Failure of my '04 TL's rear view auto-dimming mirror. This is important.
Registered Member
My '04 manual TL, which has been garage kept its entire life, just surprised me yesterday with a strange looking semi-oval "clear" spot at top center of my rear view mirror, about four inches long and an inch+ high. The other part of the mirror not affected by this oval, reflected images that were distorted and with ghost-like secondary images.
After researching on this site for a little bit this morning, I enclosed the mirror in a freezer 1-gallon ZipLock bag, then using my Service Manual, and some logic, I removed the mirror and packed it in a small cooler (no ice) to take to Pohanka Acura on Monday. Their parts department knows about this problem, said it was pretty common, and has the newer mirrors in stock.
If this happens to your 3G TL you need to fix it, or have it fixed, as soon as you are able. Do not let this linger because from what I was able to find out, it can cause damage to your interior and be dangerous to you.
Glad this didn't happen a few weeks ago when I was on vacation.
This is interesting as the 2G cars had this problem (my old 2G included), requiring mirror replacement. Lots of folks on the 2G forum indicated that they had mirror leaks as there's fluid in the mirror giving it the anti-glare property. Mine never leaked, but I did have it replaced for free (back then, the mirrors were made by Magna Donnelly, and they had an exchange program for a while, but MD doesn't supply the mirrors anymore).
It's concerning if it's happening to the 3G cars now. I would agree if you see changes in the image on the mirror (area of no glare reduction in a surrounding area of the image), it might be a good idea to get the mirror replaced.
2G Mirror problem which sounds similar: https://acurazine.com/forums/2g-tl-1999-2003-98/rear-view-mirror-exploded-549093/
Registered Member
I was completely out of thin air so I can only guess that it was due to problems others have reported for both 2G and 3G TL's. One moment all was well then yesterday when I started up my TL to pull out of my garage to go someplace, I noticed it right away. No advanced warning of any kind with this.
Registered Member
I am going to pick up two mirrors on Monday; one to replace the one I removed in my '04 this morning and one for my '05. I'll go ahead and do the replacement for the '05 anyway just so my wife won't run into this problem.
Registered Member
2G Mirror problem which sounds similar: https://acurazine.com/forums/showthread.php?t=549093
I had no idea this was a know or "common" problem.
Same issue?
The top edge of my inside rear view mirror looks like there is a liquid melting under the glass. It is full width and about a half inch high. It is probably not even noticeable except to the driver but is annoying.
Is there potential harm if the liquid leaks out?
Registered Member
It's a simple fix and only takes about 10 minutes. When you are fitting the new mirror onto the base on your windshield, move it up to its spot carefully. If it doesn't click into place, insert a straight blade screwdriver into the slotted openings and carefully pry the mirror foot up until you hear a click.
Registered Member
I have read that it could blow up but I doubt that actually means an explosion. I would guess what those posters meant was perhaps the mirror case rupturing and thereby allowing some of the chemicals to leak out. With mine it was one moment all was well, then next moment saw a weird clear bubble behind the glass and distortion in that part of the mirror which did not have that bubble (which had distinct borders, BTW).
Having researched this on these forums, I found that this was not all that uncommon with some Acura years and anyway, that didn't matter because that mirror was getting replaced ASAP.
The complexity of modern feature-laden vehicles has its attendant problems along with its luxuries. These auto-dimming mirrors are perfect examples of this little fact. They are great to have and really do their job remarkably well until they fail.
Extra Protection
I will be leaving town for over a month and my TL will be in the South Florida driveway with a car cover over it.
Since I don't have the time to replace the THREE mirrors, I will bag the interior rv mirror with a zip lock plastic bag as a preemptive measure to prevent the fluid from causing damage should it leak out.
Dave
Dave
Has anyone used the aftermarket (manufacturer says exact fit) listed below for their 3g? My 2004 TL mirror is wacked (bubble on about 1/2 mirror. thanks for any input.
Gentex K2 Auto-Dimming Rear View Mirror
<li class="ecxheading">Gentex K2 Auto-Dimming Rear View MirrorVehicle2004 Acura TL
SubmodelAll TL models
AutoAnything SKU3821418
Part Number50-GENK2AM
Thanks. I assumed the OEM was going to be double the aftermarket price and didnt bother to look there first. After your suggestion, I looked and I was able to find a OEM unit for about that price plus shipping. With the OEM you know it will fit.
BoricuaTL
Apr 8, 2016 01:08 PM
dre707
Sep 8, 2015 08:32 PM
