Acura: RLX News
Old Mar 17, 2017 | 08:22 AM
  #4921
fsttyms1's Avatar
Originally Posted by iforyou
^ That.
The ZDX and TL are ill-proportioned. Not saying that with proper proportions, they will look stunningly good. But the proportions make things much worse....remember all that front overhang? That's one issue coming from bad proportions.
1 thing i have never understood is why someone hasnt reversed the trans layout on a FWD vehicle. I dont see why they couldnt design the trans to output in front of the motor instead of behind, thus shifting the wheels ahead of the motor, allowing the motor to sit further back, and giving it better weight/balance and allowing designers to shorten overhangs.
Old Mar 17, 2017 | 12:56 PM
  #4922
iforyou's Avatar
You'll Never Walk Alone
That's an interesting question and I never really thought about that. I think most FWD cars nowadays have transversely mounted engine, with the tranny sticking out to the side instead of front or behind of the engine?
Anyway so I just googled a bit and found that what you described is called mid-engine, FWD layout, where the tranny sits in front of the engine. There's a short blurb about this layout here:
Front-engine, front-wheel drive layout | Tractor & Construction Plant Wiki | Fandom powered by Wikia
It basically says this was actually the earliest arrangement for FWD cars and its main drawback is that there's not enough weight sitting on the front wheels for traction and handling. Citroen later found a solution to that by swapping the diff and tran around. They have since been using that layout in some models until the 80's.
Here's a picture:
Nowadays, FWD cars with a longitudinally mounted engine is really rare. I could only think of Audi and Subaru. For Subaru, most of their cars are AWD anyway, and we all know Audi also uses Quattro is all of its models. This rules out the possibility of having the tranny in front of the engine, unless you mount the engine so high up so the drive shaft can go underneath.
Old Mar 17, 2017 | 01:16 PM
  #4923
Costco's Avatar
Manufacturers mostly went to transverse engines for better packaging, efficiency, cost, and safety. More interior room, fewer drivetrain losses and components, and easier to control when traction is lost.
Having a setup like that above is new to me. It looks horribly impractical, which is probably why it isn't popular today.
Old Mar 17, 2017 | 01:18 PM
  #4924
TacoBello's Avatar
and maybe it's just me, but I get the feeling it would make working on the engine all that much more difficult.
Old Mar 17, 2017 | 02:49 PM
  #4925
RDX10's Avatar
This was exactly what came to mind immediately. By pushing the engine back like that, it would make working on the engine VERY difficult and in a crash setting it would probably intrude on the cabin space. The other issue is that vibrations are going to be much harder to stop and NVH would be terrible. Though I can see some huge bonuses of doing that.
Old Mar 17, 2017 | 03:01 PM
  #4926
jwong77's Avatar
Midnight Marauder
The 2nd Gen Legend and 1G RL and Vigor/TL were like this right? I remember there was talk about the driveshaft going through the oil pan or something like that making it difficult to do some repairs.
Old Mar 17, 2017 | 03:42 PM
  #4927
MSZ's Avatar
MSZ
Lola
Yep, FWD longitudinal platform.
And my personal favorite, wasn't sold as an Acura for some strange reasons, the Honda Rafaga:
Old Mar 17, 2017 | 10:19 PM
  #4928
jwong77's Avatar
Midnight Marauder
Thats great! Look at the attention to detail, looks like for better weight distribution, they put the battery in the back of the engine compartment like some actual RWD cars. Honda really cared about engineering back in those days.
Old Mar 18, 2017 | 01:40 PM
  #4929
fsttyms1's Avatar
Front-engine, front-wheel drive layout Tractor & Construction Plant Wiki Fandom powered by Wikia
Here's a picture:
No, thats not the same or what i was referencing to. The trans always has stuck out to the side of the engine, then it gets transferred to the differential which has always sat behind the motor. (talking Transversely mounted engines) to which the axle/axles then pass behind the motor. Its not that they would be moving the trans to sit in front of the engine, or making the motor longitudinal, the trans itself wouldnt move 1 bit, The output of it where the differential sits would be the only thing that would have to move, from aft of the trans to the front of the trans to pass the engine on the front.
Old Mar 20, 2017 | 08:16 AM
  #4930
Looks like an E36/Alfa/Evo VI hybrid, but looks great.
Old Mar 20, 2017 | 10:31 AM
  #4931
My E46 Xi had the front CV axle go through the oil pan since the front diff was bolted to the side of the pan. It was a PITA to service.
