G-109: DIY-Eliminate LED Bulb Induced Hyper flashing WITHOUT LOAD RESISTORS
Old Apr 20, 2015 | 06:00 PM
  #1161
sauceja's Avatar
Desert Life Sucks!!
My main concern is why I can't get rear led's to work. They don't hyperflash.
They start blinking weird. With rear led's when I use left blinker I have the rear right and front left blink and some other odd symptoms. Craziest shit I've ever seen.
Old Apr 21, 2015 | 07:53 AM
  #1162
:scratchhead: sounds like you got some electrical gremlins... Have you tested by putting your incadenscent bulbs back in to see if the issue is still there? If so it's either your wiring going to the back trunk or the signal relay is iffy.
https://acurazine.com/forums/audio-b...orking-928077/
Check that thread, it talks about some broken wiring, that may or may not be related..
Old Apr 22, 2015 | 04:28 PM
  #1163
upnout's Avatar
RIP RBP
I have six of the .12 ohm resistors. I'll sell each one for $1.50 shipped
Mike
Old Apr 22, 2015 | 09:33 PM
  #1164
Mike
Considering they can be had for ~30 cents on digikey.com. that's quite a markup there buddy..
Also get that crap onto the Black Market where it belongs!
Old Apr 26, 2015 | 08:19 PM
  #1165
sauceja's Avatar
Desert Life Sucks!!
1.50 shipped is still not bad lol.
Yea my halogen rear bulbs have no issues. I gave up on rear blinker led bulbs couple years ago.
Although I found this thread again because I am re-visiting changing my switchbacks for different bulbs or for amber only.
Plus now that DRL led technology is a couple more years older I am looking into upgrading my led lights throughout.
Old Jun 13, 2015 | 01:47 AM
  #1166
stljim2005's Avatar
5th Gear
Mike
I'll take you up on this offer. I'll take 2 ! If you still have them.....
Old Jul 13, 2015 | 05:06 PM
  #1167
valco6's Avatar
Installed front LED turn signals last week, and just today was able to complete this mod. Thanks so much for the info, it worked fantastic and was relatively easy.
Old Jul 13, 2015 | 05:26 PM
  #1168
valco6's Avatar
By the way, I picked up a 2-pack of these resistors at Fry's for about 99 cents. I think normally they are like $1.50 but this package was the last so they marked it down. So far everything works fine, with headlights on and off.
Old Sep 7, 2015 | 10:12 AM
  #1169
MANDO28's Avatar
6th Gear
Does anyone have a .24 ohm resistor looking to do this mod
Old Oct 2, 2015 | 08:02 PM
  #1170
upnout's Avatar
RIP RBP
OK, since you are a moderator you move it kiss my....
Sorry, i'm not on this forum that much
If anyone is interested, i still have them.
PM me and i'll get an email
i'm not trying to make $, just trying to get rid of em
$1.25 each shipped
Mike
Old Mar 22, 2016 | 12:45 AM
  #1171
DesertMistTL's Avatar
Originally Posted by Roger555
Hey you guys that have a FRY's it looks like they carry it in some of there stores
Fry's Electronics |
just bought the ACME corner light switchbacks and bought these resistors from Frys. Comes in a pack of 2! Works perfectly.
If anyone is squeemish and wants someone to do it for them--LMK!
TIP: I had to hulk this relay out of its socket. Didnt know it was in there that hard... Then I had to use a thin flat head to get the circuit board out of the relay housing. I tried for 5mins with my fingers and gave up, used flat head and it popped off.
Old May 2, 2016 | 09:09 PM
  #1172
AbdullahSheikh's Avatar
3rd Gear
I live in Toronto and would like to do this mod, but I can't find any .12 ohm resistors. Can anyone help?
Old May 10, 2016 | 12:48 PM
  #1173
dbqtown's Avatar
Shout out to bSpecialist..!!
So soldering in two .12ohm or just one .24 will eliminate your hyper flash. I have an 08 type s led's all four corners and it flashes like it should now. No problems what so ever..!!👍🏻 you have to solder the two .12 in series though. Like he said before it should make a triangle
Old Jul 23, 2016 | 02:36 PM
  #1174
uneedkhoality's Avatar
Just did my flasher mod with a 0.24 ohm resistor and works great, thanks Roger555 and Vietxquangstah!
Old Aug 1, 2016 | 12:07 AM
  #1175
alexbach23's Avatar
Certified Acura Tech.
***Recently completed swapping the shunt resistor in mine...
==> A couple of weeks ago, I successfully completed uninstalling the recently installed (...but never-to-be-used-again!!) load-resistors and installing the shunt resistor I'd ordered from Digi-Key.com. Unlike some who'd ordered the resistors prior to me, I was able to ordered a single, 0.12ohm resistor for a couple of $s. My switchbacks are just as awesome as ever, and I don't cringe every time those damn energy wasting, heat dissipating load-resistors crossed my mind! I give my oath to never use another set of load-resistors again, whereas before I was unaware that there's such a simple fix to the hyperblink problem. But now, thanks to roger555, I won't have to sacrifice wasting useful electricity in my TL! Thank you roger555!!
Old Aug 12, 2016 | 12:58 PM
  #1176
Whdrms's Avatar
e92TL
I, too, experience this magic of resistor! Thank y'all!
