Vertical Exterior Door Trim
Old Sep 12, 2016 | 09:36 PM
TrackDayRdr's Avatar
Mine is loose, not terribly where it rattles as I drive, but putting a hand on the pillar to close the front doors (either side) and there is movement. I did a search and checked for a parts fiche but no luck. Is there an easy way to tighten or is this just the way they are?
Old Sep 12, 2016 | 11:57 PM
csmeance's Avatar
what part are you talking about? You should be able to take apart more pieces that rattle and put foam behind them to apply pressure and keep them from making noise.
Old Sep 13, 2016 | 05:50 AM
The vertical piece of wide black trim on the front driver and passenger door.
If you put your hand on it to close the door you can feel it moving. I can't see how to tighten or remove it.
Old Sep 13, 2016 | 05:35 PM
csmeance's Avatar
Old Sep 13, 2016 | 07:07 PM
Csmeance, if I lived in FL I would buy you a beer. Thank you very much for that.
Do you know if the trim is supposed to be solid or do they all have some movement? It's not loose, but there is some play.
Old Sep 14, 2016 | 05:09 PM
RDX10's Avatar
My trim moves when I put pressure on it. However it doesn't cause a rattle or any noises so I think it may be normal.
Old Sep 14, 2016 | 08:51 PM
csmeance's Avatar
thanks for the offer! Pay it forward instead
Mine has a little bit of movement but no noises when I press on it.
Old Sep 15, 2016 | 11:44 AM
Thanks!! Sounds like mine is as intended.
I appreciate everyone's input!!
