Thoughts on LED Tail Light Designs?
#41
Off Road interpretation
More off-road
Hella
Enforcement
Enforcement 2
Enforcement 3
and we haven't even addressed the photometric requirements.
You are referring to lighting units such as driving lights or those KC lights that screw to the top of trucks. These lights are not addressed in the law but - as soon as they are turned on - they would supplement a lighting system (such as a headlight) and would thus violate the law as the FMVSS specifies that only one white light can be illuminated per side to meet the photometric requirements. In addition, the supplemental lights would exceed the photometric standards and are also illegal based on that.
#42
#44
The Infiniti style tails look pretty good. I just searched for images of the G and M35, and it looks like they have a reflector in the center of the LED rings instead of an array. With just the parking light on, they might appear to be similar.
Today I'm ordering a bunch of different LED's. Finding one with a small footprint that is also bright enough for brake lights is going to be a little difficult. Osram has some in a reverse mount package which looks interesting. They would be mostly hidden by the PCB when they're off.
Also, I checked Acura OEM parts and they sell the outer tails for about $125 and the inners for $95. The price difference between aftermarket and OEM isn't quite as bad as I had thought.
#45
Developer & Car Fan
Sure. I don't have access to my office files right now, but these links should get you started.
More off-road
Hella
Enforcement
Enforcement 2
Enforcement 3
More off-road
Hella
Enforcement
Enforcement 2
Enforcement 3
Matt
VortexBlueTSX (04-04-2012)
#46
Small update.
Yesterday a few hundred LED's arrived. Some mid-power, some low-power, some with optics and some without. I plan to try a few different combo's to see what works.
Then today the new OEM tail light arrived, so I finally got to take a good look at the housing. It's much deeper than I thought. On the other hand, the turn signal could be a challenge. It's hard to say at this point.
Tomorrow I'll pop the tail light in the oven and we'll find out if these housings can be pulled apart. If they have to be cut, then it probably won't be worth messing with.
Brake light on.
Stock bulb vs. 2.2CL LED array, just to give an idea.
Brake light on.
mrstak (04-12-2012)
#48
Looks pretty good man! Im down to get some of these, if you decide to sell them
#49
ROTAREDOM
Im down for a DIY so no one gets in trouble.... LED tails would be SEX with Ed.
#50
Everyday I'm rofling
These look incredibly bright. Ive been stopped behind cars at night at red lights and the led tails were destroying my eyes, and my eyes aren't sensitive at all. It made me hate the guy in front of me. I know you are just doing tests now but I hope they aren't going to be blinding everyone in the final product.
#52
Small update.
Brake light on.
Brake light on.
#53
7# werC 2uoYeeS
To be fair, we don't know how many LED's are in that array pic that he posted. He'll probably adjust accordingly and decrease the number of LEDs if it's too bright. Also, I'm pretty sure the LED pic wasn't in a housing and I think the stock brake light was in the housing.
#54
I understand the eyes response to light is logarithmic. That photo was just for fun. The array is going behind a tinted lens, so the guy asked me compensate by making it brighter.
Anyways, I started taking the tail light apart and it's a struggle. They're glued with a type of epoxy. Most of it came off clean, but the corner light end of the housing doesn't want to budge. The epoxy is cracking and because the lens is clear, it's visible from the outside. I may be able to sand it down once it's apart. I don't really know what to do at this point.
#55
Finally! The damn thing came apart! ...and I didn't crack the lens!
You're right about tail lights, mrstak. It's a very brittle plastic. I learned that lesson the hard way when I took my tails apart. I broke the passenger side lens, ordered a replacement and broke that one too.
Now looking at the insides of this thing, I had the idea of mounting the parking light LED's forward on that removable window. Then fix the brake light array to the reflector.
Here's a quick illustration.
It's time to start experimenting.
#56
make sure whatever you do can be sold to me later. Or just pm me so I can send you money now
VortexBlueTSX (04-18-2012)
#58
ROTAREDOM
I figured baking them would be the same as baking the headlights... This is gunna be cool though!!
#59
#60
Here's another small updated. I've been working on a few other projects at the same time, so this is moving slower than I'd like. Tonight I drew up a quick layout and etched a PCB to test the wide angle Osram's.
I expected some nasty reflections on the chrome surfaces. It's not looking very good right now, but there's a few things we can try. I have some Osram's in the same SMT package with 60° optics built in. The reflection shouldn't be harsh with these, so I plan to swap the LED's. Another option is to move the parking light ring closer to the red lens. If that doesn't work, as a last resort I can paint the "walls" of the brake light tunnel. Maybe try a flat silver, or possibly black?
#64
So... When you say this will be a one time thing I need some more info. Would you consider putting together lighting units for us , or atleast making a very in depth DIY so that we could replicate your process if we cannot be apart of it? Or can you just make mine and we could forget about the rest of these scrubs
And like, dibs if they sold their car
#66
I spent some time yesterday searching google for LED retrofits to see how they disassembled their tail lights. The ones that were plastic welded like the TSX were mostly pulled apart with trim removal tools sort of like how I had done it.
I suppose it's possible to cut the back of the housing open with a dremel and insert the PCB's from the rear. The only problem is that those inner lenses are clipped in from the front. The one that covers the turn signal is probably fine, but the brake light lens has those translucent rings which will effect the appearance of the LED's.
I'm not sure what to do. If one is broken, an OEM replacement is $125 and this project starts to loose its appeal. I think that's why those retrofit companies charge close to $1k for LED tail lights.
lol Yeah, I can assemble the PCB's and post a DIY for those that want to tackle this themselves. When the passenger side tail light is taken apart, I will post more photos.
Well last night a brake light array was fitted with the reverse mount Osram's. It looks really clean with the LED's being so small and sitting flush against the PCB. If these make it to the final design, I will silkscreen a red or silver ink onto the board so that it blends in better with the rest of the reflector.
There's a weird pattern to the LED's. On the next one, I plan to rotate the rings a little more and hopefully it will appear more uniform.
Clearly the brake light is too dim in this photo. Both arrays are direct driven off the power supply and I didn't have time to adjust it.
And here's just a side by side shot of incandescent bulb vs. the LED's.
#68
This looks fantastic!
#70
It's still moving in the right direction.
The parking light is getting the 60° LED's swapped in tonight. Not much else to report other than that. Most of the week I've been stuck at the office till about 7 pm.
mrstak, you're right about the brightness. They're also a deeper red. I'm trying to keep it close to OEM and these tiny LED's seem to work really well.
60 of them at 20 mA a piece is roughly 180 lumen. The original 7443 bulb is about 440 lumen. It sort of gives you an idea of how inefficient an incandescent bulb can be with more than half of the light being absorbed by the reflector and filtered out by the lens. The stock set-up also focuses most of its light into a relatively small area. The beam angle of the LED's is clearly much wider and more uniform.
#72
led pron ftmfw
#75
ROTAREDOM
Blazin Si died... he now rests in peace with moarrlow, 24boosted, sandpaper, modesto, and many other members!
#76
sandpaper is still alive
#78
ROTAREDOM
MC MiYoung3269 (11-01-2012)
