Motor mount DIY or pointers/tips
Old Mar 18, 2011 | 12:46 AM
DimwitRj's Avatar
that ONE RED tl
I'm going to attempt doing my mounts next week, does anyone have a DIY (don't believe I've come across one) or any tips? Especially for the rear mount... TIA
Old Mar 18, 2011 | 02:31 AM
paperboy42190's Avatar
o man the rear mount is a PITA....i highly recommend paying $80 for a shop to do the rear.
front is okay. remove the radiator fans for more clearance and make sure you have a variety of extentions and sockets.
side mount is EASY i can do it in like 10 min. only 2 bolts holding it on bottom and 1 bolt on top and very easy access.
i noticed you're in socal, lemme know if you need any help.
Old Mar 18, 2011 | 02:38 AM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
This might help: https://acurazine.com/forums/3g-tl-problems-fixes-114/replaced-my-motor-mounts-pics-inside-772642/
Old Mar 18, 2011 | 12:27 PM
DimwitRj's Avatar
that ONE RED tl
Thanks to the both of you.. well technically I'm doing it at my uncle's shop with his and my brother's help. Just getting some pointers because he specializes in DOHC 4cyl Hondas (ex-pro drag racer).
As far as the rear, it can be done through the top of the engine, correct?
Old Mar 18, 2011 | 12:28 PM
Old Mar 18, 2011 | 12:36 PM
KN_TL's Avatar
It's honestly not that bad. I did mine with just a jack and stands.
Old Mar 18, 2011 | 05:12 PM
jda123's Avatar
Dogmatic Dinosaur
If your uncle has a shop, then this will be no problem. Some extensions, socket u-joints and air tools will make this a breeze.
Old Mar 19, 2011 | 10:27 PM
BLACKURA_NY's Avatar
I have car ADD
like others said... side takes 2 minutes... front, isnt too rough.. the rear is a BITCH
honestly, the best method is old school... get a floor jack and some 2x4's.... put the 2x4 between the oil pan and the floor jack, and jack up the engine slightly (or lower it) to help with aligning the mount
what happens to some people, is they remove the mount and then the holes wont line up... it can become a real bitch to fix
Old Mar 19, 2011 | 11:43 PM
DimwitRj's Avatar
that ONE RED tl
Not looking forward to this at all... lol.
Old Mar 23, 2011 | 11:04 AM
DimwitRj's Avatar
that ONE RED tl
Damn I'm sore as f***. Did all 3 of my mounts yesterday and took my about 4 hours. Even though I was able to utilize my uncle's shop I did 95% of the work because my brother and uncle were busy building a roll cage for another car.
Like you guys said, side was a breeze (I wish they were all that easy). Front wasn't a big deal after removing the radiator fans, I found that I couldn't remove the driver side fan without removing the top hose. The rear was a bitch, just because of the awkward positions you had to be in, other than that, they were all pretty straightforward.
What really gave me a hard time was probably the simple things. Banged up my finger removing the vacuum line from the front mount, and had to do the rear over because I pinched the vacuum line without knowing and tightened down the bolts $#!+.
Another pointer... the front and rear are filled with fluid so if they're cracked... don't turn them upside down. I made that mistake with the front mount while messing with the vacuum line.
Once all is down, enjoy the clunk free driving and rattle free cold morning starts! ...and take some pain relievers the next day because you will be sore.
Old Mar 23, 2011 | 11:48 AM
sddale's Avatar
How much has your idle changed? Is there still some vibration?
Old Mar 23, 2011 | 08:42 PM
I have car ADD
wait. did you replace with OEM mounts, or did you go with Innovative...?
I had Innovative 75A mounts on my 3G TL-S... oh my what a world of difference
Old Mar 23, 2011 | 08:51 PM
DimwitRj's Avatar
that ONE RED tl
I went with OEM, didn't want any rattles.. but I guess that doesn't matter right now... my trans just died.
Old Mar 23, 2011 | 09:34 PM
mindanaomoro's Avatar
What your trans DIED!!? another one!? how many miles? so sad to hear.
Old Mar 23, 2011 | 09:51 PM
DimwitRj's Avatar
that ONE RED tl
96k, I have a thread in Problems & Fixes.
Old Feb 2, 2020 | 11:59 AM
ThetypeSwithBadPaint's Avatar
do you still have your TL ?
Old Feb 2, 2020 | 03:46 PM
Mine still going....
Old Feb 2, 2020 | 11:39 PM
*how many miles on clock
Old Feb 3, 2020 | 05:37 PM
DerrickW's Avatar
Would you mind expanding on this thought? I also have a 3G TL-S, sitting at 178k and I anticipate having a little play money in-pocket next month & trying to figure out some modest yet good bang-for-buck upgrades/changes.
Mike734
Dec 10, 2021 01:25 PM
tsx_boy
Dec 13, 2019 08:33 PM
08KBP_VA
Oct 22, 2019 01:55 PM
rp_guy
Jul 16, 2017 07:33 AM
