Notices
Parts Search
Keyword:
Category:
Price:
Location (State/Prov/Terr):
Item Condition:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Color:
Location (State/Prov):
SOLD: 3G TL: Carbon Fiber, JNC, Type R Red, Volk TE37 SL, Rays, C-Mod Grille, Ultra Racing&
Old Jan 6, 2014 | 07:23 PM
Skier4lyfe303's Avatar
Category: Accessories
Price: $1
Location (State/Prov/Terr): CO
Item Condition: Used
This is an update to my large for sale thread. I have sold a lot of items in the first thread, so I am closing it and starting this thread. Here are the links:
-Build Thread
https://acurazine.com/forums/showt...7#post14778477
-First For Sale Thread
https://acurazine.com/forums/car-parts-sale-361/3g-tl-rays-volk-ignalss-p2r-flp-tein-carbon-fiber-jnc-am-type-s-aspec-more-901057/
I have explained what happened to this car and why I am selling these parts. The majority of the parts (including brakes and suspension) were on the car for 5K miles.
DO NOT PM ME ASKING FOR OTHER PARTS NOT LISTED
. SOME PARTS IN THE BUILD THREAD HAVE ALREADY BEEN SOLD OR ARE NOT AVAILABLE FOR SALE
First are the descriptions
Pictures are in Post 2
Pricing is in Post 3
Exterior
-New 07/08 C-Mod Grille Wrapped w/ an 04 OEM Hood Trim in Matte Black Vinyl
-Comes w/ C-Mod Hood Trim
-Fits BOTH Base and Type S
New Carbon Creations Hood, Wrapped w/ 1 piece of clear bra (top corners are peeling, center has a blemish)
Suspension
Ingalls Front ball Joints on stock upper control arms +/- 1.5
H&R Front and Rear Sway Bars
Front Sway Bar 28MM STILL ON THE CAR
Rear Sway Bar 22MM
Moog Endlinks for the Rear sway bar
Ultra Chassis Bracing
Front Subframe Brace powder coated red STILL ON CAR
Side Floor Bars powder coated red
Rear subframe brace new in plastic
Engine Dress Up
OEM ITR Powder Coated J32A3 Valve Covers (These are one of a Kind)
Matching FLP for 04-08 TL can use with EDFC
Interior
Custom CF Wrapped OEM Interior Parts (one of a kind)
04-06 Cluster Bezel
04-08 Fuel Door release (was originally gray, not visible when installed)
04-08 Steering column (driver side has broken tabs, creates a small gap when installed)
04-06 Steering wheel buttons
04-06 Fuse Box Lid in engine Bay (has a scratch)
Engine
04-06 Gerzand PNP Intake Manifold w/ Maxbore TB (TB has machined shaft & Screws)
Comes w/ Both P2R TB & IM gasket
-Stock J32A3 Valve Springs & Retainers
-Stock J32A3 Crank
-Stock J32A3 Cams
-XLR8 Engine Mounts (65A Bushings) STILL ON THE CAR
Lights
04/05 JNC Headlights
-Darkness Theme (which I helped Create)
-Matte Black V2
-Fog Light Bulb Covers
-Gloss Black
-Bezel
-Chrome Strip
-Type S Diffuseres
-Real ZKW Lenses
-Hybrid TL Projectors
THESE WERE REPAIRED BY JNC and will directly ship from him
-Two outside tabs have been repaired, fully functional may be better than OEM
-The pass light tab broken and was repaired (this headlight is clear bra’d)
-The driver light was replaced with a used light
-Only the ZKW Lens and Type S diffuser were reused
-The lens has been refinished by JNC
Luminics Yellow H8 Fog Lights 12V 35W
Wheels
TE37 SL 18X9.5 +22
Comes w/ Original boxes, stickers, valve stems, wheel covers
-New Fake Rays Lug nuts in package with key
-Real Rays Lug Nuts & Valve Stems-Very Faded will need to be reanodized
-SSR Lug Nut Adapters- Allows you to use aftermarket lugs (acorn) with stock wheels (ball)
Tires
Hankook Ventus RS3 235/40ZR18
All 4 tires have between 5-6 32nd's
All 4 tires have rubbing on the sidewalls
Included is a set of 4 replacement certificates from Discount Tire
Brakes
-Stoptech FR (For Brembo) Cross drilled and Slotted Rotors
-127.40062RL with Silver Anti Corrosion
-Hawk Performance Brake pads- Part # HB530N.570
Other
Accord Fog light wire harness (includes both wires harnesses- inside and outside, OEM fog light button, New OEM relay)
This is for running lower fog lights in the lower grilles of 04-06 TL's.
