My Build Thread - Lols @ 56k
Old Mar 4, 2010 | 10:23 PM
  #961
JCharged's Avatar
I know this, however I had thought Jake was running a Type S ecu and still pulling 40* of timing. Pulling 40* on boost is still a bit much.
Nope, TL-P. I used richie's harness.
Old Mar 4, 2010 | 11:40 PM
  #962
DaInFaMMuS1's Avatar
This is an interesting build, too bad this thread is riddled with bullshit, makes it harder to get to the good points lol.
Old Mar 5, 2010 | 04:21 AM
  #963
Rajca's Avatar
wham bam thank you ma'am
but keeps it interesting. imo
Old Mar 5, 2010 | 09:31 AM
  #964
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
I don't have the time or energy to go through and clean it up, def makes it harder to follow the build though
Old Mar 5, 2010 | 12:08 PM
  #965
civicdrivr's Avatar
Sorry. If its easier I can always put together a No Bullshit Timeline in another thread. Think of it as cliff notes to my build
Let me know if thats ok.
Old Mar 5, 2010 | 12:11 PM
  #966
civicdrivr's Avatar
Originally Posted by friesm2000
stock tuning should already be adding that, in the higher rpms though, cause it needs to ignite (aka more degrees) the a/f mixture sooner so it will still be at it's peak at tdc
, and btw i think the stock programing already adds as much timing as possible, then pulls out just enough to prevent pinging, by using the knock sensor, cause when my car was getting a baseline, it actually gained power on the 2nd run, then again on the 3rd run, then stayed consistent for the 4th and 5th run (same as the 3rd run), due to it learning the timing for that preticular time/runs, and the 3rd run was where it had maximized the amount of advanced timing
but yeah if you start adding/using racegas, then yes you need to advance the timing yourself (not fully though, but enough that the computer will still be able to compensate for it, and not be outta "range"/throw a knock sensor code [cause it is looking for that ever so slight knock])
Yes, the stock ECU is great on a 3.2l, but it was never made to run a 3.6l at its best. Theres more power to get out of my motor with proper tuning.
Old Mar 5, 2010 | 12:20 PM
  #967
e30cabrio's Avatar
LFG RANGERS!!!!!!!!!!!
Mine threw P0130, lean yesterday. I cleared it & set the UNICHIP to B, after 100 miles it has not come back. I am going to install the wideband AFR Monday & finish the FPR today.
Old Mar 5, 2010 | 01:32 PM
  #968
Rajca's Avatar
Post pics if u can when ur installing it
Old Mar 5, 2010 | 05:28 PM
  #969
friesm2000's Avatar
B A N N E D
why get a new ecu , and just go and get a AEM FIC, to be able to tune it
Old Mar 5, 2010 | 07:53 PM
  #970
civicdrivr's Avatar
It wont pick up the crank sensor.
Old Mar 5, 2010 | 08:00 PM
  #971
friesm2000's Avatar
B A N N E D
you know there are two options for the fic, there is a specific one for hondas and such
but then again you got the manual crank sensor, and trigger afterall, so different from the auto
Old Mar 5, 2010 | 08:04 PM
  #972
NVA-AV6's Avatar
BANNED
The 30-1910 works for ALL J series V6, the 30-1911 is specific to the AP1 S2K.
Old Mar 5, 2010 | 08:18 PM
  #973
CL-Future's Avatar
Lives in Boost
Wait, there's someone running the AEM F/IC on a CL-S here?
Old Mar 5, 2010 | 08:36 PM
  #974
NVA-AV6's Avatar
BANNED
LOL, at least 10 that I have built harnesses for in the last year.
Old Mar 5, 2010 | 08:52 PM
  #975
CL-Future's Avatar
Lives in Boost
Sorry, I just haven't seen anyone say that it actually works.
I thought E-Manage was the only thing working w/ our ECU. According to civic's comment, I don't think I'm the only one that thought that.
Are there any dyno's of CL-S members that were tuned on the F/IC?
Old Mar 5, 2010 | 09:00 PM
  #976
friesm2000's Avatar
B A N N E D
group buy for the manual owners
Old Mar 5, 2010 | 09:05 PM
  #977
Rajca's Avatar
e-manage blue works for auto and manual. ultimate doesnt work on the manual
Old Mar 6, 2010 | 09:26 AM
  #978
e30cabrio's Avatar
So what is the best ECU solution for my 3.6?