Old Mar 20, 2017 | 11:18 AM
  #4932
Legend2TL's Avatar
AZ Community Team
Here's a picture:
That's an unusual setup for sure. The other kind of odd geabox is the Lambo Countach where the gearbox was in front of the V12 and the diff was at the back of the motor.in the oil sump A transmission output driveshaft went longitudinal through the bottom of the motor.
+1, yep transverse engines work out pretty well for all the reasons you cited.
Yes, the 2G Legend and 1G RL had the front diff that was next to the oil pan and the one driveshaft went through the oil pan.
I've occasionally wondered the same thing, why the halfshafts always go behind the block instead of in front where the engine would shift back some for more crash absorption in front and better weight distribution.
Old Mar 23, 2017 | 09:03 AM
  #4933
fsttyms1's Avatar
Ive wondered that for about as long as i have been tinkering/modding FWD vehicles, especially when the large front overhang/heavy nose fwd discussions come up.
Old Mar 27, 2017 | 05:57 PM
  #4934
iforyou's Avatar
Even Legend2TL doesn't know????
Old Aug 10, 2017 | 04:54 AM
  #4935
TSX69's Avatar
Exclamation MMC Reveal Video
GLOBAL REVEAL: 2018 Acura RLX
Old Aug 10, 2017 | 08:11 AM
  #4936
kurtatx's Avatar
Azine Jabroni
Old Aug 10, 2017 | 08:49 AM
  #4937
Looks like they put the TLX drawings into a copy machine and hit the enlarge button.
Old Aug 10, 2017 | 09:30 AM
  #4938
MSZ's Avatar
MSZ
Lola
Old Aug 10, 2017 | 09:43 AM
  #4939
TSX69's Avatar
Lightbulb Release
Acura Reveals Striking New Design for 2018 Acura RLX; Debut Set for Monterey Automotive Week - Acura News
Aug 10, 2017 - TORRANCE, Calif.
  • 2018 Acura RLX adopts new Acura design direction including signature diamond pentagon grille
  • Supercar inspired 377-horsepower RLX Sport Hybrid with Super Handling All-Wheel Drive™ has been further optimized based on NSX learnings
  • Standard AcuraWatch™ enhanced with Traffic Jam Assist, an Acura first
Acura today unveiled a redesigned 2018 Acura RLX reflecting the brand’s new Precision Crafted Performance design direction to create a more substantial presence for Acura’s top-of-the-line luxury sports sedan. The 2018 Acura RLX will make its public debut during the prestigious Monterey Automotive Week, August 15-19 on the Monterey peninsula. The new RLX incorporates design cues to showcase its performance capabilities, including Acura’s signature diamond pentagon grille, a more sculpted hood, new wheel designs, bold, newly designed LED taillights, dual exhaust finishers and a gloss black rear diffuser.
The 2018 Acura RLX is the most sophisticated and best performing Acura sedan ever, with Sport Hybrid Super-Handling All-Wheel Drive™ (Sport Hybrid SH-AWD™) technology, shared with the NSX supercar, that creates a powerful and precise driving experience unmatched in the segment. Acura has simplified the RLX trim structure to make the brand’s innovative Sport Hybrid technology more desirable and accessible streamlining the offering to 2 well-equipped variants. The new 2018 Acura RLX will go on sale in November.
The 377 total system horsepowersup1 RLX Sport Hybrid seamlessly integrates a direct-injected V-6 with 3 electric motors and Super Handling All-Wheel Drive™ for instant acceleration, precise handling, outstanding all-weather performance and excellent fuel economy. Based on developments from the NSX, the RLX Sport Hybrid powertrain and dynamic handling has been further optimized.
The 310-horsepower RLX with Precision All-Wheel Steer™ is now mated to a new 10-speed Automatic Transmission (10AT) delivering a more refined driving experience, as well as improved acceleration and passing times.
“This redesign of the 2018 Acura RLX is transformational, creating road presence and styling that better reflect underlying performance capabilities of the vehicle,” said Jon Ikeda, Acura vice president & general manager.
Standard features on the 2018 RLX Sport Hybrid include premium Krell Audio System, Surround View Camera, parking sensors, LED fog lights, remote engine start, ventilated and heated front seats, heated rear seats and steering wheel and more.
The 2018 RLX features the unique AcuraWatch™ suite of technologies, as standard equipment, and has been enhanced with the addition of Traffic Jam Assist, a 1st for Acura. Working in conjunction with Adaptive Cruise Control with Low Speed Follow, Traffic Jam Assist helps reduce driver stress in highly congested traffic situations by helping keep the vehicle in its lane and a set interval behind a car detected ahead.
