CLOSED: 2003 Acura CL-S 6MT ABP ★★Location of Vehicle : Edmonton, AB, Canada★★
'03 ABP YA4-S 6MT
Year: 2003
Make: Acura
Model: CL
Price: $9600
Mileage: 105000
Color: Aegean Blue Pearl
Location (State/Prov): Can-AB
Year : 2003
Make and Model : Acura CL Type-S
Exterior Color : Aegean Blue Pearl (rare colour, best of the generation)
Interior Color : Black leather
Auto or Manual? : Manual 6-speed
Odometer Reading : 168000km (~105000 miles)
Description :
-I have owned this vehicle for over 8 years. Unfortunately, due to circumstances I need to sell it. I had a vision for how I wanted the vehicle to be 'complete', but I am not willing to put more time/money into it. I still drive it daily, so it is in working order, with a few problems (listed below), but all extras were purchased with the intent of direct install/compatibility. Parts listed have purchase price beside them (invoices/paypal statements available for almost everything listed).
-Clean title (active status)
This has everything a stock CL has:
-Power windows/locks/sunroof/heated mirrors, homelink garage opener, auto-dimming rearview mirror, black leather interior, HID headlights, heated memory seats/mirrors.
-Estimated 280hp/260lb·ft with 3.5L and complementary mods. Will go over 300hp if extras are installed (higher flow heads/intake manifold)
-Currently running -2.4º/-4.5º camber F/R to fit wheels
Issues :
-3rd gear grinds on entry - suspected misaligned clip
-HVAC door stuck - needs to be run in front defog mode
-Rear driver wheel rubs - haven't rolled 1/4 panels yet
-OEM location for radio is empty
-Shift boot needs to be refitted
-While the car is completely driveable, it would likely go best to a home that could install the extras and also fix these issues
Parts List :
Interior
Hertz 6.5" component front, 6.5" coaxial rear speakers, baffles & rings $360.00
Dayton Audio RSS265HO-4 10" 600W RMS 4ohm sub w/ custom ported box $200.00
Elemental Designs nine.4 65Wx4 RMS speaker amp, Phoenix gold ryval v8001 600W RMS sub amp $400.00
Big 3 upgrade w/ 0 gauge wire, fuse holders, battery terminals $120.00
Alpine IVA-W505 touchscreen dvd double din w/ bluetooth & nav $320.00
Metra axxess steering wheel control $55.00
Boyo VTK350 rear camera $40.00
Clifford 5702 2-way remote starter/alarm $250.00
OEM Acura CL navi dash $90.00
OEM Acura TL rear seat heater vents $57.00
PE Tuning short shift kit $200.00
XLR8 aluminum pedal set $115.00
OEM CL door checkers $30.00
All-season mats $20.00
JDM Honda S2000 VGS steering wheel w/ RSX airbag, can be sold with this steering wheel (comes with stock steering wheel) $1,000.00
B]Interior total $3,257.00 [/B]
Exterior
Custom molded OEM TL lip kit w/ new paint on front/rear bumpers, rockers, mirrors and xpel paint protection $3,200.00
M3 style painted trunk lip spoiler $100.00
20% front/5% rear tint $240.00
Hella Micro DE foglights $140.00
3000K HID h3 bulb fog kit $54.00
HIR highbeam bulbs $60.00
Airhorns $32.00
XXR 527 18x8.75" +35 dark bronze w/ 225/40R18 tires, can be sold with stock wheels, but camber/alignment set for the XXR's $800.00
Exterior total $4,626.00
Mechanical
OEM Acura 02 MDX J35A3 3.5L motor swap $1,600.00
OEM Honda Odyssey 130A alternator $56.00
NGK Laser iridium spark plugs $58.00
UR underdrive pulley $170.00
Gates belts #40425, #60441 for UR pulley $40.00
Aasco lightweight flywheel $475.00
Clutchmasters Stage 3 clutch/pressure plate/throwout bearing $740.00
Corsport aluminum shifter bushings $30.00
XLR8 75A engine mounts $305.00
Custom poly filled transmission mounts $8.00
AEM cold air intake $250.00
Comptech headers $600.00
Straight pipe axle-back w/ Magnaflow tips $200.00
OEM CL timing belt/water pump/tensioner $300.00
Ingalls stiffy engine damper $160.00
OEM CL clutch slave w/ damper removed $60.00
OEM CL clutch master $55.00
Moog inner/outer tie rods $100.00
Ingalls camber adjustable front control arm 13920/rear links 38720 $450.00
Progress 24mm rear sway bar $170.00
