New Here Acura TSX 2009 (Base)
Hello! I am now a part of the Acura family. I have a 2009 Acura TSX Base model 5AT and I would like to know any tips on my vehicle that maybe I wouldn’t know upon purchasing. Thank you and please feel free to let me know on any secrets
Welcome to the forums.
Since this is a topic/technical issue which will require replies, and not a "New Member Introduction", this thread has been moved to the model specific forum.
Welcome
maintain it
enjoy it
take care of it, and it will take care of you till 500k Miles
maintain it
enjoy it
Issues with a code P0339
Hello everyone,
I really need advice or pointers on what to do next, I have an Acura TSX 2009 and its been giving me issues for the past couple of months and i don't know what it could be. In most mornings or every morning when i go to start my car it takes a while to start and when it finally does start all the service lights you can think of come on my dashboard, looks like a Christmas tree. My steering wheel doesn't move and the break pedal and stiff as well so in order to operate my car i have to turn off the car and then turn it on again but there is times where i have to do this procedure 1-3 times every morning. The code indicates that its a crankshaft sensor "A circuit". i swapped out two of those sensors each located in different areas of the motor, one underneath and the other within the motor and the problem persist. Help Please!!!
Hello everyone,
When your car is just turning over does it sound like the starter is "skipping" or turning over at different rates? Does it turn slow then speed up?
And when a crank sensor code throws it may put the car into "limp mode" which is why it acts different while driving.
Not saying this is your problem but it is a common issue with these K24 motors.
Usually listening to the starter will confirm your diagnosis, it'll just sound "off".
Also check for any other codes it may be throwing.
OR you could have a software issue. I know this pertains to Accords but it's the same engine in the vehicle but I'm not 100% sure it affects Acura's vehicles but it's worth checking out.
Honda service bulletin 09-050 - Ricks Free Auto Repair Advice Ricks Free Auto Repair Advice | Automotive Repair Tips and How-To
Very Helpful!!
Thank you for the advice, I will speak to my mechanic to try and see if i can swap out my starter, last time i had that fixed I’m not sure if it was an original part to begin with but it sure sounded different then when i had the original starter of the car. So maybe its that. Do you recommend not buying after market parts for certain areas?
Twotab
10-17-2014 10:47 PM
xxh
08-21-2010 03:56 PM
Xpditor
12-04-2008 11:45 PM
whoaclutch
10-27-2008 10:40 AM
