iPod Connection Temperamental
Old 09-16-2008, 01:29 PM
webs's Avatar
I think I've seen this mentioned before. My iPod connection randomly says "No Data" and won't load my songs. Its so temperamental now that I can't put anything in the console with my iPod without knocking it out of service. Has anyone figured out a solution to this?
Old 09-16-2008, 02:44 PM
Colin's Avatar
Received 1,012 Likes on 567 Posts
Have you tried a different cable? To me, that's step one. Step two would be to try a flash drive to see if it's the iPod. Step three is visit the dealer.
Old 09-16-2008, 08:18 PM
WTH happened to my garage
HeavyDuty's Avatar
My aux cable crapped out in my 07 Civic Si on Thursday, but the USB cable worked perfectly in the TSX on Friday. They don't gradually go out, they're ok one day, done the next.
Old 09-18-2008, 12:26 PM
Craig-D's Avatar
Yeah, it's happened to me too, but only when I pick up or otherwise move the iPod. I've found that if you leave it alone at the bottom of the console, it's fine even if you pile stuff on top of it. So just make sure it's at the very bottom of the console and leave it be. I haven't had a problem since, and I have other stuff on top off it.
Old 09-18-2008, 12:28 PM
The Anti Avatar
2009TSX's Avatar
Not much of help in your situation, but I have had no issues with mine. I even picked it up and shook it a bit... no problems.
Best of luck with yours.
Old 09-21-2008, 09:42 PM
Forced Induction
DeadLock's Avatar
Mine is acting up as well, I have to reconnect it. Sometimes it says no data, sometimes it says it's not compatible. I am using a first gen nano.
Old 09-23-2008, 11:24 PM
OCD in the OC
ccarbajal08's Avatar
I'm having problems as well. I have the newest software for my iPhone. However, my system tells me, "unsupported version."
Old 09-25-2008, 09:47 PM
OCD in the OC
Ok, today it worked. You're right in using the word, "temperamental."
Old 09-28-2008, 02:36 PM
pja79's Avatar
Mine does the same thing, i find that turning the stereo off then on resolves the issue.
Old 09-28-2008, 09:19 PM
OCD in the OC
I spoke too soon. It still doesn't work!
Old 10-06-2008, 01:10 PM
AG11's Avatar
Mine says "Unsupported Version" but I was told this is because my ipod is an older version (60GB Ipod Photo):
I guess Im going to have to test it with a friends (newer) ipod to see if its the USB port or the ipod.
Old 10-06-2008, 02:40 PM
CBP TLX
CybrRdr's Avatar
I have a iPod Video 5g plugged into my radio via USB. Sometimes it will lock up with my radio saying "No Data". I would then have to re-boot my iPod (hold Menu + Center buttons) and everything would be fine again.
Old 10-06-2008, 02:51 PM
AG11's Avatar
It appears that it is because I have an ipod that is not supported by the USB port. I found the following in this thread:
https://acurazine.com/forums/2g-tsx-problems-fixes-145/3rd-gen-ipod-getting-unsupported-ver-error-679178/
The 2009 owner's manual says its compatible with the following models and firmwares:
iPod 5G - Ver. 1.2 or more
iPod classic - Ver. 1.0 or more
iPod nano - Ver. 1.2 or more
iPod nano 2G - Ver. 1.1.2 or more
iPod nano 3G - Ver. 1.0 or more
iPod touch - Ver. 1.0 or more
iPhone - Ver. 1.1.1 or more
So I'm just going to have to use the Headphone connector for the time being....until I get a new ipod.
Old 10-06-2008, 03:30 PM
Hondaholic
Taterhole's Avatar
Flash drive is working great in my wife's car.
Got a great deal at Newegg on this: http://www.newegg.com/Product/Produc...82E16820220251
Will buy a bigger one soon.
Old 10-09-2008, 11:07 AM
webs's Avatar
Could just be my car, but for some reason I don't have as many connection problems if i remove the iPod plus the white apple cord every time I take it out. When i leave the white cord plugged in and reconnect I get the "no data" display more often. Weird.
Old 10-13-2008, 04:23 PM
OCD in the OC
Finally, I erased all of the movies from my iPhone and now it works.
Old 02-02-2009, 08:47 PM
ressling's Avatar
make sure you have your iPod firmware up to date. Also, only use Apple adapters/cords...
Old 02-02-2009, 09:12 PM
risc's Avatar
I've found that whenever it doesn't load up my songs, I reboot my iphone and it works. Kinda annoying though. And I wish there was a way to import all my contacts into the car through bluetooth or some other way instead of manually entering in all the contacts.
navtool.com
3G MDX (2014-2020)
32
01-20-2016 11:43 AM
navtool.com
31
11-16-2015 08:30 PM
TLguy42
09-26-2015 11:27 AM
4drviper
09-23-2015 09:00 PM
Quick Reply: iPod Connection Temperamental
