Oh Sickest TL's '06 Royal Blue Pearl
Old Apr 21, 2016 | 03:47 PM
  #1201
Oh Sickest TL's Avatar
Jeff
so did i fuck shit up? i did use hub centric rings 73.1mm
Old Apr 21, 2016 | 04:15 PM
  #1202
rockstar143's Avatar
no
Old Apr 21, 2016 | 04:27 PM
  #1203
Alex.Leslie's Avatar
It's not the end of the world if you put the stock lugs on them, I just would avoiding driving on them until you can replace them. The hub ring will help them from 'slipping' on the non-conical lugs (once you get conical lugs, you don't actually need the hub ring).
Muteki lugs would have my vote. The SR48 are the most popular and come in a number of colors. If you like closed end, SR35s should be long enough.
Evasive sells them, but you should definitely be able to source them in Canada.
Old Apr 21, 2016 | 04:34 PM
  #1204
Jeff
I just ordered the black gorillas for now , thanks guys!
Old Apr 21, 2016 | 04:37 PM
  #1205
Old Apr 21, 2016 | 05:23 PM
  #1206
they're nice.!!!
Old Apr 24, 2016 | 01:24 PM
  #1207
Jeff
What bore size do I need for spacers? The advans are 73mm but the OEM bore is 64mm. I used hub centric rings when putting on the advans. Im just confused about these sizes.
Will the spacers go over the rings or do i take the rings off, put spacers on then put the hub ring on the spacer? LOL
Old Apr 24, 2016 | 02:54 PM
  #1208
sockr1's Avatar
spacers will fit your oem hub and they will also have their "own" hub that is same same as the oem ones. so you can keep your rings inside your wheels and put the rims on the spacers as is.
what size spacers? sounds like you're going 15mm with the built in studs?
PS a trick for the hub centric rings is to always keep them attached to the wheels. whenever i use rings, i put a little siilcone sealant inside the wheel and then put the ring into the wheel and wipe away excess adhesive. that way a ring doesn't get lost when you rotate and balance your wheels, which could easily not be noticed until you start driving and know something's wrong
Old Apr 24, 2016 | 02:58 PM
  #1209
Jeff
yea I'm going to try the 15mm spacers. So just get 5x114.3 64mm?
Thanks for all the help dave
Old Apr 24, 2016 | 03:00 PM
  #1210
sockr1's Avatar
yup, 64.1 and keep the rings inside the wheels and just mount onto spacers as you would oem hub.
no problem jeff! excited to see how your car looks with everything!
Old Apr 24, 2016 | 03:02 PM
  #1211
Jeff
me too man, doing everything this coming weekend. should have pics up of the suspension installation and what not.
then she's off to the detailer
Old Apr 24, 2016 | 04:19 PM
  #1212
Jeff
what do y'all think of yellow fogs. Yay or nay on my car? lol
Old Apr 24, 2016 | 06:29 PM
  #1213
nay or nay?
I say nay.
Old Apr 24, 2016 | 06:39 PM
  #1214
Jeff
nay or nay?
I say nay.
word tho?
Old Apr 24, 2016 | 06:42 PM
  #1215
well, you asked a question with only one answer.
so i gave you that answer.
1) you're not 17
2) it's not 2002
3) no.nay.non.nonmerci.silvousplaitnon.nein.fuckno.no ,fuck
  #1216
Jeff
Lmfao gotcha
Old Apr 24, 2016 | 06:43 PM
  #1217
thank goodness,
when I write, i never know if my message is coming across.
but remember, that's just like, my opinion, man.
Old Apr 24, 2016 | 06:46 PM
  #1218
Jeff
Sall good dawg. My buddy has yellow on his 2g. Looks good but yea it is a little fast and furious isn't it lol
Old Apr 24, 2016 | 07:54 PM
  #1219
sockr1's Avatar
Do you mean yellow output or yellow look without them on? I used to like the white fogs but recently switched to yellow nokyas. I love the look of yellow when I need to use fogs. However I only use fogs when I need to and during normal driving my fogs don't have a yellow look since they're off. I don't like the yellow overlay
Old Apr 24, 2016 | 07:57 PM
  #1220
Jeff
if I were to do it, I would do 3k bulbs and yellow laminx over the lens
Old Apr 24, 2016 | 08:03 PM
  #1221
sockr1's Avatar
I actually think a yellow look (overlays) look best on kbp and a dark blue like yours. Any other color and I think it looks tacky. Overall not a fan of the look but then again I love yellow functional fogs they get it a unique look. I just don't like the yellow look without them on haha.
