever so tasty!!