Energy greaseable sway bar body mounts $50.00
H&R 51858 lowering springs $250.00
Koni sport (yellow) rebound adjustable struts $520.00
Timken wheel bearings $58.00
OEM Acura Legend Type II front 2-piston calipers $240.00
OEM CL manual transmission gears/syncros $1,800.00
Mechanical total $8,745.00
Extras (not installed)
OEM Saab 9-3 painted lip spoiler (new) $200.00
OEM 01 CL headlights, painted housing (used) $300.00
OEM 03 CL tailights (half red/half clear - used) $300.00
OEM CL J32A2 heads w/ KMS valvesprings (used) $450.00
ARP headstuds (used) $270.00
OEM TL J37 intake manifold (new) $350.00
OEM MDX manifold spacer (new) $50.00
Blox 76mm throttle body - for use with TL manifold (new) $238.00
P2R throttle body/manifold gaskets - for use with TL manifold (new) $241.00
OEM Acura RL advics front calipers for BBK w/ custom mounting bracket (used) $380.00
Rebuild kit for RL calipers & rear calipers w/ EBC greenstuff pads (new) $110.00
EBC rotors front GD7122, rear GD7146 - for use with RL big brake kit (new) $400.00
Russell stainless steel brake lines - used with RL BBK (new) $95.00
73mm -> 64.1mm aluminum hub rings - used with aftermarket wheels (new) $12.00
66.1mm -> 64.1mm aluminum hub rings - used with 350z rotors (new) $13.00
Tokico blue struts (used) $310.00
Neuspeed short shift kit (used) $87.00
Innovative 60A engine mounts (used) $320.00
NRG engine dampers set (new) $150.00
OEM CL navigation (used) $380.00
Dom's unit for OEM CL nav (used) $105.00
Metra dash kit for double din (new) $25.00
Omnipower 21mm quickclutch master cylinder - reduces clutch pedal height/throw (used) $130.00
Custom parts for swaybar endlinks (new) $200.00
Various OEM parts (new/used) $-
3rd gen TL wheels w/ studded winter tires - needed to clear RL BBK, can be sold with this setup (comes with XXR 527 wheels) $560.00
Extras (not installed) total $5,676.00
Total modifications $22,304.00
Asking Price :
-$9600USD ($12000 CAD based on 1.25 exchange) with almost everything including extras (at this time, car must be sold with all extras - minus VGS steering wheel and TL wheels)
-Anything listed in the extras section can be sold separately. Nothing currently installed on the car will be sold separately. Separate part out thread for more info/pricing on parts. All parts pricing is in USD, buyer covers shipping and paypal fees.
Contact Information :
Please send a PM/reply to this post if you are interested. No Trades. A cleaner mod list can be emails in XLS format if needed.
Pictures :
Attachment 102638
Attachment 102639
Attachment 102640
Attachment 102641
Attachment 102642
Attachment 102643
Attachment 102644
Attachment 102645
Attachment 102646
Attachment 102647
Attachment 102648
Attachment 102649
In accordance with the Members Cars For Sale Forum Rules and Regulations offers of parts, or requests for parts, are not allowed in this forum.
If the OP decides to go back to stock he will have to start a new thread in the main forum, and he can post that information here with a link to the new thread. Conduct your parting out business in the linked thread, not in this thread.
Do not send PM's to the seller unless you are invited to do so.
Any parting out discussions posted above have been deleted, and future parting out posts will be deleted without notice.
Love that CL! Had just seen it on a autotrader type site yesterday and was drooling. I've been looking for the j37 zdx intake manifold swap the last week and researching how to install it. Sent you a PM about it and the TB
Question
HEY THERE BUDDY
i have a question does the saab 9-3 spoiler fit the Cl? I just wanted to make sure
thanks in advance!!
thanks in advance!!
The OP hasn't updated the thread since 03-18-2016, and hasn't logged in since 06-16-2017.
This thread is closed due to lack of updates or bumps by OP.
You can send a PM if you think there's a chance, and the OP can PM me with a link to this thread if he/she wants this opened.