Old Aug 12, 2016 | 01:32 PM
  #1177
Oh Sickest TL's Avatar
Jeff
I just mounted the resistors in the trunk with double sided adhesive . took like 5 mins
Old Aug 12, 2016 | 01:41 PM
  #1178
That's the wrong way of doing it and the injunear in you should be ashamed
Old Aug 12, 2016 | 01:52 PM
  #1179
Jeff
well it works now so seems right to me. Better than taking the front bumper off and to be honest this shunt resistor shit confuses me LOL
Old Aug 12, 2016 | 01:56 PM
  #1180
Resistors =unnecessary heat produced which is a waste of electricity.
Old Aug 12, 2016 | 01:59 PM
  #1181
Jeff
yea, I dont mind. I have a new battery And I dont use my blinkers much anyways LOL
Old Oct 7, 2016 | 12:24 PM
  #1182
yakko1zzz's Avatar
7th Gear
Did this yesterday while stuck inside from the hurricane. Ordered .12 Ohm resistor from digikey, 15 minutes in all, works great!
Old Oct 7, 2016 | 09:16 PM
  #1183
BreezyTL's Avatar
These are the resistors I ordered from digikey. What way do these need to be or are they universal? I am clueless when it comes to this stuff. I would assume they are one way resistors.
Old Oct 10, 2016 | 04:11 PM
  #1184
winn746's Avatar
4th Gear
Hi Breezy, you can install the resistor either way, BUT I did notice the picture of the packing label you posted says 12 OHMS 3W. You will need a .24 1W (POINT 24) if you have front and rear LED blinkers, so the hyper flash does not occur. I also purchased my resistors from digikey and they cost around 30 cents for one with $7 dollar priority mail. There are cheaper shipping methods, but I did not mind the shipping cost as I wanted the resistor expedited.
I searched the part number from your label on the digikey website to confirm the resistor specs. PNP300JR-73-12R Yageo | Resistors | DigiKey
Old Nov 1, 2016 | 02:57 PM
  #1185
BreezyTL's Avatar
Thanks to winn746, I was able to get this to work. I do have a second one that is modified from my part out. If anyone doesn't feel confident doing this themselves, I am selling the second one. Check out the BM for the ad!
https://acurazine.com/forums/car-par...sh-fix-950907/
Old Nov 2, 2016 | 07:14 PM
  #1186
ze2o's Avatar
Thanks OP. .22 ohm 1W works perfectly. Front and back LED signals no problem. 08 Base.
Old Nov 10, 2016 | 07:27 PM
  #1187
ATLS15's Avatar
Hey guys, real quick... I tried a 50 Ohm 1 W 1% resistor on my '08 TLS, and it only got rid of the hyper flash when my hazard lights were on. Still experiencing the issue when I use my turn signals. Does that mean that 50 Ohms is an overkill?
P.S. Huge props to the topic-starter for providing a legit fix on led hyper flash!
Old Nov 10, 2016 | 07:34 PM
  #1188
Why not use the properly spec'd resistor ???
Old Nov 10, 2016 | 08:46 PM
  #1189
ATLS15's Avatar
Because that's not what I had on hands. Figured, why not... Do you have an answer to my question?
Old Nov 10, 2016 | 08:48 PM
  #1190
rockstar143's Avatar
Even YOU have an answer to your question.
They said use XYZ...you used something else and it didn't work as planned.
The answer is use XYZ. You even gave OP props for recommending XYZ that you chose not to use.
Tread lightly with your snide comments to senior members that do nothing but troubleshoot and share and research for newer members on here all day long.
THEY are what make this forum great.
Old Nov 10, 2016 | 09:21 PM
  #1191
ATLS15's Avatar
Look, I'm interested in the technical aspect here. No offense to respected members here, but when I'm pretty much asking a "why?" question and get in response another "why?" question... That's just not helpful.
Old Nov 10, 2016 | 09:42 PM
  #1192
I'll answer this question
No, it means you used the wrong resistor.
Everyone is using a .12 ohm resistor. POINT TWELVE. (Or .24 for front or back only)
You put in a FIFTY OHM resistor. That's FOUR HUNDRED times the proper resistance .
Do the math man ..
Old Nov 10, 2016 | 10:11 PM
  #1193
ATLS15's Avatar
Do the math man ..
My bad, I meant to type .50 Ohm. I get the point, though. It's too much. Thank you for your time man
Old Nov 10, 2016 | 11:38 PM
  #1194
still too much
Old Nov 11, 2016 | 08:43 AM
  #1195
The funny part is, man...
you actually provided more useful information than most of the last few pages.
You at least let people know what happens if you get to the point of too much impedance.
At one point a member had bought it in bulk and sold individually for cheap.
I recall HATING removing the light board so much I was glad to be one and done with it.
Old Nov 12, 2016 | 10:01 AM
  #1196
ATLS15's Avatar
Haha, it's literally the worst part.
Old Nov 12, 2016 | 11:26 AM
  #1197
Big time!
Old Nov 17, 2016 | 08:56 PM
  #1198
bluetroll's Avatar
Do you guys have any idea where I can get these .12 ohm 1 watt resistors in Canada?
I tried Sayal electronics and they don't carry any resistors that low
Old Nov 17, 2016 | 08:58 PM
  #1199
Have you checked online? Digikey.com
Old Nov 17, 2016 | 09:04 PM
  #1200
bluetroll's Avatar
Is this what I need?
http://www.digikey.ca/product-detail/en/yageo/KNP100JR-52-0R12/0.12ACTR-ND/2058738