Old Mar 6, 2010 | 09:44 AM
  #979
friesm2000's Avatar
B A N N E D
i would say stock ecu, with an aem fic (and just use that too compensate for a larger motor/fuel demands, but also if you put larger injecters in at some point)
Old Mar 6, 2010 | 10:06 AM
  #980
civicdrivr's Avatar
I was under the impression that the F/IC couldnt pick up the crank sensor either.
The e-manage is the tried and true method, but I don't like it. JPRoy was tuning on the F/IC but never posted an update past "it was wired wrong, I got it figured out though".
I got on it hard last night in second and third and when I came to a stop I smelled a shitload of unburnt fuel. Im going to go verify I dont have any leaky lines before I assume its running a bit rich. At WOT in high RPMs the AFR is right around 12.6, but when I let off the gas it drops down to around 10.4, then fully rich, then back to fully lean (off throttle completely).
Old Mar 6, 2010 | 01:14 PM
  #981
NVA-AV6's Avatar
BANNED
Yeah, JPROY sent me his harness and I re-wired the BS P&P for him, LOL.
Fully lean with foot off the throttle is normal, the ECU shuts off both fuel and spark when there is a negative load on the engine....
Old Mar 6, 2010 | 01:22 PM
  #982
e30cabrio's Avatar
NVA, what is the best solution for an engine like Morgans?
Old Mar 6, 2010 | 03:10 PM
  #983
NVA-AV6's Avatar
BANNED
Stock ECU + FIC since he has narrowband primay O2 sensor the fic can tune fuel in closed loop by modifying the O2 data being sent to the ecu.
Old Mar 6, 2010 | 03:21 PM
  #984
e30cabrio's Avatar
Timing set by the stock ECU is fine?
Old Mar 6, 2010 | 04:27 PM
  #985
civicdrivr's Avatar
Yea, I know fully lean is normal off throttle, but its going fully rich after a WOT run when I initially take my foot of the throttle, then it goes back to fully lean. Its fully rich for 2 seconds tops.
And the fuel I smelled last night was indeed a leak. A fitting off the FPR (that I replaced the o-ring on before) started leaking. I replaced the entire fitting this time. I dont want to deal with it again. It seems to be holding well now. Im keeping an eye on it though.
x2
And an update with the wheels. My wheel guy had a hard time finding paint that matched, but he got it on Thursday. I should have them back and mounted mid-week.
Old Mar 6, 2010 | 07:34 PM
  #986
NVA-AV6's Avatar
BANNED
Yes, the ECU will use the knock sensor to set the timing as close to knock as possible without actually knocking (This takes a little while for the ECU to learn).
Old Mar 6, 2010 | 07:51 PM
  #987
civicdrivr's Avatar
Interesting.......
Goddammit and I said I was done dumping money in this car
Old Mar 6, 2010 | 08:01 PM
  #988
Rajca's Avatar
a car enthusiast is never done.
Old Mar 6, 2010 | 08:04 PM
  #989
e30cabrio's Avatar
Interesting.......
How can you leave HP on the table????
Old Mar 6, 2010 | 09:03 PM
  #990
friesm2000's Avatar
B A N N E D
x2, and i know i said it before, but what thread was that in again???
Old Mar 6, 2010 | 09:21 PM
  #991
civicdrivr's Avatar
I got other shit to work on
I dont remember you ever saying that
Old Mar 6, 2010 | 09:35 PM
  #992
what does the car put out in its current state, have you had it on the dyno yet?
Old Mar 6, 2010 | 09:55 PM
  #993
civicdrivr's Avatar
Ive yet to dyno it. Once I get the intake work done then it's going on the dyno.
Old Mar 7, 2010 | 01:06 AM
  #994
CL-Future's Avatar
Lives in Boost
Guess you can get the F/IC and fix that fuel issue now that we know there are multiple CL's on here running it...
Old Mar 7, 2010 | 02:47 AM
  #995
JCharged's Avatar
Let's just wait on Don.
I fux with crome.
Old Mar 7, 2010 | 11:05 AM
  #996
civicdrivr's Avatar
I fux with crome.
Im really hoping that he gets somewhere with it. Ive never been a fan of piggybacks.
Old Mar 7, 2010 | 11:12 AM
  #997
friesm2000's Avatar
B A N N E D
x2, but piggyback is our only option for now
Old Mar 7, 2010 | 11:35 AM
  #998
civicdrivr's Avatar
Which is why I haven't bought one yet
Old Mar 7, 2010 | 11:41 AM
  #999
Rajca's Avatar
^x2
Old Mar 7, 2010 | 11:48 AM
  #1000
friesm2000's Avatar
B A N N E D
still cheaper to buy a FIC, then buying another motor (and anyways it can be sold once the hacking becomes available)
