19x8.5 or 19x9? post your pics
Old Nov 24, 2016 | 08:27 PM
dwalk103's Avatar
short time reader first time poet. previous wrb wrx owner first time acura owner. hoping you folks will post your thoughts and post your pics on 19x8.5 and 19x9's for the ilx as I hope to soon be an owner of a set of vossen vfs2's. questions in mind seeking answers: tires options (most rubber without rub); spacer options: are they even needed with wheel size?; whos dropped? how much?
POST YOUR PICS
Old Nov 24, 2016 | 08:29 PM
dwalk103's Avatar
Old Nov 24, 2016 | 10:26 PM
iRaw's Avatar
19X8.5
+30 Offset
Stock Height
235/35/19 Pilot Super Sports
Tires sit almost flush with fender. Maybe a few MM of "Poke Out" The rear tires slightly rub on hard corners and steep driveways. I'm sure a mild drop will cause slight bit of camber and tires will tuck in perfectly with no rubbing.
Old Nov 27, 2016 | 10:02 AM
holografique's Avatar
^ Wow. Proper.
If you don't mind me asking, what wheels are those? And how is the ride quality / road noise compared to the OEM A-spec 18's?
Old Dec 6, 2016 | 03:41 PM
aomechmarine's Avatar
I'm surprised it rubs at stock height... But it would probably rub about the same amount with a spring drop 1 to 1.5 inches.... maybe not with a dialed in coil-over drop... The reason being that you have somewhat of a high offset... OP if you are going for 19x9, You are gonna want a much lower offset. like probably at LEAST +20, or maybe more like +15... if you had the same wheels as the pictured car, but in 19x9 you would have to get +25 (more or less) for it just to sit the same. So no rubbing means +20. Rough educated guess, YMMV.
I have test fit 19x9 3 piece wheels on the car before, looked amazing. I have a 1,5 inch spring drop... The offset was something +15 or +20, it was a while ago, don't remember... actually... it MAY have even been +10 or a weird size close to that... Every wheel will be different and they may come in slightly weird offsets too like +17 or +23 or something
Old Dec 7, 2016 | 04:25 PM
C1Forged's Avatar
Originally Posted by iRaw
19X8.5
+30 Offset
Stock Height
Lowering your car will not prevent rubbing. The control arm articulates the same way regardless of static height. It only has one arc of movement and so regardless of starting position, it will have the same end position. The only way to actually change the camber arc is with an adjustable control arm.
You have it backwards. Lower the offset, the more poke you get. In order to sit the same in regards to being flush with the fender lip, he would need a 19x9"+36 offset, which would end up flush with 19x8.5" +30 [19x8.5 +30 = 78mm poke w/ 138mm inset, 19x9 +36 = 78mm poke w/ 150mm inset]. In order to tuck more and prevent rubbing, he would need an offset higher than +36 as it will be sunken in more.
Based on the specs of your 3 piece wheels, and having a slight drop, the wheels were more than likely poking out from the fender by 5-10 mm after the adjusted static camber.
Check using the link below and scroll to the bottom. Fender clearance is same for 9" +36 vs. 8.5" +30:
http://www.wheel-size.com/calc/?wheel1=235-35-19X8.5ET30&wheel2=235-35-19X9ET36&fcl=50mm&wcl=30mm&scl=50mm&sr=0mm
Old Dec 9, 2016 | 06:08 PM
i realized after that I didnt clearly explain myself, I was talking about 3 piece type wheels with lips... The black ILX in the pics in this thread has wheels that are "flat face"? I don't know the actual term... But they are not 3 piece wheels with lips... the wheels I test fitted had about a 3 inch lip. They fit EXACTLY flush, no poke. it was awesome... Deal fell through due to seller being kind of a douche about pricing and kind of trying to bait and switch on me...And actually I saw some cheaply priced 3 piece Work wheels that were 18x9 +38, which I'm pretty sure would fit flush as well... BUT not much of a lip.
i also use the website willtheyfit.com
Old Dec 9, 2016 | 06:32 PM
** To clarify, I never said that lower offset does not push the wheel out further... I just did not fully explain myself.
I was always under the impression proper dialed in dropping would help with preventing Bacon Fender type issues... and would help with rubbing, although I guess I can see how that doesn't really make sense when you are actually creating less clearance and travel space between the wheel and the fender well/fender......
But wouldn't the drop make the wheels angle in towards the car , creating naturak camber and other fore better clearance? Wouldn't the fenfer well rub less against a wheel that is slightly slanted like this \\\\\\ ) or like this(///////....versus the wheel being straight up and down..?