AcuraWatch™ also includes Collision Mitigation Braking System (CMBS) with automatic emergency braking, Lane Departure Warning (LDW), Forward Collision Warning (FCW), Lane Keeping Assist (LKAS), Adaptive Cruise Control (ACC) with Low-Speed Follow and Road Departure Mitigation (RDM). AcuraWatch uses a millimeter wave radar and monocular camera sensing technology to detect other vehicles as well as lane markings and can help intervene to prevent or mitigate the severity of a collision.
The 2018 Acura RLX is complimented by 3 new exterior colors including 2 premium paint offerings – Brilliant Red Metallic and Majestic Black Pearl. Inside, the 2018 Acura RLX receives upgraded materials and touchpoints including a completely redesigned seat featuring high-contrast piping and stitching, as well as a new Espresso interior option, which adds sophistication to an interior with class-leading space and comfort.
The 2018 Acura RLX will be featured at multiple events throughout Monterey Automotive Week including the Carmel-By-The Sea Concours on the Avenue on Tuesday, August 15 and The Quail, A Motorsports Gathering, on Friday, August 18.
For More Information
Consumer information is available at
http://www.acura.com. To join the Acura community on Facebook, visit http://www.facebook.com/acura. Additional media information including pricing, features and high-resolution photography is available at http://www.acuranews.com/channels/acura-automobiles.
About Acura
Acura is a leading automotive luxury nameplate that delivers Precision Crafted Performance, an original approach to technology and design that creates a new driving experience.
The Acura lineup features 6 adistinctive models – the RLX premium, luxury sedan, the TLX performance luxury sedan, the ILX sport sedan, the 5-passenger RDX luxury crossover SUV, and the 7-passenger Acura MDX, America's all-time best-selling 3-row luxury SUV. Last spring, Acura launched its next-generation, electrified NSX supercar as a new and pinnacle expression of Acura Precision Crafted Performance.
Old Aug 10, 2017 | 09:53 AM
  #4940
wait, is that the Kia Stinger!?
Old Aug 10, 2017 | 10:27 AM
  #4941
atl7's Avatar
The new seats look nice, but the dual screen layout/design is looking VERY dated. Not a fan of the headlights or taillights, they look bloated and sharp for the most part but then they have rounded edges and it just doesn't mix for me. Looks very meh to me, kind of reminds me of a Kia.
Old Aug 10, 2017 | 10:48 AM
  #4942
AZuser's Avatar
_
Originally Posted by TSX69
Originally Posted by Jon Ikeda
".... then we introduced the TLX which included not only the diamond pentagon grille, but an exciting new A-Spec that signals Acura's commitment to luxury performance sedans."
But A-Spec doesn't offer any real performance over non-A-Specs trims.
As for updated RLX, it does look better than the current design, but not by much. Not going to change sales direction. Might slow decline or even stabilize sales though.
Originally Posted by Jonathan Rivers
The team worked really hard
And this was the best they could come up with?
Old Aug 10, 2017 | 11:47 AM
  #4943
Old Aug 10, 2017 | 12:33 PM
  #4944
AZuser's Avatar
_
Side profile looks good. Now just get rid of all the chrome trim along the lower front, side and rear.
And they really need to rework that interior. Simplify it like how the 10th gen Accord's is.
Old Aug 10, 2017 | 01:55 PM
  #4945
CCColtsicehockey's Avatar
377hp
If they really wanted to make a statement they need to get that number in the 400s for their top sedan.
Old Aug 10, 2017 | 02:05 PM
  #4946
AZuser's Avatar
_
377hp
Or just market it as being as fast as a BMW M5
Old Aug 10, 2017 | 02:17 PM
  #4947
MSZ's Avatar
MSZ
Lola
"Introducing the 2018 Acura RLX, the most powerful Acura sedan ever made, faster than the BMW E34 M5 in a straight line."
Old Aug 10, 2017 | 06:10 PM
  #4948
Mizouse's Avatar
Old Aug 10, 2017 | 06:46 PM
  #4949
BurnabyTSX's Avatar
A-TSX Oldie
Is it just me, or does the Honda Accord look more upscale than this...?
Old Aug 10, 2017 | 06:55 PM
  #4950
AZuser's Avatar
_
Interior design/layout? Definitely.
Exterior? Need to see the new Accord in person.
