how do you remove antenna on roof?
Old 06-03-2012, 12:25 AM
12TSXtech's Avatar
I want to put black vinyl on the roof but idk how to remove the antenna. Does anyone know how to remove the antenna and is it easy to do?
Old 06-03-2012, 06:11 AM
TSXV6Guy's Avatar
It involves removing or partially removing the headliner. Not a trivial undertaking.
Old 06-03-2012, 08:50 AM
ceb
ceb's Avatar
Received 1,276 Likes on 951 Posts
Correct. You'll want to vinyl around the antenna.
Old 06-03-2012, 01:55 PM
Vancouver B.C.
ttk5's Avatar
The antenna is glued down AND bolted down. Once you loosen the bolt, you can pull the antenna off slowly cause the glue is pretty strong. You access the bolt by unscrewing your rear dome light piece. Take that whole dome light assembly out and put your arm inside. You can unscrew the nut without removing the headliner.
If you do not want to break the glue bonds, you can just wrap around the antenna. I wanted to tuck the vinyl underneath the antenna so that why I did this. Also, the antenna is NOT fully removable. It is attached to a thick cable so you can pull it off the roof, but it will still be attached to the car.
The following 4 users liked this post by ttk5:
Acura_Dude (06-03-2012), chaqui74 (06-03-2012), plumpduck (11-23-2020), TSXV6Guy (06-03-2012)
Old 06-03-2012, 02:03 PM
TSXV6Guy's Avatar
Originally Posted by ttk5
[...] You access the bolt by unscrewing your rear dome light piece. Take that whole dome light assembly out and put your arm inside. You can unscrew the nut without removing the headliner. [...]
Interesting, and thanks: I just learned something!
Old 06-04-2012, 12:05 AM
12TSXtech's Avatar
Thankz for the help...I appreciate it
iRaw
ILX Photograph Gallery
30
08-05-2016 04:41 PM
dainmezron
10-16-2015 06:56 PM
us285126
10-02-2015 02:03 PM
rhdune16
09-28-2015 11:31 AM
spoiler900
09-23-2015 04:41 PM
Quick Reply: how do you remove antenna on roof?
