VSA & ABS light on after replacing wheel bearing
hi Guys, i need some help. my left side wheel bearing was broken so i had a local guy replace it for me. according to him it was in pretty bad condition. needed alot of work. he also replaced inner tire arm.
anyways i just picked up my car and VSA and ABS lights are on.
the car skids alot especially in corners.
and somehow i can feel every bump on the road.
the steering is softer than normal.
please let me know whats causing this?
thanks
thanks
On many honda/acuras, the wheel bearing only has the magnets that the sensor sees on one side of the bearing. You can install it backwards. I'm not sure if your car is set up this way, but it happens frequently.
so this monday he finally fixed the bearing issue and the light went away. today i took the car for allignment as i was out of town and the guy said the tire rod used is not the correct tire rod. he was not able to allign the wheels as some screw was lose and woudnt tight
how is that even possible. here is the picture
