19x9.5/19x11 Fitment Question!
Old Apr 16, 2016 | 12:17 AM
Pearson4G's Avatar
Anyone running or know someone running aggressive specs? I'm looking into a new set of wheels for next year and was curious if any of y'all know if it'd work heh.
Complete specs are from a 2P wheel. Fronts are 19x9.5 +20 and rears are 19x11 +25. When checking out the fitment guide on WillTheyFit, it's poking about 1.5cm more in the fronts and 1.7cm in the rear than my current setup, which isn't too crazy I guess? (Fronts: 19x8.5 +15 Rears: 19x9.5 +20).
Old Apr 16, 2016 | 09:05 AM
carbonTSEX's Avatar
The Original Shawdy
Specs are pretty aggressive but I'm sure you can get them to fit. The rears will be the challenge. That's a big jump from your old setup in the rear.
Old Apr 16, 2016 | 01:20 PM
Pearson4G's Avatar
Eh, could always follow the norm and flare all the fenders. 👀👀
Old Apr 16, 2016 | 04:20 PM
carbonTSEX's Avatar
The Original Shawdy
If it's a wheel you like, make em fit. That's what I do. My new setup is gonna be pushing the limits.
Old Apr 16, 2016 | 10:07 PM
lodyice's Avatar
9th Gear
Of course u can fit them
I'm running 10.5 all 4 +35 front +25 rear and I just roll the fenders and pull them a little no camber kit but if u gone go low like I did u gone get 2-3 degrees camber
Your set up gone be 3mm more on front and 6mm on rear then my with is not a lot of course u gone need to work a little to fit them like cut the front liners cause after u roll and pull the fender they not gone be attached to it
And I run 245/35/20
I would like to see the wheels u want to get
Good lucky
Old Apr 16, 2016 | 11:26 PM
carbonTSEX's Avatar
The Original Shawdy
And I run 245/35/20
Good lucky
What tires are you running? Good to know the work you put in to get em to fit. Helps me a little more.
Old Apr 17, 2016 | 09:33 AM
lodyice's Avatar
9th Gear
Achillis ATR Sport 245/35/20 they are cheap but I'm running camber so they wear a lot
It's nice stretch on 10.5 with 245/35
But u can go 245/30 and go lower then me
Old Apr 17, 2016 | 09:16 PM
carbonTSEX's Avatar
The Original Shawdy
Nice fitment. I'm trying to avoid 30 series tires. I'm on them now. Would prefer to run 35.
Old Apr 18, 2016 | 05:38 AM
lodyice's Avatar
9th Gear
Unhappy
All depends I'm daily driving I live in Long island and drive to Queens a lot so I need more cushin
But yes I prefer 35
Old Apr 18, 2016 | 07:29 AM
Pearson4G's Avatar
35 series is life. And Carbon, you can't keep teasing me about those wheels man. It's starting to take an emotional toll on me ����.
And the wheels are Work Meister S13P. Either powder coated Metallic copper or Black Face/Copper barrel.
Closest example I can find.
Old Apr 18, 2016 | 09:52 AM
carbonTSEX's Avatar
The Original Shawdy
The Meisters go hard.
tepioka92
ILX Tires, Wheels & Suspension
Apr 27, 2017 06:50 PM
johnpancakes014
Mar 21, 2016 12:23 AM
614erich
Feb 23, 2016 10:54 AM
Marmstrong1023
Jan 25, 2016 08:36 AM
