Passenger door handle
Does anyone know how to put back the door handle on the passenger side? The door handle is stuck on the open position and won't go back in. The actual door open and closes fine but does not go back in the actual handle.
Sounds like something might be disconnected inside the door.
Could be an easy fix but you'll need to pull off the door card and check things out. |
Probably the spring is broken. You will need to pull the door trim out and see if you can retrofit a spring in there, or just replace the handle.
