a little history of my TL (lots of pics, 56k warning)
Old Sep 17, 2009 | 01:17 PM
  #201
desired_speeds's Avatar
Originally Posted by undyroos
i know it was months ago but i've been busy finishing my dissertation. all done now so here are some pics...
at the norcal caravan
I love these pics.
Old Dec 6, 2009 | 10:46 PM
  #202
undyroos's Avatar
Type II intake manifold
the reason i did my HID retrofit was because i saw surfin scotty do it. the reason i did this type II IM swap was because i saw tony do it, i'm such a biter! anyway, here are the pics.
located a type II IM on cragislist who turns out to be ken's friend who also happens to have a legend coupe parts car so i also got his front strut bar.
dirty type II IM
after some simple green and a toothbrush
still some carbon in there
all clean after some brake cleaner
before pic in case i forgot where everything goes
IM out, see that blue and gray wiring harness in the valley where the IM was, DO NOT touch it or the sensors or you'll end up having to replace them and take out the IM again. i could go on forever about all the vacuum hoses and sensors that you need to undo just to get to this part. frustrating at first but its the only way you can learn about this kind of stuff...
looks not too bad for 115k. is there supposed to be oil in that little center pocket? scraping the paper gasket off is sooo tedious. found out soaking it in hot water works wonders.
dirty type I vs clean type II
EGR chamber wasn't too bad either
new o-rings everywhere on the fuel injectors. the old rings still looked new.
cleaned and ready for reassembly. playing with the VSS butterflys was kind of fun. IIRC, the side butterflys open at 4100 rpms, when does the center butterfly open or close?
all buttoned up, ready to go. see the hole at the top left? forgot to get the gasket for that. it is the air suction joint gasket. i ended up reusing the old one. you can also cut one out of gasket material or cardboard.
back in the car. no fuel leaks! you can see the mounting brackets for the front strut bar. still trying to get it to fit w/o drilling.
TYPE II, still need to put the fuel rail covers on. hope you guys enjoyed the pictures, didn't take as many as i wanted because my hands were filthy. props to ken for answering all my questions. i still can't believe you did this all in one day. the backs of my legs are still sore from leaning forward into the engine bay all the time.
Old Dec 6, 2009 | 10:52 PM
  #203
how the did the swapping of the injector studs go? I completely forgot about the gasket for the air suction pipe. Luckily, it's not very important. Looks like you did a great job on everything, especially for a first timer! To put on the legend fuel rail covers using the stock closed end nuts, you have to shorten the studs btw.
Old Dec 6, 2009 | 10:56 PM
  #204
undyroos's Avatar
swapping the injector studs was cake, thanks for the tip! i would have never figured it out myself. for those of you who are wondering, take two nuts and tighten them against each other and then unscrew with the bottom nut to remove the injector studs.
Old Dec 6, 2009 | 11:04 PM
  #205
6spd91Sedan's Avatar
Shoulda ported it like I said! haha nice job, did you feel a difference?
Old Dec 6, 2009 | 11:12 PM
  #206
undyroos's Avatar
hey man, thanks for the gasket hookup. didn't notice a huge difference yet but rain and traffic prevented me from getting past 3000 rpms. i was happy enough that the car started when i fired it up the first time and i didn't throw any real codes. i'll let you guys know how it feels when the weather clears up in a bit, supposed to snow in davis tonight and tomorrow!
Old Dec 6, 2009 | 11:14 PM
  #207
No problem anytime just let me know, sounds good. Yea I heard it was gunna get pretty cold around here.
Old Dec 6, 2009 | 11:32 PM
  #208
tmnhs81's Avatar
Looks nice undy!! I was hoping for some shots of your whole car too but this will do it for now. We gotta arrange some mini 1G TL meet now... oh and you lucky to get that type 2 badge on yours. I got nothing..
Old Dec 7, 2009 | 09:40 AM
  #209
TLin401's Avatar
'13 Hyundai Sonata
That is legit.
Looks nice. It makes your car even more sex.
Old Dec 8, 2009 | 10:50 PM
  #210
tmnhs81's Avatar
Did you get a chance yet to open her up?
Old Dec 9, 2009 | 04:24 PM
  #211
Mandy's Avatar
98 3.2 Flamenco Black
Open her up, as in open up wide, I am coming in?
Old Dec 12, 2009 | 05:09 PM
  #212
tmnhs81's Avatar
....yes.
Old Dec 16, 2009 | 07:25 PM
  #213
undyroos's Avatar
winter mod
new winter mod, can you see it?
follow the arrow
first one exploded when I exited my driveway
merry xmas!
Old Dec 16, 2009 | 07:32 PM
  #214
haha legit
Old Dec 16, 2009 | 11:19 PM
  #215
tmnhs81's Avatar
lol..Merry Christmas...
I have to admit, I like how your car looks without any window tint. But for some reason I can't seem to live without it..
