Larger battery.
Old 01-13-2016, 12:17 AM
3rd Gear
johnma's Avatar
Larger battery.
It's possible to replace the current 51R battery with a larger battery without heavy modification to the battery bay area?. Have anyone done it before. Current battery is really not holding up too well in the winter and have to keep charging it between day while having the car seating.
Thanks.
Old 01-13-2016, 12:33 AM
urbanstereo's Avatar
search is your frined.
just need a tray and change out the cables
Old 01-13-2016, 01:17 AM
01acls's Avatar
Physical size is not the determining factor in batteries. A larger battery is possible in the same size space/container.
Battery size is determined by amperage rating. In general the more you pay, the more amperage you'll get.
Shop for amperage not battery size. For any vehicle there's usually at least two different amperage offerings.
musty hustla (01-20-2016)
Old 01-13-2016, 01:33 AM
01acls's Avatar
Ie.
Old 01-13-2016, 05:12 AM
slyslysly's Avatar
You might need a new battery.
Old 01-13-2016, 07:53 AM
D4nnyD's Avatar
I put in the V6 battery size (24F) about a month ago for better starting during winter. Worked out fine. Used an inventory Bin i found at work as a tray, which was the perfect dimensions. Doesn't move around horizontally at all and all the cables are sufficient length.
Still need to install a proper tie down, just been lazy.
Old 01-13-2016, 09:21 PM
3rd Gear
johnma's Avatar
Your right. I did some more research, looks like most Honda accord I4 drivers upgraded to 24F and V6 comes with 24F.
Old 01-14-2016, 09:23 PM
alexb92's Avatar
Your battery is dying. Just replace it with a reputable brand with a great warranty and call it a day.
Old 01-15-2016, 08:17 AM
DLCU2's Avatar
Sounds like you need a new battery rather than a larger one.
I was having a similar issue with the crappy OEM battery that comes with the car.
I'm running an Interstate 51R battery that has more Cold Cranking Amps (500 vs 430): Car and Truck Automotive Batteries - Buy a Vehicle Battery for Cars or Trucks | Interstate Batteries - Mega-Tron 51R Automotive Battery Five-Year Performance 500 CCA.
The car starts up fine even at 10 degrees F. Goodluck
Thanks.
Old 01-15-2016, 08:51 AM
icu2tsx's Avatar
Yup! got my Interstate at Costco for under $80 with 42 month warranty.
Old 01-16-2016, 03:12 PM
3rd Gear
johnma's Avatar
DONE, autocraft 24F AGM battery fits right in. Have to flatten the metal hold down to make it fit for a larger size.
WheelMcCoy (01-17-2016)
Old 01-18-2016, 03:22 PM
vraster's Avatar
dead battery 08
[B][i have the same problem did you find anything, I did find some good stuff a few months ago.
Thanks.
Old 01-25-2016, 10:38 PM
Itr0059's Avatar
51r
Yeah I just replaced my small 51r
With a larger AMG 24f (v6)battery. I used a v6 tie down and boom it fitted right in!
cca 680 800 cranking amps
Feels so much better !
xtcnrice (01-26-2016)
Old 01-26-2016, 10:59 AM
t3hhcaptain's Avatar
Did you also get the battery box? Or does our stock tray work?
OEM Acura TSX SEDAN 2010 BATTERY (V6) parts
Old 01-27-2016, 12:17 PM
Itr0059's Avatar
I installed mine without the box , if you want to install one the V6 box would be needed ! They are cheap to get anyway. ..!
t3hhcaptain (01-28-2016)
teh CL
05-13-2018 09:57 AM
youngTL
08-03-2017 10:58 PM
OnlyDaanish
01-19-2016 03:23 PM
Kaputnik
1G RDX (2007-2012)
01-18-2016 04:48 PM
haha0002
1G RDX Problems & Fixes
01-12-2016 07:39 PM
Quick Reply: Larger battery.