But wouldn't the drop make the wheels angle in towards the car , creating natural camber and therefore better clearance? Wouldn't the fender well rub less against a wheel that is slightly slanted like this \\\\\\) or like this (///////....versus the wheel being straight up and down..?
Old Dec 12, 2016 | 01:55 PM
C1Forged's Avatar
No worries, just wanted to clarify just in case OP was confused. 3 Piece is a whole different ball game all together, since lip sizes don't determine offset that much. Depending onn how the centers are cut, you can make up for extra lip, or take away.
You are correct that lowering the car does increase the static negative camber. However, it wont increase any more than the natural articulation of the suspension. Remember, that like a pencil attached to the end of a string that is anchored on one point, it follows one single circular path around the anchored point. It doesn't matter where on that circle you start [stock height, vs. lowered], you will still follow the same arc path when the suspension compresses/decompresses. The only way to increase the natural camber is to lengthen the lower control arm, shorten the upper control arm [wishbone suspensions], or shim the hub [Pie wedge chunk of metal].
Old Feb 5, 2017 | 09:15 PM
idelgado782's Avatar
Rohana RC7 19x9.5 +35 offset all around. Tires are 225/35/19 lowered on H&R Springs. No rubbing and didn't need a roll.
Old Feb 21, 2017 | 02:27 PM
aafdiablo's Avatar
New wheels 18x8.5 +35mm offset lowered on eibach prokit
Old Feb 28, 2017 | 02:05 PM
FZ427's Avatar
aafdiablo: Size of tires ?
Old Feb 28, 2017 | 04:24 PM
aafdiablo's Avatar
225/40/18
bf Goodrich g force comp 2 a/s
Old Apr 24, 2017 | 06:25 PM
Illex's Avatar
19X8.5
+30 Offset
Stock Height
Your ride is looking smooth. What kind of finish is on your wheels?
Old Apr 27, 2017 | 06:40 PM
Le7316's Avatar
Old May 5, 2017 | 02:20 AM
iRaw's Avatar
It's called "Hyper Black" Looks like a Black Chrome Color.
Some lighting makes the wheel look gunmetal and other lighting makes the wheel look shiny and Chrome-ish.
Old May 15, 2017 | 02:37 AM
looks like you are running a pretty thin and stretched tire tho... so maybe no rubbing, but a lot more risk of wheel curbing and wheel damage... wouldn't work for me... I drive too fast...and way too many vicious unforgiving potholes where I'm at.. wheels do stand out a lot on your ride tho, with that sizing you can see a lot more of the concave.
OP - do you just want style or performance or what? For style, bigger is better and this car does look sexy with some 19's ... the "safer" size at 19's is 19x8.5 because you can get a decent tire size that will protect the wheel pretty well.. but you are still risking more wheel damage then an 18 regardless.. I had a near blowout even with one of my 17's... I'm leaning more towards an 18x9... Any info that I could find said that anything wider then that isn't really adding performance, most likely taking away... on fact 18x9 may evenbe slightly too wide for optimum performance too...same for wider then 8.5 at 19 inch wheel... the proper "ratio" has to be maintained to improve/maintain peformance
Do I Need Plus-Size Tires? - Consumer Reports read the part about the Honda Accord. Blown out tires and bent wheels.
not saying you can't go bigger, obviously there are ways to make it fit. But you are trading grip, braking distance, hydroplaning resistance, amd some overall performance and MPG for looks. Depends on you tho.
I'd love the look, but I want both performance and looks.
Old Jul 2, 2018 | 10:02 AM
john_winn's Avatar
4th Gear
Originally Posted by Le7316
aye bro quick question, you got g37 wheels on the bottom pic right? what size did you get for the acura center cap??? im on the same i cant seem to find a replacement acura cap though
Old Oct 27, 2018 | 11:01 PM
oo3's Avatar
oo3
4th Gear
19x9.5
Sorry for the crappy phone pics.
19x9.5
235/35/19
Continental Extreme Contact
Old Jun 9, 2019 | 02:22 PM
Yos3z's Avatar
5th Gear
Work Equips 19x8.5 +39/+40 225/35/19 Tein’s coilovers. No rub and roll is needed. Rides good
Old Jun 9, 2019 | 02:47 PM
Yos3z's Avatar
5th Gear
Old Jun 10, 2019 | 02:43 PM
sobrien556's Avatar
6th Gear
Looks good! What trunk spoiler is this?
Old Jun 10, 2019 | 05:04 PM
Idk.ilx's Avatar
8th Gear
2015 ilx
I’m on 18x9.5 wed Kranze bazreias
Old Jun 11, 2019 | 08:17 PM
Yos3z's Avatar
5th Gear
Thanks, it’s oem. Full oem aero kit
2G CL Photograph Gallery
Nov 29, 2016 08:04 AM