Old Aug 10, 2017 | 08:56 PM
  #4951
oonowindoo's Avatar
The center console still looks pregnant. Too little too late. That Navi map stil looks like it s from early 2000.
Old Aug 10, 2017 | 10:09 PM
  #4952
svtmike's Avatar
Modern version of
Old Aug 10, 2017 | 10:14 PM
  #4953
SSFTSX's Avatar
they said there are improvemetns to the hybrid system based on NSX experiance.
new MDX hybrid 0-130mph in 32 second. pulling 0.87G. You wont find any other 7 seater SUV with similar high speed performance and handling from skinny 245 size all season tires on 20 inch rim with super quiet refinement.
TLX already beating in quietness and comfort BMW 3 and Audi A4.
Nothing prevents RLX to beat MDX in handling and performrnace with superior comfort and refinement over the top of TLX. There is no doubt about Made in Japan quality and reliability for those who understand. This will permanently shut Yeh and his hyundai Genesis / Germanic crap that she was spouting every month.
BMW 540Xdrive only 0.88G from 19inch rim. BMW put limiter under 130mph. they dont want to hide the high speed aerodynamics inefficiency. Civic Type-R 0-140 mph in 28.5 seconds and its hatch not even a aerodynamic Coupe.
fhttp://www.caranddriver.com/reviews/2017-bmw-540i-xdrive-test-review
2018 Acura RLX Photos and Info | News | Car and Driver
The company claims the new transmission will improve the RLX’s acceleration; for reference, a front-drive RLX with a six-speed automatic ran from zero to 60 mph in 5.8 secondsin our testing.VIEW PHOTOS
Old Aug 10, 2017 | 10:28 PM
  #4954
SSFTSX's Avatar
there is newer infotainment system in development.. It still has Krell Audio system as standard. Honda is rich firm. they can provide options as standard.
Acura Precision Cockpit Previews Acura's Future Interface ? News ? Car and Driver | Car and Driver Blog
We spent a fair amount of time poking around the system with the folks who designed it and found that it works fairly intuitively, certainly more effectively than Lexus’s clumsy Remote Touch interface. Other trick features of the Precision Cockpit include graphics and colors that change according to the chosen drive mode—white for Snow, blue for Comfort, Red for Sport, and Orange for Sport Plus. The display ahead of the driver uses what Acura calls a 3D engine to support a dynamic layout that shows other cars, objects, pedestrians, cyclists, and more. When autonomous driving becomes a thing in Acuras, it will be able to recognize other vehicles being driven in autonomous modes via vehicle-to-vehicle communications.
Old Aug 10, 2017 | 10:41 PM
  #4955
oonowindoo's Avatar
2018 Acura RLX Photos and Info News Car and Driver
Stop bring rims and tires into conversation. You are not allowed to use word, rims, wheels, tires, upgraded,superior and aero anymore. I wish i was a MOD
Old Aug 10, 2017 | 10:44 PM
  #4956
oonowindoo's Avatar
Acura Precision Cockpit Previews Acura's Future Interface ? News ? Car and Driver Car and Driver Blog
In development means nothing. By the time it is released, all cars will be driving by themselves.
Your argument makes 0 sense... Hey all the appliances are "standard" if you buy the house. Instead of $500,000, i now charge you $600,000 but hey standard right?
Old Aug 10, 2017 | 11:04 PM
  #4957
SSFTSX's Avatar
All cars will not have same quality and sophistication. Honda i always ahead of others in real implementation of technology.
i havent heared they are charging more for this than current RLX. it will minor adjustments. this thing is coming practically fuly loaded with all the safety features. navigation is good enough consider it is secondary use than music system. people use music daily. while navigation is mostly out of town.
the closest you can come is Lexus GS F in red mica but that car has no road presence. RLX Is tall and wider stance. NO one is going to mistake RLX for TLX. it is such design. BMW/MB will have to give bargain basement leases on 5 series and E class.
Old Aug 10, 2017 | 11:09 PM
  #4958
SSFTSX's Avatar
Road presence and styling to match performance. if they removed the speed limitor and put perofrmance tires and rims. it will go all the way to 200mph.
Acura Reveals Striking New Design for 2018 Acura RLX; Debut Set for Monterey Automotive Week - Honda News
Old Aug 11, 2017 | 02:38 AM
  #4959
Will Y.'s Avatar
Registered but harmless
The RLX is transformed, all right... into a Buick.
Old Aug 11, 2017 | 02:46 AM
  #4960
MTEAZY's Avatar
brahs be jelly
I give up on this brand. The front end is so ugly.
