Where to find these replacement bolts? - Photo
The engine on my TSX is pretty clean, but some components are rusting worse than others. Particularly one of these three bolts are very rusted. I would like to replace all three of them. I have tried to find them on Acura parts web sites, but I cannot find them. The closesest I have come to is this diagram/web site but the bolts I am looking for are not listed :/
From here: CYLINDER HEAD COVER for 2012 Acura TSX SEDAN
Circled in red are the three bolts I am referring to. This is a stock photo from google.
Does anyone know the part number, or where I can have a better shot at finding these?
One is a bit worse than surface rust. If they are a few bucks a pop, I would like to just replace them. If they looked half as good as the ones in the above photo i could care less. The bad is one orange and is a huge eye sore.
Isn't 11 what you're looking for
#11 is kind of hanging out and doing its own thing. Not sure what that is for, but it looks more like a nut vs a bolt. Maybe these are nuts vs bolts?
Could be one of those. What is interesting is a few of the bolts appear to head both ends threaded...
1/4inch ratchet till tight is all you need.
Now that I know a bit more about them, its definettly worth a shot vs replacing them. Looks like its a combo of #11 and #12! Cool that was easy. Thanks guys!
Somewhat related pic:
Edit - Found a better diagram from here: http://www.hondapartsnow.com/genuine...1-pna-010.html
Received 7,772 Likes
justnspace (12-02-2016)
I have seen now two torque specs under 2 digits such as the one for these bolts but I have never found a torque wrench in that low a torque range. I ran into this when installing the TPMS sensors on my Aspec wheels. At that time I basically hand tightened them and told the tire shop to make sure they were on properly.
What do you do in this case if you actually want to torque to spec?
8.7 ft-lbs is ~104 in-lbs.
Snap-On QD1R200 does 40 - 200 in-lbs
https://store.snapon.com/Product-Det...e-P640957.aspx
Any lower than 40 in-lbs is getting into "finger tight" or less.
Or really annoyingly expensive tools. Mine is used for assembling a vacuum pump at work.
Torque Screwdriver - 57035 | Klein Tools - For Professionals since 1857 Hmm discontinued.
https://store.snapon.com/Adjustable-...e-P744932.aspx