Your car man go for it! It's fairly cheap so you can easily switch back
Old Apr 25, 2016 | 11:30 AM
  #1222
DarkTower19's Avatar
I actually did this per your recommendation and it worked wonders Otherwise, they fall out very easily.
Old Apr 25, 2016 | 12:14 PM
  #1223
meant to mention that too...I always do a dab of RTV when I mocked up the ring and a cap that doesn't belong.
Old Apr 27, 2016 | 11:46 AM
  #1224
Jeff
got the TL inspected today. Wasn't sure if it would pass due to the xlr8 v2 j pipe removing the 3rd cat. no one said anything. Car is mechanically sound so they prob didnt look to deep into anything
Old Apr 27, 2016 | 11:47 AM
  #1225
maharajamd's Avatar
Old Apr 27, 2016 | 11:51 AM
  #1226
Jeff
Originally Posted by maharajamd
let the modding begin! Gonna go swap out my cluster now
Old Apr 27, 2016 | 11:54 AM
  #1227
maharajamd's Avatar
Do what? the tach and all that? From what to what and why?
Old Apr 27, 2016 | 01:31 PM
  #1228
Jeff
04-06 base instrument cluster to the 07-08 base cluster. Man what a difference. Its no contest
Old Apr 27, 2016 | 01:41 PM
  #1229
maharajamd's Avatar
If you say so. I like my blue with type-s bezel...
Old Apr 27, 2016 | 01:50 PM
  #1230
Jeff
Found the time to swap out the instrument clusters today and took a cpl pics. The car is pretty dirty ATM as its been in and out of shops for the past 2-3 weeks
Advans RSII
Advans on now with black gorilla lugs. Oh boy that gap tho..does she ever need a drop!! TEIN FLEX going in this weekend
HIC roof spoiler
HIC Window visors on now. Kinda hard to see but they look great. Peeled off that dumb HIC logo on the 2 front ones
07-08 base cluster I find it to be more crisp and just better looking then the 04-06 base. But that is purely subjective
new mileage 134290kms Old mileage was 217114kms. Wrote them both down in a book and will keep track of it that way
Car is getting detailed next week after the suspension install so stay tuned for that as it will look 100x better.
Still working away on the RL calipers too
Old Apr 27, 2016 | 02:04 PM
  #1231
sockr1's Avatar
looks great! but my eye keeps focusing on the lack of center caps!
jk but overall the car looks much different and excited to see how the drop looks after
Old Apr 27, 2016 | 02:07 PM
  #1232
Jeff
thanks dave. Yea I know about the centre caps. At least its nice and clean in that area and not rusted lol.. Ill prob run it like this for this season and just grab them around xmas time for next summer
Old Apr 27, 2016 | 02:11 PM
  #1233
sockr1's Avatar
when you get a chance next, can you measure from the center of the wheel to the fender straight up at stock height? i want to compare it to what mine is to see how much i'm really dropped. i know i'm at 24.75" from ground to fender but that isn't the "drop" since it is influenced by wheel size, tire size, etc.
also what height are you planning to drop it to? far as you can?
Old Apr 27, 2016 | 02:17 PM
  #1234
Jeff
yea man I can def do that on friday before we start getting into things..
I just want it as flush as possible. I assume that Ill have to play around with some adjustments it for a little bit to get it where I want.
Theres no place that sells spacers in my area so I still gota order the 15mm ones. ill have the suspension on without spacers so it may look sunken in as the offset is +45 on these.
Old Apr 27, 2016 | 02:24 PM
  #1235
sockr1's Avatar
thanks man!
even sunken in it will still look good. you may want to shoot for a 24" ground to fender measurement to start off with and play with it from there. it will take some dialing in to get what you want but that's the awesome thing about coilovers!
Old Apr 27, 2016 | 02:25 PM
  #1236
Jeff
Im pretty excited to throw some parts at it this weekend lol.
Old Apr 27, 2016 | 08:41 PM
  #1237
Steven Bell's Avatar
Good stuff Jeff....nice shots.
Old Apr 28, 2016 | 05:57 AM
  #1238
ryanfett's Avatar
Looking good man! Love the new cluster. It's going to be sittin pretty after the drop
Old Apr 29, 2016 | 09:00 PM
  #1239
Jeff
Old Apr 30, 2016 | 06:45 PM
  #1240
Jeff
Everything is in. The job didnt go too bad. everything came apart pretty well
Had to cut the toe arms out those bastards were seized badly!
She's on the ground now. Just making some tweaks on all four corners..<br/><br/>Dinged my fender on that side with one of the coils. Luckily its really small but it did break the paint. so back to the body shop next week FFS
