How to install Type-S trunk spoiler with 3M tape?
Old May 1, 2017 | 09:57 AM
mazen222's Avatar
I finally got a used Type-S trunk lip that i want to install on my Base 2007 TL.
I don't want to drill holes and all, so i'm sure some of you used a 3M double sided tape to install this.
Can you please share some instructions or tips based on your experience?
From what i saw, the inner flat surface of the spoiler will not fall flush with the trunk, so i am wondering how/where you applied the tape?
Thanks,
MM
Old May 3, 2017 | 12:38 PM
mazen222's Avatar
Anyone? Did you all install this by drilling holes?
Old May 3, 2017 | 12:42 PM
i viewed this thread the other day; but didnt understand how it isnt flat? cuz that's what I would do for an OEM type-s spoiler, just 3M tape it.
Old May 3, 2017 | 12:52 PM
mazen222's Avatar
Here, I might be wrong but it looked like the surface i highlighted below would not be flush with my trunk?
PS. I did remove the bolts and green/white plastic alignment guides
Old May 3, 2017 | 12:57 PM
understood now! seems like you do have too drill for OEM. as that's the only way, i would feel comfortable it wouldnt fall off
Old May 4, 2017 | 06:45 AM
08KBP_VA's Avatar
^agree 100%. It might stick for a while but will come off due to weight. Also since you wacked off those bolts can you replace them to install? The tape they use is just to make sure edges stay flush and to limit water from going underneath and ponding.
Old May 5, 2017 | 11:08 AM
mazen222's Avatar
Alright, i was hoping to avoid the drilling and potential rusting that will come with it later... but i guess i'll have to be careful.
Thanks,
MM
Old May 5, 2017 | 01:55 PM
BreezyTL's Avatar
Drill it then plasti dip it to seal it or use clear nail polish. Or even get some clear from a local paint shop.
Old May 5, 2017 | 02:24 PM
01acls's Avatar
Inlew of clips and nuts in this situation you can glue the lip down with polyurethane structural adhesive. Just put a dab at the front corners and a bead across the entire lip at the mounting hole areas as marked by you in the pic.
Follow manufacturers curing time to ensure full adhesive strength before removing the masking tape that you will use to hold the lip in place while the adhesive is setting.
Clean off any adhesive that's oozed out from the lip with automotive tar remover.
Be sure to use 3M double side tape for the edges where applicable.
Old May 5, 2017 | 02:31 PM
01acls's Avatar
Actually, the front corners are probably for the 3M tape so don't use the adhesive there.
Old May 6, 2017 | 05:26 PM
guitarplayer16's Avatar
I installed my Type-S spoiler a few months ago, with only 3M tape.
I just put the tape where the old tape (which sucked to remove) was.
Old May 8, 2017 | 10:54 AM
mazen222's Avatar
Ah nice, thanks for highlighting it. So is the spoiler flush with the trunk using this method? Also, I was under the impression that whats there was the gaskets to avoid water going inside?
Old May 8, 2017 | 11:55 AM
If by flush you mean there's no edge from the spoiler to the trunk lid, no it won't be flush. Due to the thickness of the 3M tape there's probably less than a mm, but that's really negligible.
If I remember correctly, the OEM double sided tape was super thin compared to the 3M tape I bought, but that's okay because Acura used bolts and bolts in addition to the double sided tape.
There are no gaskets on the spoiler; the tape itself kinda acts as a gasket to *prevent* water from going inside.
I installed my spoiler in the January cold too, probably not smart but I don't see it coming off
Old May 9, 2017 | 10:39 AM
devensd54's Avatar
I put a spoiler on my 2007 Type S last Fall. I used 3M tape and the spoiler shows no sign of loosening. I use a pressure washer to clean the car weekly and I spray the trunk/spoiler as hard as any other section of the car. It is not going anywhere--that was a New England winter and seven months ago. In short, I think the tape is an easy, low cost solution.
Old May 9, 2017 | 02:57 PM
mazen222's Avatar
Cool, where did you apply the tape?
Old May 10, 2017 | 06:31 AM
devensd54's Avatar
The tape was applied slightly inside the entire front and rear span of the spoiler. You cannot see the tape and the spoiler appears flush to the truck lid. As I mentioned, I don't envision this coming off in the near term.
