Let's talk about brakes: RL brake upgrade to be specific.
Old 10-26-2017, 09:58 AM
Sheefo2k's Avatar
I have done some research and I am well aware of some of the options out there. This is more of a discussion for members who upgraded their brakes in the past and what concerns did they run in to. Marketing can really sell a product but legitimate testing and first hand experience is what sells me on a product/design. The brakes on my 2011 TSX wagon will need servicing soon, and normally I like to upgrade parts (if possible), otherwise I purchase stock OEM parts if the need for upgrade is not worthy. I am a firm believer that the manufacturer of our vehicles supplied the car with the correct brakes from the beginning. Sometimes, they will leave some room for improvement but that usually comes with a tradeoff of some sort. The tradeoffs could be comfort (noise level), longevity or reliability. In my own opinion, reliability and longevity are very important since my i-4 5AT is not a race car and will never be race car. I personally like the RL brake upgrade since the design utilizes OEM parts but let's start things off with some simple questions:
What year and model is your car?
How many miles driven on your brake upgrade?
What parts did you upgrade?
Any concerns?
How would you compare them to the orignal factory brake setup?
Thank you
Old 10-26-2017, 12:12 PM
BROlando's Avatar
Received 1,166 Likes on 877 Posts
My 1st gen has:
-RL calipers
-FFC bracket for 12.8 (324mm) rotors. This is VERY important. Buy the kit for 324mm rotors or larger. Do not buy the kit for 12.6" (320mm) rotors.
-12.8" (324mm x 30mm) rotors for a 350Z with the brembo option.
My complaints:
-This will shift too much brake bias to the front axle.
-Pedal travel increases a little (13%, numerically).
-Almost all the readily available pad options are awful. Ceramics. All stupidassed ceramics.
**I was able to find a decent semi-metallic pad (that has been discontinued LOL). But I have not yet tried them. Hopefully that solves my issue. I fu#%ing hate general use ceramic pads.
On our 2nd gen, I just did the brakes with Raybestos EHT pads and blank rotors (mixture of duralast and centric and durago branded rotors).
I LOVE the EHT pad. GG DOT edge code friction rating. Dust washes off easily (moderate amount of dust), silent, and MOST importantly, they make shitloads of torque. A shitload is a numerical term. It means...a lot, as explained thusly:
My wife's 2nd gen's stock brakes with EHT's easily make more torque and stopping power per pedal travel than my 1st gen with the giant RL calipers and 12.8" rotors. Even though the 2nd gen (wagon) is using 18" wheels and 245/40's...the stopping torque is higher. Its an immense difference.
Again...I'm using ceramic pads on my 1st gen with RL calipers. Currently, I am using Satisfied "Performance" pads. I only bought them because they were labeled as "semi metallic". When they arrived, the box read ceramic. I was pretty pissed. I have used Powerstop Z23 (garbage), and Wagner Thermoquiet (quiet garbage).
So...maybe when I swap to the Bendix semi metallics that I have sitting on the shelf, I won't hate the RL setup so much.
One could use EBC yellows or Carbotechs on RL calipers so that the brakes actually work well. But neither is "commonly available". They cost between $130-160. If my Bendix pads let me down, I will just bite the bullet and buy Carbotech AX6 or EBC Yellows.
The following 4 users liked this post by BROlando:
cu2wagon (10-27-2017), justnspace (10-26-2017), Sheefo2k (10-26-2017), xtcnrice (10-26-2017)
Old 10-26-2017, 12:37 PM
BROlando's Avatar
Cliffs:
My wife's 2nd gen on STOCK sized brakes and Raybestos EHT pads:
-Bigger, heavier, and has a larger rolling diameter tyre.
-Stops harder than my smaller, lighter 1st gen with giant brakes.
-Better brake distribution. All 4 tyres engage ABS on hard stops.
-I have not detected a hint of fade even when I purposely abused the brakes to find their limit.
The EHT and random rotor setup cost me like $150.
My 1st gen with RL brakes:
-Looks good AF.
-Pad choices ruin the performance aspect of this mod.
-Despite their size, the brakes will fade fairly easily due to pad choice and massive dependency on front brakes.
The following 3 users liked this post by BROlando:
cu2wagon (10-27-2017), Sheefo2k (10-26-2017), xtcnrice (10-26-2017)
Old 10-26-2017, 12:45 PM
VTEC just kicked in, yo!
xtcnrice's Avatar
Received 1,112 Likes on 876 Posts
I don't have anything scientific to add really.. BROlando's post can pretty much close this thread haha.
But do I regret the setup? A little bit. You get what you pay for. They're sort of aesthetically pleasing... but that's pretty much it. No real functional improvement over the TSX OEM brakes, especially because these calipers weren't designed for the TSX.
To answer the rest of your questions:
- 2013 autotragic 4banger sedan
- Probably about 30k kilometres if I had to guess
- RL calipers (with rebuild), initially had NAPA blanks with EBC Redstuffs... switched to EBC blanks with Akebono ProACT because the Redstuffs dusted WAY too much and the NAPA rotor hat was getting pretty ugly from the rust.
Old 10-26-2017, 01:00 PM
BROlando's Avatar
That's a good way to put it, actually. The RL calipers don't offer much of an upgrade from the stock brakes for street use.
If you were doing some sort of customized setup for track use...then maybe the size of the RL upgrade parts would come in handy.
But for a performance street or daily driven setup, I would just use the stock 2G system and good pads.
The following 2 users liked this post by BROlando:
Old 10-26-2017, 07:30 PM
Sheefo2k's Avatar
I am glad you touched on the brake bias, that was one of my initial concerns. The TSX is a fairly light weight car and the RL calipers looked a little overkill. I would like to supercharge the wagon sometime down the road and I figured this would be a good time to beef up the brakes. I am starting to think the stock setup might be just fine for now and for later when it's supercharged.
Old 10-26-2017, 07:35 PM
Sheefo2k's Avatar
Thanks for your feedback. Did you also notice the brake bias under heavy braking?
Old 10-27-2017, 09:43 AM
xtcnrice's Avatar
Nope not really, at least not in the most obvious sense. I haven't had to slam the brakes on this car to the point of lockup yet (fingers crossed), so I haven't directly noticed any difference in this sense. With that being said, I typically brake before turning in even when driving more aggressively, so I haven't noticed any difference in over/understeer from hard braking.
Old 10-27-2017, 10:09 AM
TSX1012m6's Avatar
My 1st gen has:
-RL calipers
My complaints:
Do you not like ceramic pads?
Old 10-27-2017, 10:55 AM
BROlando's Avatar
How do you know my secrets?
xtcnrice (10-27-2017)
Old 10-27-2017, 10:58 AM
TSX1012m6's Avatar
I do not, please enlighten
Old 10-27-2017, 11:27 AM
BROlando's Avatar
Ceramic pads are just one of the many tools of the devil.
Sheefo2k (10-29-2017)
Old 10-27-2017, 01:01 PM
TSX1012m6's Avatar
How come? I thought ceramic = best for everyday. No/low dust and last a long time.
Old 10-29-2017, 05:45 PM
Sheefo2k's Avatar
That is a proven fact.