07-08 TL Passenger Side fog light housing with screws
Custom Cut Clock (fits 9500ci Radar Screen w/out blue cover)
Custom iPad Mini Bezel
Aux Port
iPad mini of your choice
Paint or Plasti Dip
Stretched AC Display
-2007-08 TL Ignition part (the black piece goes behind the immobilizer, this is not sold separately by Honda/Acura, sold only with the complete ignition)
-Base 3G TL Exhaust inserts
-Hondata Complete Plug and Play for 04/05 MT with 07 MT Type S ECU
-Either Send me your already cut Switchbalde
-Send me your stock key, I will reblade and recut the switchblade
-Fully Built Engine
Made 264WHP in Denver on a Mustang Dyno
-STILL IN THE CAR
Parts that are still on the car will be removed when the engine is taken out. I do not currently have a set date for this. Should be within the next month.
Old Jan 6, 2014 | 07:24 PM
NEW 07/08 C-Mod Grille Wrapped w/ an 04 OEM Hood Trim in Matte Black Vinyl
-Comes w/ C-Mod Hood Trim (not pictured)
-Fits BOTH 07/08 Base and Type S
-One of the Bolt holders was shaved for CF hood
URL=http://s1309.photobucket.com/user/skier4lyfe303/media/C-Mod%20Grille/IMG_1739_zps296764a0.jpg.html][/URL]
New Carbon Creations Hood, Wrapped w/ 1 piece of clear bra (top corners are peeling from putting it in the box, has a blemish towards the center)
Ingalls Front Camber Kit
H&R Rear Sway Bar 22MM
Side Floor Bars powder coated rear
Engine Dress Up
OEM ITR Powder Coated J32A3 Valve Covers (These are one of a Kind) STILL ON CAR
04-06 Cluster Bezel
99-08 TL, 96-04 RL or 01-03 CL Fuel Door release (was originally gray, not visible when installed)
Engine
-Stock J32A3 Crank
-Stock J32A3 Cams
P2R IM Gasket
Stock J32A3 Valve Train
Stock J32A3 Crank
Stock J32A3 Cams
Lights
-Matte Black V2 and Fog Light Bulb Covers
-Gloss Black Projector Bezel and Chrome Strip
-Type S Diffuseres
-Real ZKW Lenses
-Two outside tabs have been repaired, fully functional, better strength than OEM
-The pass light tab broke and was repaired (this headlight is clear bra’d)
TE37 SL 18X9.5 +22
Comes w/ Original: boxes, stickers, valve stems, wheel covers
Tires
Other
This is for running lower fog lights in the lower grilles of 04-06 TL’s.
Aux Port
Paint or Plasti Dip
All prices are shipped to the lower 48 unless otherwise stated
07/08 C-Mod Grille $220
Carbon Creations Carbon Fiber Hood $550 NOT SHIPPED
Ingalls FR Camber kit $150
H&R Rear Sway Bar $165
Moog Rear Sway Bar Endlinks $50 (ill refund $25 when I get your stock ones back)
Ultra Side Lower Bars $200
Ultra Rear Subframe Brace $170
Custom ITR Powder Coated Valve Covers & Strut Bar $525
Valve Cover & IM Cover come with New valve cover gaskets & Used IM Cover gasket
Just Valve covers & IM cover $350
Just strut bar $200
04-06 Cluster Bezel $150
04-08 Fuel Door release (was originally gray, not visible when installed) $40
04-08 Steering column (driver side has broken tabs, creates a small gap when installed) $150
04-06 Steering wheel buttons $70
04-08 Fuse Box Lid in engine Bay (has a scratch) $40 (plus stock lid) or $50 no stock lid
Comes w/ Both P2R TB & IM gasket $375
-Stock J32A3 Valve Springs & Retainers $125 OBO
-Stock J32A3 Crank $150 OBO
-Stock J32A3 Cams $150 OBO
JNC Headlights $600
Luminics H8 Bulbs $20
TE37 SL $3000
RS3 Tires $350 Picked up (will ship at buyers expense)
New Fake Rays Lug Nuts $80
Real Rays Lug Nuts & Valve Stems Make an offer (must be above $120)
SSR Lug Nut Adapters $30
Stoptech FR Rotors for Brembo Brakes $170
Hawk Brake Pads $75
Accord Fog Light Wire Harness $85
Custom Clock for 9500CI $60
Custom iPad Mini Bezel (PM me for details, minimun $500)
07/08 Ignition part $15
Base 3G TL Exhaust Inserts $20
Hondata- Complete Plug and Play $1400
Old Jan 6, 2014 | 08:19 PM
Mondo375's Avatar
How much for front Ingalls shipped to 33823?
