EXCELERATE PERFORMANCE: Exclusive Distributor For Many 09+ TL SH-AWD Parts!!!
Former Sponsor
![](http://i34.photobucket.com/albums/d121/Excelerate/XLR8LogoJPG.jpg)
Excelerate Performance is proud to carry a variety of parts for your 09+ Acura TL SH-AWD.
XLR8 PERFORMANCE PRODUCTS
XLR8 Stainless Steel Resonated Catback Exhaust (3" to Dual 2.5" to Dual 4.5" Double Wall Oval Tips):
![](http://d5otzd52uv6zz.cloudfront.net/931a9e15-c742-4aa9-93a8-cb08f7108176-800.jpg)
http://store.excelerateperformance.c.../i-399076.aspx
XLR8 J-Pipe:
![](http://d5otzd52uv6zz.cloudfront.net/bea7a153-9e21-430c-b9a5-78617b869f46-800.jpg)
The XLR8 J-pipe is 100% stainless steel, utilizing T304 stainless steel. The primaries are equal length 2.25" piping which transition into a 2.5" collector with stainless steel flanges and hangers.
http://store.excelerateperformance.c.../i-349736.aspx
XLR8 T304 Stainless Steel High Flow Cat 2.5" IN/OUT (200 Cell Metallic Substrate):
![](http://d5otzd52uv6zz.cloudfront.net/41e38553-0f1e-4c2a-97a3-6f1a89e75faa-800.jpg)
http://store.excelerateperformance.c.../i-349577.aspx
XLR8 Test Pipe:
![](http://d5otzd52uv6zz.cloudfront.net/20cee089-3de5-4844-818d-afc5b93af988-800.jpg)
The XLR8 Test Pipe replaces the third cat with a straight through 2.5" test pipe. This helps free up exhaust flow, especially when installing a j-pipe. The test pipe is made out of T-304 stainless steel pipe and T-304 stainless steel flanges which offers high strength and complete resistance to harsh elements. The pipe also includes tabs to reuse the OEM heat shield. Also includes hardware and gaskets.
http://store.excelerateperformance.c.../i-300877.aspx
XLR8 Stainless Steel Brake Lines:
![](http://d5otzd52uv6zz.cloudfront.net/a4a4c7fb-c6f7-4e32-8ce8-4d93fd020452-800.jpg)
XLR8 Performance now offers our very own XLR8 Stainless Steel Brake Lines. Each stainless steel brake line is made up of teflon hose that has an extruded teflon core with an outer stainless steel braided wire covering. The ends are then permanently crimped on each end. Each line is then finished with a black PVC cover, which gives added protection from flying debris or further abrasion protection from the line rubbing on suspension components. All lines are DOT certified and manufactured for us by an industry expert who has 25 years of experience.
http://store.excelerateperformance.c.../i-465652.aspx
XLR8 Aluminum Crank Pulley:
![](http://d5otzd52uv6zz.cloudfront.net/b1257728-d92d-40e8-80f9-a983c9bf3f7f-800.jpg)
XLR8 Crank Pulleys are lightweight aluminum pulleys manufactured for Excelerate Performance by Unorthodox Racing. Each pulley is designed and manufactured here in the U.S. using the latest CAD software. We use only the finest U.S. produced materials available today. Our manufacturing processes follow strict quality control measures ensuring superior products that are attractive, durable, and most of all reliable. Our pulleys are held to .001” tolerances, usually reserved for aircraft, medical, military and space manufacturing programs.
http://store.excelerateperformance.c.../i-291887.aspx
Acurazine P2R Package:
![](http://d5otzd52uv6zz.cloudfront.net/7d4dc263-cb3e-42c9-9a6d-6f8f5b242b5d-800.jpg)
This package includes one polished P2R 3/4" Throttle Body Spacer and two P2R thermal throttle body gaskets.
http://store.excelerateperformance.c.../i-285242.aspx
Takeda Retain Short Ram Intake:
![](http://d5otzd52uv6zz.cloudfront.net/974cdabc-cdfa-4720-a596-d80510e2d4c3-800.jpg)
Polished:
http://store.excelerateperformance.c.../i-262816.aspx
![](http://d5otzd52uv6zz.cloudfront.net/0d08fdd5-73eb-4b98-89ff-0d269316bf92-800.jpg)
Black:
http://store.excelerateperformance.c.../i-283115.aspx
Ingalls Alignment Kits:
Ingalls Toe Arm:
![](http://d5otzd52uv6zz.cloudfront.net/b397cd55-6cc2-4719-a784-ce18abe9542f-800.jpg)
1 Required Per Side:
http://store.excelerateperformance.c.../i-412290.aspx
Ingalls Camber and Toe Arm:
![](http://d5otzd52uv6zz.cloudfront.net/bed9f7d5-d0c9-4164-adc8-3867d11f0b83-800.jpg)
http://store.excelerateperformance.c.../i-412291.aspx
SPRINGS AND COILOVERS:
H&R Sport Springs:
![](http://d5otzd52uv6zz.cloudfront.net/group-f981ba19-4f43-4556-b041-c2e7530e45e9-800.jpg)
Every spring produced by H&R comes from the H&R ISO 9001 certified engineering and manufacturing facility in Germany. All H&R springs are produced from a special 54SiCr6 spring steel, which has strength rated at 290,000 psi resulting in unrivaled tensile strength and resiliency.
http://store.excelerateperformance.c.../i-238962.aspx
Ksport Kontrol Pro Coilover Kit:
![](http://d5otzd52uv6zz.cloudfront.net/6930da7c-b767-490a-9a55-89909b20ee92-800.jpg)
The Ksport Kontrol Pro Coilover kit has been designed with professional road racing in mind offering extremely high value and performance.
FEATURES
36-way adjustable dampening
Made from high quality 6061 Aluminum with T6 for increased hardness
Compression/Rebound adjustable
Adjustable spring perch for height adjustment
Adjustable body allowing maximum suspension travel
Pillow Ball Top Mount w/ adjustable camber (not available for some models)
Monotube High Pressure Design reduces oil leakage
Electroplated body for protection from corrosion and rust
One Year Limited Warranty
http://store.excelerateperformance.c.../i-398272.aspx
TEIN Super Streets:
![](http://d5otzd52uv6zz.cloudfront.net/50219-800.jpg)
These features of the TEIN Super Street Damper kit were designed with greater performance to satisfy all your driving demands. This high performance damper can be used for weekend racing and/or daily driving.
Features
High performance and cost effective.
16 levels of damping force adjustment (compression and rebound together).
Ride height adjustable.
New paint coating for rust prevention.
Pillow ball mounts are optional (on certain applications).
Exclusive design for USA vehicle specifications (only available for the U.S.A Market).
Available for overhaul.
http://store.excelerateperformance.c.../i-304947.aspx
TEIN Basics:
![](http://d5otzd52uv6zz.cloudfront.net/50210-800.jpg)
TEIN Type BASIC damper is for the driver that is seeking high performance with a reasonable price. The Basic damper MSRP starts at $750.00, which includes 4 springs and 4 shocks. Compared to the “sleeve type” coil over, the Type Basic has a more exclusive set up for a better balance of suspension travel and damping force.
http://store.excelerateperformance.c.../i-304924.aspx
ExcelerateRep
Sponsored Sales & Group Buys
01-06-2016 09:59 AM
ExcelerateRep
12-11-2015 12:58 PM