Old Dec 16, 2009 | 11:32 PM
  #216
TLin401's Avatar
'13 Hyundai Sonata
That is awesome.
I your car.
Old Dec 16, 2009 | 11:37 PM
  #217
tmnhs81's Avatar
So any high speed test drives yet??
Old Dec 16, 2009 | 11:39 PM
  #218
TLin401's Avatar
'13 Hyundai Sonata
Well how does it feel with yours? Does that smiley give me your answer?
Old Dec 16, 2009 | 11:41 PM
  #219
tmnhs81's Avatar
Hell yea!!!! I need to fuel up in less then 200 miles every time when i drive but when my sister does she gets away with 250 easy...
Old Dec 16, 2009 | 11:50 PM
  #220
undyroos's Avatar
a few in mexico. one on the bay bridge, CHP was there too. let's just leave it at that. it drives fine, although the difference is subtle to me. didn't destroy my knock sensors, no cels = i'm happy (not about the ticket though)
Old Dec 17, 2009 | 12:06 AM
  #221
tmnhs81's Avatar
Old May 23, 2010 | 10:48 PM
  #222
undyroos's Avatar
wash, clay, wash, wax, wax, re-badge
washed the car and finally put on the emblems I had lying around
Old May 23, 2010 | 10:50 PM
  #223
TLin401's Avatar
'13 Hyundai Sonata
Do I see eyelids or is that the lighting?
Old May 23, 2010 | 10:56 PM
  #224
undyroos's Avatar
no eyelids, just poor lighting... they don't look right on our cars, or most cars for that matter
  #225
CLtotheTL32's Avatar
Wow that's clean! Very nicely done
Old May 23, 2010 | 10:59 PM
  #226
TLin401's Avatar
'13 Hyundai Sonata
Anyway, back to what I was going to say...
that shit isn't right.
:timetochangemypants:
Old May 24, 2010 | 12:24 AM
  #227
tmnhs81's Avatar
Need more info on this...
Is this the whole grill or just the center "H" Part or Just the "H".?
Looks great like always.
Old May 24, 2010 | 12:37 AM
  #228
Go90go's Avatar
大日本帝国
^ Whole grill, it looks like. The backing is too perfect to be an A one. Besides, look how clean the black part is. Definitely a Saber grill.
~Cheers~
Old May 24, 2010 | 12:59 AM
  #229
undyroos's Avatar
Go90go's right. it's the entire grill, got it off ebay but only swapped the center emblem "mount" since the rest of the grill is exactly the same as ours.
Old May 24, 2010 | 08:46 AM
  #230
DAiNiUS's Avatar
Your car looks sick, and it's so ridiculously clean!
Also, post more pics if you have some since they're always a pleasure to look at.
Old May 24, 2010 | 09:30 PM
  #231
did removing the old emblems leave you with etched in/chipping paint?
Old May 24, 2010 | 11:29 PM
  #232
undyroos's Avatar
the paint underneath was perfect after I clayed it, only some residue from the double sided tape remained. but remember the rear half of my car was re-painted ~5 years ago so i expected it to still be in good shape.
Old Jun 4, 2010 | 03:08 PM
  #233
ParaSurfer1979's Avatar
This is by far one of the cleanest cars i've seen on this entire site. I'm all about the JDM factor. I've always gone this route as well. One question... I'm shock you have no window tint. Will you ever do this? It would def make the dark wheels "pop" even more. I must say I love this car best with the 5th gen Prelude wheels.
Congrates on maintaining a nice car.
Old Jun 4, 2010 | 03:51 PM
  #234
undyroos's Avatar
Thanks, no plans for tint. I don't like doing anything to my car that I can't do myself.
Old Jun 5, 2010 | 03:54 AM
  #235
tmnhs81's Avatar
I so envy you Andrew. Your car is so clean. Just love it. Mine has been parked in garage from last two days and full of dust. Looks like . Wish I had a silver or white color.
Old Jun 9, 2010 | 03:01 PM
  #236
undyroos's Avatar
woody knob
i wanted to change out the shift knob with a wooden one but the RL, MDX, etc ones were too $$$. went with something more in my budget, 2 1/4" wooden ball knob for all of a $1.25. drilled the hole out to slightly under 10mm and screwed it right on. loving the contrast. just wanted to have some fun with the interior, not trying to be a 917
Old Jun 9, 2010 | 05:02 PM
  #237
TLin401's Avatar
'13 Hyundai Sonata
I love it.
Old Jun 9, 2010 | 06:24 PM
  #238
tmnhs81's Avatar
So clever. Nice and very different that anything I have seen so far..
Old Jun 9, 2010 | 11:01 PM
  #239
bigwerm187's Avatar
Str8 Home built
put some of that wood stain stuff to match the woodgrain in the TL lol
Old Jun 10, 2010 | 02:19 AM
  #240
myisanog's Avatar
looks like a lollipop lol
