Nav screen stays in daytime setting at night..
Old Feb 23, 2016 | 10:19 AM
teh CL's Avatar
Whenever I'm driving and my auto lights turn on the Nav screen would also switch to night mode (black map background). The last week or so it hasn't been switching and stays in daytime mode (white background).
Is there something that has to be reset? Not a big deal since I just press the button to switch it over but it's starting to bug me (yes the whole .5 seconds it takes to press the button )
Turning into a spoiled brat with this car
Old Feb 23, 2016 | 10:22 AM
Your ambient light sensor might be on the fritz..
you guys have one right..?
Old Feb 23, 2016 | 10:27 AM
teh CL's Avatar
Sounds about right &
Old Feb 23, 2016 | 11:29 AM
oo7spy's Avatar
There is a setting in the Nav menu. There is also something related to the dash brightness if I remember correctly. I think going max brightness pulls the nav out of night mode, but I may be wrong.
If your auto lights work, your light sensor does too.
Old Feb 23, 2016 | 11:34 AM
JasonK's Avatar
09 TL SH AWD /w TECH
Max brightness doesn't pull the nav out of night mode.
Go into the settings in your nav and you can change the color of the screen. Might have been changed at some point? I have mine on black all the time because I find the other settings annoying.
Old Feb 23, 2016 | 12:12 PM
teh CL's Avatar
First thing I did was go back to change the colour of the screen. It was still set to white for daytime & black for nighttime.
Old Feb 29, 2016 | 08:50 AM
Tubasteve's Avatar
Agree, if lights change but navi don't, sensor good. I'd bet the tail lights aren't coming on
Old Feb 29, 2016 | 10:07 AM
teh CL's Avatar
They come on.
Still pressing that damn button..
Old Feb 29, 2016 | 10:51 AM
oo7spy's Avatar
Battery reset.
Old Feb 29, 2016 | 11:18 AM
teh CL's Avatar
Good call
Old Mar 6, 2016 | 09:34 PM
RL09's Avatar
FkNo!TheyRdstroyinEvrting
Did the battery reset work?
I think spy was on to something. mine was working until some point. Close to that i had pressed the dash brightness to max coz in the day you can barely see them sometimes. Maybe they are related.
How does one do a battery reset? disconnect?
Old Mar 6, 2016 | 09:37 PM
JJones91's Avatar
Max brightness WILL pull it out of night mode.
I kept trying to figure out why I would have to keep putting it in night mode manually. I pushed the (-) brightness button once and it went into night mode. Ever since then it goes from night to day automatically. I like having my illumination bright but I hate having to keep switching from day to night so I can live with a little less brightness.
Old Mar 6, 2016 | 09:43 PM
JJones91's Avatar
If you can barely see it like say right after a cold start it's because the LCD has to warm up. Unfortunately it takes a little while on cold days.
Old Mar 7, 2016 | 10:46 AM
oo7spy's Avatar
A "battery reset" consists of taking the cables off, and holding the terminals together for 30 seconds or so. If you had a regular ignition, turning the key to "On" would be optimal, but I don't think the RL is a good candidate.
What this does is discharge any stored charge in most of the capacitors in the circuits. Acura released a service bulletin to their shops instructing the techs do do this first if an RL with a bunch of random codes comes in.
Old Mar 7, 2016 | 07:59 PM
RL09's Avatar
Just pressed on the minus '-' once in dash brightness and voila. I too no longer have to switch it manually.
Old Mar 7, 2016 | 08:01 PM
JJones91's Avatar
Yup very easy fix lol
Old Mar 7, 2016 | 08:24 PM
RL09's Avatar
spy knows his stuff
Old Mar 17, 2016 | 07:24 PM
teh CL's Avatar
You should actually thank JJones.
BTW, just went out to the car and hit the (-) ……
GF must have touched it the one time I let her drive the car when I was ..
/Thread
Old Mar 17, 2016 | 07:51 PM
RL09's Avatar
No no, it is spy. At least in this thread. Spy's the first to mention it in post#4.
It was surely nice of Jones to clarify and underline and assert further.
/Thread
She deserves a
I got my stick always on auto now, car switches as it pleases.
Now go back to my thread and see the embarrassing cause i found out to my "problem"
Old Mar 17, 2016 | 09:46 PM
teh CL's Avatar
Well played
Old Mar 17, 2016 | 10:17 PM
oo7spy's Avatar
You should read the posts in your threads, or at the very least, mine.
Old Mar 17, 2016 | 10:24 PM
teh CL's Avatar
Old Mar 18, 2016 | 10:15 AM
oo7spy's Avatar