Old Jan 6, 2014 | 09:31 PM
sockr1's Avatar
Pics of output of the fog lights?
Old Jan 6, 2014 | 09:54 PM
jevans06's Avatar
pmed
I don't have any pics showing the fog light output, but this thread has a picture of them on, its the 12th picture.
https://acurazine.com/forums/showthr...7#post14778477
Old Jan 7, 2014 | 12:16 AM
Noober's Avatar
would you happen to still have the center cap adapter and the te37 caps?
Old Jan 7, 2014 | 08:22 AM
mattpete's Avatar
I drool every time I see these wheels, they would be so sexy on my KBP
I get my bonus for 2013 in a month so if you still have them I'm all over it.
Good Luck!
Old Jan 9, 2014 | 07:59 PM
RTDDuone's Avatar
Asking price on the headlights?
Old Jan 9, 2014 | 10:42 PM
Ron A's Avatar
Administrator
It's posted in Post #3.
Old Jan 9, 2014 | 11:19 PM
jess2htx's Avatar
wait is 2 fog light harnesses or just 1?
Old Jan 10, 2014 | 11:02 AM
As Posted above:
This is a complete set of wires, includes everything to run a set of lower fog lights on 04-06 TL's.
Old Jan 10, 2014 | 11:14 AM
jess2htx's Avatar
Originally Posted by Skier4lyfe303
As Posted above:
sorry about that so you wont go a lil lower on the price or thats final price?
Old Jan 10, 2014 | 11:22 AM
$80 shipped, I can ship today (pending payment).
Old Jan 10, 2014 | 12:27 PM
ektyperhatch's Avatar
Pm'd you!
Old Jan 18, 2014 | 02:24 PM
mattpete's Avatar
pm sent
Old Jan 19, 2014 | 05:08 PM
pearl905's Avatar
C-mod grill shipped to canada?
Old Jan 20, 2014 | 01:14 PM
$240 shipped to Canada via USPS priority mail (around 6 business days).
Old Feb 2, 2014 | 01:15 PM
Mondo375's Avatar
Pm'd!
Old Feb 2, 2014 | 09:38 PM
jateelover's Avatar
Would you sell the bezel only for ipad mini?
Old Feb 2, 2014 | 10:06 PM
^No
Old Feb 4, 2014 | 05:57 PM
UPDATE 7
07/08 C-Mod Grille SOLD
Ingalls FR Camber kit SOLD
H&R Rear Sway Bar $150
Moog Rear Sway Bar Endlinks $45 (ill refund $25 when I get your stock ones back)
Ultra Rear Subframe Brace SOLD
Custom ITR Powder Coated Valve Covers & Strut Bar $500
Just Valve covers & IM cover $325
Just strut bar $200
04-06 Cluster Bezel $140
04-08 Steering column (driver side has broken tabs, creates a small gap when installed) $130
04-06 Steering wheel buttons SOLD
04-08 Fuse Box Lid in engine Bay (has a scratch) $35 (plus stock lid) or $50 no stock lid
IM w/ TB, along w/ P2R TB & IM gaskets $350
IM $200 comes with P2R IM Gasket
TB $150 comes with P2R Gasket
-Stock J32A3 Valve Springs & Retainers $50
-Stock J32A3 Crank $50 picked up, $100 shipped
-Stock J32A3 Cams $100
JNC Headlights SOLD
TE37 SL SOLD
RS3 Tires $300 Picked up, $425 shipped
Real Rays Lug Nuts & Valve Stems- Make an offer (must be above $120)
SSR Lug Nut Adapters $25
Rotors & Pads $220
Accord Fog Light Wire Harness SOLD
07/08 TL Type S Passenger Fog light housing $25
Custom Clock for 9500CI $40
Custom iPad Mini Bezel (PM me for details, minimum $500)
07/08 Ignition part $10
Hondata Flashpro - ECU w/ immobilizer & Key SOLD
Custom Boomslang harness & Hondata CAN BUS Connector cable for 04/05 to 07/08 TL MT ECU $300
Old Feb 5, 2014 | 02:34 PM
Mods please close, I have put the remaining items in a new FS thread. This can be found here:
https://acurazine.com/forums/showthr...3#post14863583
space_boy
ILX
51
Aug 15, 2017 12:06 PM
HOWELLiNC
3G TL Photograph Gallery
24
Oct 8, 2015 03:15 PM
Sep 14, 2015 10:48 AM
oyayjoe
Sep 12, 2015 04:40 PM
Sep 4, 2015 08:03 AM
