Tracking down the goddamn engine whining noise.
Old 09-05-2015, 02:21 PM
TSX AMG Type //M i-VVT
iCrap's Avatar
I know a few people here are having this same noise.. I have tried:
- Replaced the alternator
- Replaced idler pulley
- Replaced tensioner pulley.
- Removed all tension from the belt, noise is still there.
- Noise is there regardless of AC on or off
- Noise increases with engine RPM
like seriously wtf is causing this? Now i think it's probably coming from the engine itself.
Somebody said there is a recall / tsb on the AC unit but i can't find this anywhere.. is there a TSB?
All i can think of now is taking it to the dealer to have them look at it.
Old 09-05-2015, 02:33 PM
LIST/RAMEN/WING MAHSTA 짱
princelybug's Avatar
What about the ground?
Old 09-05-2015, 03:12 PM
iCrap's Avatar
What about it? not sure what you mean
Old 09-05-2015, 06:28 PM
rawger's Avatar
I think he means road noise?
Old 09-05-2015, 08:08 PM
UTAH TSX's Avatar
Take the belt off and start it if the noise is gone it is most likely the water pump if it still makes the noise with the belt off it's the oil pump
Old 09-05-2015, 08:53 PM
cu2wagon's Avatar
Received 7,772 Likes on 5,045 Posts
Maybe he means the electrical system ground?
I've heard that in an old Celica. The thing sounded like it had a supercharger: as the revs climbed, there was always a weird whining noise coming through the speakers. Ended up being a bad ground feeding back into the electrical system.
Long shot, but maybe?
Old 09-05-2015, 11:47 PM
iCrap's Avatar
noise is still there with the belt off, so if you're right its the oil pump. If that's what the noise is then does that mean it's on its way out?
hmm maybe. but it really does sound like it's coming out of the engine.
Old 09-06-2015, 01:08 PM
mmafighta's Avatar
Honda wind bro.
Old 09-08-2015, 05:41 PM
2012wagon's Avatar
Mine was at dealer for 2 weeks.
It is back there again.
However, mine only does with A/C on
-Replaced idler pulley
- Brand new belt
Noise still there. They now got the Acura district manager involved.
Thank god for warranty
Old 09-08-2015, 05:50 PM
iCrap's Avatar
^ yeah so i just did that exact same stuff myself this weekend and the noise is there still. Like Utah says it may be the oil pump. Cause it STILL makes the noise when the belt is off completely.
Luckily you have warranty cause i paid $100ish for all that shit for no reason
Old 09-08-2015, 05:53 PM
2012wagon's Avatar
I will update you if they can solve it THIS time.
Old 09-08-2015, 06:01 PM
UTAH TSX's Avatar
This is the bulletin that Honda has for crv's but it is the same problem same part numbers to replace
Service Bulletin-09-002
© 2009 American Honda Motor Co., Inc. –
January 23,2009
Old 09-08-2015, 06:02 PM
2012wagon's Avatar
My dealer did the fix "per the bulletin" last time and it didn't cure the problem. FYI
Then again I own the TSX from hell
Old 09-08-2015, 07:29 PM
2012wagon's Avatar
Per dealer noise is from expansion valve
Has been ordered, will be here Thursday
Interestingly enough lots of Gen 1 TSX owners had same problem, where dealer replaced all bearings, belts, pulleys, only to find its the expansion valve:
https://acurazine.com/forums/problem...-sound-675749/
https://acurazine.com/forums/problem...-valve-855107/
Old 09-09-2015, 07:59 AM
UTAH TSX's Avatar
His noise is with no belt no ac pressure so no way could it be the expansion valve
iCrap (09-09-2015)
Old 09-09-2015, 09:19 AM
VTEC just kicked in, yo!
xtcnrice's Avatar
Received 1,112 Likes on 876 Posts
<p>
Originally Posted by 2012wagon
My dealer did the fix &quot;per the bulletin&quot; last time and it didn't cure the problem. FYI Then again I own the TSX from hell
No offense, but that name is reserved for UTAH TSX </p>
Old 09-09-2015, 10:00 AM
iCrap's Avatar
So you think its gotta be the oil pump?
Does that noise mean its going to die soon?
Is there a TSB on it?
Old 09-09-2015, 12:54 PM
xtcnrice's Avatar
<p>Time to get a Type R oil pump and rev your K series&nbsp;up to 9 grand!</p><p></p>
Old 09-09-2015, 02:58 PM
iCrap's Avatar
VVVTAKKKK!
I had to look that up to see if its real lol. only thing that comes up is a 99 integra type R oil pump
Old 09-09-2015, 03:11 PM
xtcnrice's Avatar
<p>Lol yeah alotta K series builds/rebuilds will source a RSX-S or DC5R oil pump, assuming it fits.</p>
Old 09-11-2015, 06:21 PM
UTAH TSX's Avatar
[QUOTE=iCrap;15547835]So you think its gotta be the oil pump?
IT WONT DIE OR BREAK JUST LOUD
THE HONDA ONE IS ALL I HAVE TO GO BUY
January 23,2009
udelslayer
1G RDX Problems & Fixes
05-06-2016 12:27 PM
09-17-2015 09:01 PM
09-15-2015 06:44 PM
09-14-2015 03:16 PM
Quick Reply: Tracking down the goddamn engine whining noise.
