Dropitlow
Old Feb 13, 2017 | 06:08 PM
TheWrench116's Avatar
FLETCH
Dropitlow
so i got the coilovers (by Megan) on last week.... after waiting till 155k miles to do new suspension i wish id have done this a lot sooner.
HOWEVER THE ONLY REASON IT WORKS WELL IS BECAUSE OF MY CUSTOM REAR UPPER CONTROL ARMS. additional $400.00
my camber settings in the rear are .9 degrees factory spec is 1 if it were dropped 2 inches without the custom kit id looked stanced and handle for shit. if you like stance life dont talk to me. i wont like you.
Old Feb 15, 2017 | 06:03 PM
FLETCH
I think it's going to look great with the summer setup
Old Apr 4, 2017 | 03:49 PM
allmotorap2's Avatar
Looks much better! This is how it should of came stock honestly. I have the BC's and couldn't go to low due to the bad camber in the rear.
Old Apr 4, 2017 | 03:50 PM
Old Apr 5, 2017 | 12:35 PM
FLETCH
i got a set of upper adjustable arms made specifically to correct the rear camber issue. I'm able to go as low as i want and still maintain proper geometry.
Old Apr 5, 2017 | 08:16 PM
Definitely jealous. I'm at -3 right in the back 😒
Old Apr 7, 2017 | 11:59 AM
FLETCH
call me and i can help point you in the right direction. im sure the shop that made mine would make another set.
Old Apr 7, 2017 | 12:37 PM
hues10's Avatar
Oh yeah Wrench, well I am going to put a set of those Eibach Spring things on, and then whip your car...... Well, it won't touch your car cause you may as well have just built a custom car kit thing by the time you are all done with it. Looks good though, and probably drives even better.
Old Apr 13, 2017 | 12:51 PM
FLETCH
That feeling you get when you quadruple the posted recommended speed For an exit ramp!!!
Old Apr 13, 2017 | 12:55 PM
rockstar143's Avatar
15mph off ramp?
Love that first post OP...wit and sarcasm aren't lost on me.
Old Apr 14, 2017 | 08:14 AM
FLETCH
Yeah15 went 60
Old Apr 14, 2017 | 09:08 AM
because, you know...35 is pretty slow for an off ramp but then I did the extrapolation and holy shit 140 would be impressive!
Old Apr 15, 2017 | 08:24 PM
FLETCH
Roads seriously suck around here need to repave the whole damn state.
Old Apr 17, 2017 | 06:21 AM
my neck hurts now :'(
Old Apr 17, 2017 | 09:23 PM
FLETCH
Running that low life
Old Apr 17, 2017 | 10:04 PM
TacoBello's Avatar
Polish them headlights, son!
you can DIY, and it'll make your car look new again!
Old Apr 18, 2017 | 06:16 AM
I love that driveway.
Old Jun 14, 2017 | 07:24 PM
CSmoney28's Avatar
CSmoney28
Just ordered the BC Coilovers, Progress Rear Sway Bar, and Prothane Complet Kit. Any feedback on these products?
Old Jun 15, 2017 | 07:08 AM
BC Racing is a good brand, I'm sure they'll be good.
Progress sway helped on my 3G for cornering.
Prothane...not a fan of going harsh on anything rubber but I'm not sure if that's what they do or just better handling.
Old Jun 15, 2017 | 12:35 PM
FLETCH
If you don't have a means to adjust the rear camber you're going to have a bad time when you drop the car. My Factory camber bolts wouldn't even keep my rear suspension in spec with Factory components at factory height. If you run into issues shoot me a text or phone call.
Old Nov 8, 2017 | 03:50 PM
CSmoney28's Avatar
CSmoney28
I finally got my BC Racing Coilovers & Progress Competition Rear Anti-Sway Bar installed. I put the Anti-Sway Bar at the most aggressive setting and it makes a huge difference. You can really really feel the rear end tighten up. It almost feels like more power is in the rear end now. How long did it take your coil overs to settle? I keep adjusting because at an inch and a half from the top of the adjustment I was scraping. Now I’m at a half inch from the top and I’m good no scraping. But my rear seems to have settled more where it’s flush with the tire and the front is one finger from the tire. When it was scraping both front and rear were tucked. I’ll take picture when the weather clears up.
